Old November 13th, 2008, 12:54   #1
robhegedus
TDI(s): 2002 Golf
Default HID Projector Retrofit
Well I've got some bi-xenon projectors, shrouds, etc on order and I'm going to be retrofitting them into my stock housings. I've done a lot of reading up on retrofitting, but was just wondering if anyone on here has retrofitted a MKIV golf headlight. I know the Jetta has been done forsure.
What projectors did you use? How did it turn out? Any hints/tips/tricks/photos you'd like to share?
I will make sure to post pics when it's all said and done. Maybe even some how-to pics depending on how it goes.
2002 Golf 5spd: Malone Tuning Stage 3 tune, PP764's, G60/VR6 clutch, CCV mod, Cat/Muffler/Ventectomy, Mcnally Boost/EGT combo gauge, E55 Bi-Xenon Retrofit, Koni STR.T struts, Koni Red shocks, Audi TT LCA bushings
Courtesy of robnitro: "He can make 400 ft lbs easy but at 2 rpm, using the starter"
robhegedus is offline   Reply With Quote
Old November 13th, 2008, 13:44   #2
Hoodie
Hoodie's Avatar
If I had a Golf I would just buy an OE or aftermarket solution. There are so many options that look nice and aren't rediculous looking like most of the aftermarket Jetta headlights.
Why bother hacking a set all to pieces when you could probably buy a used set of OE projector headlights and get a better/cleaner final result.
Sorry for the non-constructive post....Just my 2 cents.
And I kind of fell off the retrofit bandwagon so I am probably missing something....but why bi-xenons for a Golf? They have seperate high/lo bulbs unlike the Jetta? What are you going to do with the hi-beam part of the housing?
02 Jetta TDI 305K
04 Passat TDI 398K
16 GTI 8K
Hoodie is offline   Reply With Quote
Old November 13th, 2008, 15:20   #3
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
scroll vortex MKIV FAQ. A guy there did both a Jetta and a Golf retrofit.
Found it: http://forums.vwvortex.com/zerothread?id=3115601
When interviewed about why no diesel for the new F150, Ford responded to effect that diesel makes no sense in the 1/2 ton market. That brilliance should be repeated in every Ram 1500 eco-diesel commercial.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Old November 13th, 2008, 15:41   #4
robhegedus
TDI(s): 2002 Golf
Thanks alot for the link. That should help me out.
As for the bi-xenon's...why not? I do a lot of highway commuting and during the winter most of that is in the dark. So I'm going to have 4 high beams which should be pretty awesome.
As for not going with an aftermarket solution there were two reasons I guess:
1 - Anything with a decent projectors are very expensive and hard to find.
2 - Anything affordable has a terrible cutoff and beam pattern.
So I decided to get some quality components and try doing it myself. I know it's going to be a challenge but it should be pretty rewarding when it's done.
Old November 20th, 2008, 05:13   #5
20IndigoBlue02
20IndigoBlue02's Avatar
my old Golf, I used a S2000 projector. They are one of the best projectors out there in low beam performance (second to the LS430).
Other good low beam projectors: TSX (great for the budget), RX330/350/400h AFS.
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old November 22nd, 2008, 14:04   #6
aRd
good on you, keep a build up thread on the forum updated.
aRd is offline   Reply With Quote
Old November 24th, 2008, 09:04   #7
DucMike
DucMike's Avatar
TDI(s): none
Check out this thread on the Vortex as well. The important part starts about 2/3 of the way down the page, look for "brought one project home today". *Bi-xenon conversion*. If you have some time, check out the rest of the build. This guy has some serious talent.
Mike S.
2003 GTI 20th AE #3806
(Yea, I know. It's not a TDI but...)
DucMike is offline   Reply With Quote
Old November 26th, 2008, 04:15   #8
robhegedus
TDI(s): 2002 Golf
Hey guys...got the parts in the mail. Did a clear lens swap, then did a color mod...then fixed the hinge I broke on the cutoff shield doing the color mod...
Anywho...due to work schedule (work far up north in the boonies/far far away from my headlights) I haven't started the retrofit yet. Still keeping my eyes peeled in the plumbing sections of any hardware store I go into for the right pieces, but once I get started I'll keep you updated.
Old November 27th, 2008, 10:03   #9
mctdi
TDI(s): 2010 Jetta
FYI - The headlight lens will come off without baking it. Remove the metal clips, then with a medium steady pull, the rubber sealant will stretch, and tare. Do like a starfish.
The rubber sealant will reseal, too. But to be sure, I seal the seam with clear RTV silicone.
Ben / mctdi
10/24/2015 => 300,262 miles
5/29/2010 Jetta 12 miles [new],
R.I.P. 2004 Golf 362,993 miles,
mctdi is offline   Reply With Quote
Old November 27th, 2008, 10:14   #10
compu_85
Gadget Guy
compu_85's Avatar
It's a good thing the Mk4s have clear lenses... looking at those pics mounting the projectors behind the lenses with the pattern on them makes way too much glare.
Present:
2013 Fiat 500e. 22,000 miles.
Past:
compu_85 is online now   Reply With Quote
Old November 27th, 2008, 16:21   #11
robhegedus
TDI(s): 2002 Golf
mctdi - Thanks for the tip...I'll give that a try and I'll only bake them if needed. I'm a little iffy about putting my headlights in the oven.
Old November 27th, 2008, 16:57   #12
mctdi
TDI(s): 2010 Jetta
FYI - It is a bit slow going at first.
Ben / mctdi
Old November 27th, 2008, 22:01   #13
mrwizard
mrwizard's Avatar
TDI(s): 2000 Jetta
cant wait to see some pictures!
2000 TDI Jetta with some mods...
mrwizard is offline   Reply With Quote
Old November 28th, 2008, 04:03   #14
robhegedus
TDI(s): 2002 Golf
Me too! haha...Probably won't happen until xmas break though due to work, wife, etc., so we're still a little ways off yet. But like I said, I'd really like to document it so I'll make sure to take some pics.
Old November 28th, 2008, 07:02   #15
unL33T
I'd probably bake them if I were to take mine apart again. I did before but I don't think I did it long enough. I marked up the edges of the plastic pretty good prying it with stuff.
Ex-TDIer. Current vehicles:
Red 1987 Porsche 944 5 spd; Red 2009 Aprilia RS125 2 stroke; Grey 2005 Mitsubishi Outlander AWD 5 spd
Save the manuals!
unL33T is offline   Reply With Quote
Page generated in 0.32738 seconds with 9 queries
[Output: 125.47 Kb. compressed to 103.66 Kb. by saving 21.81 Kb. (17.38%)]
