Old November 15th, 2008, 00:21   #1
fluidpower
TDI(s): 06 PD
Default car wont start.....
whats up guys, I just had a prolem with the lift pump in my 06 pd and i fixed that. A little previous info... the car would idle but would hardly run and it seemed to use filters like crazy. Everyone recommended checking the lift pump, I did and come to find the screen was clogged to hell. Cleaned it, threw it back in and off I went. However now I was driving, maybe 50 miles since looking at the pump and i felt some hesitation in boost and up hills. I got to where i was going, getting ready to go back home and the car died and will not start. I had to have my brother come with a dolly and tow me home.
I tore the lift pump out again to double check its working correctly and it is. A couple guys also said sometimes the tandem pump goes bad but its not likely. I guess that would be my next place to look right? The fuel filter is clean white and the lift pump works, so tandem right? Where is that located? Is there any other opinons to what the problem could be?
thanks
fluidpower is offline   Reply With Quote
Old November 15th, 2008, 03:49   #2
2004STARWARSTDI
2004STARWARSTDI's Avatar
Thumbs down Tandem pump
I doubt that your tandem pump is bad. How come your lift pump got clogged? Have you been running home made bio, or got a bad batch of diesel? Most likely you have an air leak or your lift pump is giving up. The tandem pump is on the opposite end of the block from the timing belt. Apparently you don't have a Bentley and it would be better off left to the experts. Tandem pumps do not fail regularly!
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old November 15th, 2008, 06:18   #3
DanG144
When you say your lift pump is working, what do you mean? How do you know?
Given your last problem, I would check out the lift pump a bit more thoroughly.
How much flow does it put out? It should put out 3 liters per minute. check it by taking the central line off of the fuel pump, going to the engine, off and directing it into a fuel container. Verify that you get 3 liters per minute or more.
It was not clear in your last post if you cleaned the canister screen or if you cleaned the half moon shaped fine wire mesh screnn on the bottom of the fuel pump, which is inside the canister.
http://forums.tdiclub.com/showthread.php?t=225672
It was not clear if you cleaned your fuel tank, either.
Try the flow test, if it is not good, then go back to your lift pump/fuel tank issue. Pump out your fuel tank, remove the lift pump and disassemble it and clean it. Then wipe down your fuel tank with lint free shop towels. Clean the tank as thoroughly as you can, reach way back off to the sides.
If your lift pump is working, I have just wasted a lot of typing time.
Dan
Old November 15th, 2008, 06:34   #4
Lefty
Lefty's Avatar
Fuel Economy: 48.5 MPG
Does the 06 have the T-fitting on the fuel filter? Is there any leaking around the fuel filter and did you change the T-fittings/0-Rings? Could just be air in the line.
<===Lefty===
2000 GLS Jetta TDI 46.5 MPG 394k and Counting
Lefty is offline   Reply With Quote
Old November 15th, 2008, 08:28   #5
DanG144
If the lift pump is working, and the fuel filter is clean, there is no concern with air in the fuel lines - even the return line - with these cars.
Dan
Old November 15th, 2008, 08:42   #6
Lefty
Lefty's Avatar
Dan
So they are a lot different than the 1999.5-2003?
<===Lefty===
Old November 15th, 2008, 09:36   #7
weedeater
Fuel Economy: 54/43/38
yes...
It may seem like I am doing nothing, but on a cellular level I'm really quite busy.
The game of Bridge is like Sex: You need either a good partner or a good hand.
You're either part of the solution or you're part of the precipitate.
weedeater is offline   Reply With Quote
Old November 15th, 2008, 10:44   #8
fluidpower
TDI(s): 06 PD
I am not sure if the lift pump will flow 3 liters a minute, I will test that today. The metal screen on the bottom of the lift pump is what was clogged. I have no idea what it was clogged with.
How would there be air in the system when I drove the car around or over 50 miles, then it decided to shut off?
Old November 15th, 2008, 23:26   #9
fluidpower
TDI(s): 06 PD
***update..
Well I pulled out the lift pump again to test the rate of flow. It flowed a little more than 3 liters in a minute so that checked out. I threw the pump back in and made sure i had the same flow coming to the fuel filter housing. I did. I took the lines off the fuel rail that goes across the head to make sure the housing didnt have any restrictions. I come to find it has 1/3 the flow coming out of the pressure line. I then hooked the lines staright to the metal rail that goes across the head (competly bypassed the fuel filter) and the engine started. I took the filter cap off or w/e its called and I think its called a popper valve, it failed and prevented the fuel from filling up the bowl. So off to the dealer on monday!
thanks guys
Old November 16th, 2008, 00:29   #10
whitedog
I don't have a 2006 si I'm not sure what this popper valve thing is. Can we get some more information on this? I would like to add it to my no start thread.
Old November 16th, 2008, 19:29   #11
fluidpower
TDI(s): 06 PD
I will get some pics if you want and post up.
Old November 16th, 2008, 19:56   #12
joetdi
I think some of the early 2006 had the old fuel filter setup. I think he is talking about the T-stat on the fuel filter, I think. Joe
joetdi is offline   Reply With Quote
Old November 16th, 2008, 19:57   #13
DanG144
I would be interested in the pictures, too.
Good follow through on your part. You just got a few tips and ran with it.
Dan
Old November 16th, 2008, 21:45   #14
fluidpower
TDI(s): 06 PD
well i snapped a couple pics with my phone... so sorry if the quality sucks...
heres how I bypassed the filter... easy... and the car started right up.
heres the part that failed.. im not sure the technical name for it.
and heres the flip side of it... you can see that little white valve thingy... and can see the shaft in the middle of it... yeah thats because it broke and blocked the flow... that was the problem...
Old November 16th, 2008, 21:56   #15
whitedog
Cool. Thanks for that. Now, I just need a similar picture of one that hasn't failed.
I know that there are like three versions of the fuel filter, do you know which one you have?
Page generated in 0.18021 seconds with 9 queries
[Output: 119.35 Kb. compressed to 98.66 Kb. by saving 20.69 Kb. (17.33%)]
