Old November 12th, 2008, 20:00   #1
Racing_Rush
Default Block heater cord?
Its getting cold and I can't seem to locate my block heater cord. Can anyone point me in the general direction to its location?
2006 Jetta TDI, 216,xxx kms, 17" Core Racing Kobe wheels with 225/45R17 Nokian WR G2 Tyres. 312mm front brakes with 4 corner ECS SS braided lines. PD140 turbo, Devils Own water/meth, Unitronic Stage 1+ reflash, 2.5" custom downpipe and straitpipe, ECS 14lb flywheel and Sachs VR6 clutch disc.
http://www.cardomain.com/ride/3314956
Racing_Rush is offline   Reply With Quote
Old November 12th, 2008, 20:07   #2
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Unless it's something special for Canada or a cold weather package, there are no block heaters in TDIs.
You can purchase a coolant heater though that works well.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old November 12th, 2008, 20:29   #3
maloosheck
maloosheck's Avatar
Define block heater. Then we can TRY to look for a cord.
maloosheck is offline   Reply With Quote
Old November 12th, 2008, 23:40   #4
NarfBLAST
NarfBLAST's Avatar
Fuel Economy: 5.8 - 4.5 (40 - 52)
Ask the dealer or previous owner if/where they installed one... when you confirm that you don't have one try www.tdiheater.com
- Paul
2001 VW Golf NADI 5MT 605,000 km w/ 1.5" lift / Valeo G60/VR6 SMF /
Sprint 520's / RC3 / turbo delete
The NARFmobile blog / push button ignition / thrustmaster shifter / http://narfblast.com
NarfBLAST is offline   Reply With Quote
Old November 13th, 2008, 13:10   #5
dayne66
dayne66's Avatar
FYI: A frostheater shipped to Canada right now is just over $160 cdn. Mine is in transit. http://www.frostheater.com/
Traded for '14 Jeep GC Summit 9.85l/100km so far
dayne66 is offline   Reply With Quote
Old November 13th, 2008, 16:52   #6
MJ72
Fuel Economy: 40ish
I installed mine this week and can not believe I ever lived without one! Plus, very easy install.
2006 Jetta - 208,000 miles
MJ72 is offline   Reply With Quote
Old November 22nd, 2008, 08:59   #7
CJB3_TDI
Fuel Economy: Best:49.49mpg, Worst:33.94(-42C) Average:41.193
hello Racing_Rush - no block heater on the TDI - the dealers may install an oil pan heater - if so check for the cord at either front lower corner zap strapped to the lower grill - previous owner may have added an in line coolant heater as listed above
06 Jetta TDI 5spd with ESP, MM, ScanGuage II,HiddenHitch w Modulite Protector, EVO OSIRIS, DMF replaced at 48k km
CJB3_TDI is offline   Reply With Quote
Old November 22nd, 2008, 20:36   #8
Racing_Rush
Thanks for all the replys, I have changed my own oil so I know there isn't a oil pan heater. I guess I will have to put an antifreeze heater. I am also thinking of adding a second battery in the trunk any thoughts?
Old November 22nd, 2008, 20:45   #9
NarfBLAST
NarfBLAST's Avatar
Run the wires inside the car, not outside. Otherwise you could electrify your rear axle and melt your hand brake cable: .http://forums.tdiclub.com/showthread.php?t=229903
- Paul
Old November 23rd, 2008, 10:37   #10
fuzzywulf
TDI(s): 06 Jetta
Fuel Economy: 5.2L/100km
i put a zero start in my A5 yesterday bought the heater from greggs for about $60-70 easy to install hung it off of the LS frame bolt and ran the hose over top of the frame and under the air box im in edmonton if you want to see what i did
'06 Jetta 5spd, Luxury pkg, Scan gauge, vag com, 40hp tune
fuzzywulf is offline   Reply With Quote
Old November 23rd, 2008, 14:03   #11
newbury
TDI(s): 2009 JSW
Pics?
newbury is offline   Reply With Quote
Old November 24th, 2008, 04:11   #12
Rival12
I have a factory installed.....plug? block heater?
Bought mine 06 Jetta TDI in Winnipeg, always had it.....i assumed it was a block heater.....could be oilpan heater....
When it's plugged and i start it in the cold....i.e. -9, -10 C.......i get engine temp reading (it moves up)
It sticks out the left front grille....i tuck it away in the summer....it can hardly be seen.
The car does not like the cold here....and anything around 0....i plug it in......it has harsh starts otherwise....(even for a diesel)
FYI. I'm in Edmonton.
Rival12 is offline   Reply With Quote
Old November 24th, 2008, 18:35   #13
fuzzywulf
TDI(s): 06 Jetta
there are no frost plugs on the engine unless the dealer put a circ. heater in it is a pan heater.I will take pics on the weekend and post them works good car was 70 degrees this morning
Page generated in 0.16217 seconds with 9 queries
[Output: 110.07 Kb. compressed to 91.30 Kb. by saving 18.76 Kb. (17.05%)]
