Old November 8th, 2008, 12:51   #1
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
Default MikesTDI letter from VW timing belt interval
I am posting this re the benefit of MikesTDI. He asked me to post this for him.
He asked VW specifically about the timing belt change interval and VW responded to him with the an 80k interval. I've talked to Oilhammer who says its okay to 100k. Can you gurus chime in and let us all know your opinions on this. I've changed his name on the correspondence to his handle fyi.
Reference # 808106419
Dear Mr. MikesTDI:
Thank you for your e-mail requesting information regarding the maintenance on your Passat. I can understand you wish to take the best possible care of such an impressive car, and I appreciate the opportunity to respond.
We recommend the timing belt to be replaced at 80,000 miles on your Passat. The oil recommended to be used in your engine is VW 505 01 quality, fully synthetic oil. I am happy to clarify this information for you. For any further questions regarding the technical aspects of the maintenance on your car, please contact your local Volkswagen service facility.
As a valued member of the Volkswagen family, your questions are important to us. Again, thank you for your e-mail. If I may be of future assistance regarding this, or any other matter, please donít hesitate to contact me again by e-mail at www.vw.com, or through our Customer CARE Center at (800) 822-8987. If I am not available one of my colleagues will be able to assist you.
Sincerely,
Gabrielle De Land
Ext. 43544
Customer CARE Advocate
*Please do not reply to this e-mail, as we currently are unable to accept replies. Thank you in advance for your understanding.
2015 Golf SE TDI with DSG, 88k.
and formerly a 2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is offline   Reply With Quote
Old November 8th, 2008, 12:53   #2
dieseldorf
top post dawg
dieseldorf's Avatar
it's interesting if they're officially backing away from the 100k interval. Personally, I don't think it's a bad idea based upon failures we've seen over the past few years. It's a risk simply not worth taking.
Take care, G!
Old November 8th, 2008, 13:00   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I have yet to see a single PD engine, or a single later ALH engine (2003) that has had any issues before 100k miles. I note the position of things, like the tensioner indicator, and how far 'off' the cam is before the lock pin will slide in, and in every case the PDs all still look like new.
Of all the ALH engines that have simply NEGLECTED the belt, the original one from the factory, but remained untouched otherwise, I have seen failures as low as 117k and as high as 196k. The later (textured style) belts that all the 100k mile ALHs get, which is the same material all the PDs already have, seems to hold up really, really well.
In fact, 99% of every timing belt or timing belt related issue I see on any VAG diesel engine is from neglect, or doing the job incompletely and/or improperly. And trust me I see PLENTY of that, as do others.
oilhammer
www.cardocautomotive.com
Old November 8th, 2008, 13:02   #4
leicaman
leicaman's Avatar
Thank you for clarifying this Oilhammer. I will have mine inspected at 80k by a guru and then move on from there.
Old November 8th, 2008, 13:06   #5
leicaman
leicaman's Avatar
Here's what VW says on their very own website re 2005 Passat TDI as of Nov 8, 2008:
Items to be serviced:
Engine Oil - change
Engine Filter - change
Timing Belt - check
V Belt/Ribbed Belt - check tension/condition
Air Cleaner - replace filter
Water Separator - drain
Fuel Filter - replace
Windshield Washer Fluid - check level
Automatic Shift Lock - check operation
Brake System - check damage/leaks, pad thickness, fluid level
Wheels - rotate from front to rear
Battery - check electrolyte level
Engine - check for leaks
Pollen Filter - replace
Cooling System - check level
Transmission - check for leaks
Tires/Spare - check condition
Driveshaft - check boots
On Board Diagnostics - check Diagnostic Trouble Code memory
Door Hinge - lube
Headlights - check and adjust if necessary
Exhaust System - check for damage and leaks
Sunroof Frame - clean and lubricate
Road Test - check system functions during and after
Power Steering - check fluid level
Automatic Trans. Fluid and Differential - Check for leaks / level. Add if necessary
Front Axle - check dust seals, ball joints, tie rods
Old November 8th, 2008, 16:51   #6
PlaneCrazy
TDI(s): Gone...
My stealer and my manual both say: visual inspection at 144,000 km (90,000 miles), and if all is well, you can motor on to 160,000 km (100,000 miles) where definitive replacement is required.
