Old November 18th, 2008, 11:18   #1
Leftygolfer
Fuel Economy: 51 over 198,000 miles, currently averaging 53.
Default Where is the glow plug relay located in a 2000 Jetta TDI?
I have a 2000 Jetta TDI and want to replace the glow plug relay switch as I am no longer getting power to the glow plugs. I can't find the location of the relay switch. Can anyone help?
Leftygolfer is offline   Reply With Quote
Old November 18th, 2008, 11:30   #2
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
Relay 180 on the thirteenfold auxillary relay panel, below steering column, left.
It's expensive, so you might want to do an output test with VCDS. It will cycle the glow plugs on and off repeatedly and it's obvious when the contacts are working.
jcrews is offline   Reply With Quote
Old November 18th, 2008, 12:39   #3
Leftygolfer
jcrews
Thanks. Thought I would ask before I started to pull all the panels off. Purchased a new Bosch relay for $34 online, instaed of paying the dealer 6 times that amount.
Old November 21st, 2008, 08:23   #4
kyledc
Fuel Economy: 45 mixed
Lefty, where did you get the relay this CHEAP?!?!
kyledc is offline   Reply With Quote
Old January 2nd, 2009, 21:36   #5
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Try partsgeek.com I paid about that same amount.
kjclow is offline   Reply With Quote
Old January 2nd, 2009, 21:49   #6
Bora-chiara
Bora-chiara's Avatar
Fuel Economy: 49-51
I have a GP relay 180 if any one needs one.
-2002 MK4 ALH *Bilstein HD, DG Short Shifter, 3" Cat Back, PP764
-2005 B5.5 BHW *Malone 1.5 Tune, Chainless, Euro E-Codes
-Y2K NB GLS TDI 125k Miles -DEAD
-1998 "GLX" MK3 TDI 225k Miles-SOLD
Bora-chiara is offline   Reply With Quote
Page generated in 0.14314 seconds with 9 queries
[Output: 66.97 Kb. compressed to 58.08 Kb. by saving 8.89 Kb. (13.28%)]