Mike
Hers: '17 Golf TSI Sportwagen 5-MT
His: '18 Sportwagen 6-MT 4MOTION
'16 Marinoni Genius/Campy Record, '94 Marinoni Special/Campy Record
PlaneCrazy is offline   Reply With Quote
Old November 9th, 2008, 11:06   #7
volkswagendude
^^^^+1. My manual writes the same.
Regardless of that, I had mine changed at 141000 km (87613 miles), even though visual inspection looked good. Overkill to say the least, but with RC2 and a heavy foot once in a while, it made sense in my world.
volkswagendude is offline   Reply With Quote
Old November 9th, 2008, 14:40   #8
dhuddleson
I have to agree with what you see in the printed manual, however the printed manual cannot dynamically update itself....
I have the DVD eBahn (Bentley) repair manual, and of course it includes the Maintenance Schedules. You get 1 year of electronic updates with the electronic manual, and I checked about once per month for updates and applied them all. The schedules were last updated May 16, 2008, and the 1.9 and the 2.0 PD diesel engine schedules are both revised with Timing Belts replacement (no, not check) at 80K miles (128K kms). Hey, I am not making it up, it's there in black & white. I also recently asked the local dealer when I need to do the Timing Belt, and they also want to do it at the same mileage. So, this is a fairly recent change, and maybe has not been widely published....
Perhaps VW is just erring on the safe side.... even if experience in the field shows that belts look good at over 100K miles.
Ottawa, Ontario, Canada
2012 Jetta Highline TDI sedan
2005 Passat GLS TDI sedan (sold)
2003 Jetta GLS 1.8T wagon (sold)
dhuddleson is offline   Reply With Quote
Old November 9th, 2008, 18:44   #9
johnboy00
If VW changed the interval and didn't inform me, doesn't that make them liable if my belt fails between 80,000 and 100,000 miles?
johnboy00 is offline   Reply With Quote
Old November 10th, 2008, 05:26   #10
leicaman
leicaman's Avatar
Wouldn't that make it a safety drivability issue and thus under the NHTSA control?
Old November 11th, 2008, 20:44   #11
pepitotdi
Default Advice San Antonio TX
My 2005 VW Passat gls TDI is 90k and needs its timing belt to be replaced. I quote the local VW shop and they are asking for a handsome ammount of money for timing belt change. Is anyone aware of a good VW garage here in San Antonio TX, that will do the same for a more sensible ammount??
Antonio
pepitotdi is offline   Reply With Quote
Old November 12th, 2008, 04:04   #12
oilhammer
oilhammer's Avatar
Antonio
Not sure what you mean by sensible amount, but in addition to the nearly $900 worth of timing belt you need, you should also read this thread:
http://forums.tdiclub.com/showthread.php?t=223941
The timing belt kit at our shop retails for about $350, the labor is 5 hours, plus $25 worth of coolant.
oilhammer
Old November 12th, 2008, 05:32   #13
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Todd Herman at www.dieseltoyz.com is good with the older engines... I don't know if he's up to date on the later ones, but it doesn't hurt to ask... 210--683--9663
Read what's in Oilhammer's link... (and you could point Todd to it as well...)
Yuri.
ymz is online now   Reply With Quote
Old November 16th, 2008, 21:08   #14
Smokerr
Fuel Economy: 43.5/32/28
Manuals says 100k (US) and I will start planning when at 90 based on time of year, use patterns, and how it works out for us (basically not to get caught out going past about 98k).
VW has to notify if that changes and I suspect like the oil, not all reps know or are looking in the right place. The new belts are new and improved.
I have seen some of that at work (we use the same type belt on conveyor drives). The old ones are being replaced by new ones that are 1/3 the width. Technology does change. In this case they went to carbon fiber material, and that's incredibly strong (its the same stuff they are making the new Boeing 786 fuselage and wings out of).
2005 Passat TDI Wagon
Smokerr is offline   Reply With Quote
Old November 16th, 2008, 21:08   #15
Smokerr
Page generated in 0.15493 seconds with 9 queries
[Output: 127.14 Kb. compressed to 105.79 Kb. by saving 21.35 Kb. (16.79%)]
