| VW MKV-A5 Golf/Jettas Discussions area for A5/MkV Jetta/Golf (2005/2006 PD and 2009 CR). |
November 6th, 2008, 18:48
#1
Air filter / pre filter / bypass question...
Ok, the trouble with doing (simple) maintenance on the car with you lot for help is a lot of in-and-out with greasy hands and no patience to search for answers.
So I think I found part of what I was looking for, but it's too late 'cause I took the pictures already.
First two pictures: is this the "prefilter" I see some of you writing about (the dirty fuzzy layer on the old filter on the left). If so, it appears I can continue using the pink filter on the right here in the mild SF bay area, yes?
Good...
New filter 1K0 129 620 D on the left and 620 E on the right.
No pre-filter vs. pre-filter?
Next question...
What's up with this air filter bypass? And why is it open?
It appears that vacuum should close it, maybe? It also appears that it feeds something other than the engine?
BUT... it also looks as though it can feed the engine air, as well: through the bypass and up, and it goes right into the port with all the filtered air.
So what the purpose and the operation behind this crafty device?
November 6th, 2008, 19:24
#2
Fuel Economy: 42 avg. 47 max
The flap you are talking about opens when it is cold out. This is supposed to draw air off of the exhaust manifold and help the car warm up quicker. If it is staying open then you have an issue with it.
There have been a couple post on here about a fix for these.
_-Airwolf-_
2006 Jetta TDI Shadow Blue Manual
RC1+, minor vag-com tweaks,ScanGauge II, Newsouth Preformance Indigo EGT/Boost/Oil Temp gauges in a offset dash pod
2008 Honda Fit Blaze Orange Metallic Auto
TDIFest2009 Organizer!
November 9th, 2008, 05:18
#3
Yes, you can definitely continue using the "D" version of the filter. The "E" version is only for cold climates.
'06 Jetta TDI Sport Edition Pkg2/DSG.
114,900 mi. since April 29, 2006. And counting...
November 10th, 2008, 08:30
#4
Thanks, fellas.
Reading through previous posts, it seems that this door should have been closed when I was digging around in there, changing filters. It had to have been at least 65° that morning.
Considering everything else in this car is tied in to the computer, should I see a warning message if the door operation malfunctions?
Is the extra soot / particulate on the last third of the filter noteworthy? That is to say, does it indicate that side of the filter is being used too often?
Am I correct that this bypass allows unfiltered air into the intake?
Thanks again.
November 10th, 2008, 08:41
#5
Fuel Economy: AVG 38.1 MPG lifetime, Best tank 49.3 mpg so far (40k miles)
No it does not let unfiltered air in to the intake. It simply pulls the hot air off the exhaust manifold, then filters it through the filter and into the intake.
I don't know why your filter is so dirty. Maybe you drive in a dusty or construction filled area?
November 10th, 2008, 10:12
#6
Dunno... first air filter change by me, at 44K. We bought the car used in February with "normal" looking VW Dealer service intervals, so I (*cough*) assumed (*cough*) we were in good shape.
Who knows, they might have only been oil & filter changes — this may very well be the car's original air filter.
December 5th, 2008, 19:39
#7
Fuel Economy: 39.5 city / 49 hwy
is there any video or step by step guide in changing your air cleaner filter element around here?
Lovin' my PD!
2004 Jetta Wagon GLS TDI PD | Made 10/03 | Mine 01/04 | Ref Silver/Grey Interior | Ave 39 mpg mostly city/ some hwy | Now over 34.6K miles | New Houston 16s | Cold Wther Pkg | VW iPod Adapter | Thule Rack | Wind Deflector | Gorilla Cargo System | Motorola T305 | Nuvi680 (never left in the wagon)
December 6th, 2008, 04:41
#8
It's been a while since I messed with my car, but IIRC airflow is from the underside upwards, hence the little bypass is filtered. I'd imagine the large amount of black stuff on the filter (on the bypass side at least) is because of the area the air is coming from, i.e. under the hood not from airflow hitting the front of the car. The filter really isn't that dirty on a second look. Also, isn't the service interval for the air filter 40k miles? You're good without the prefilter, you have to have quite a bit of snow to waterlog the filter methinks.
Edit- Changing the air filter- remove the screws holding the top of the airbox on (11 if I remember, but not sure)... they all face upwards and are on all sides of the box. Remove the top of the box, do your best to prevent any dirt from entering the clean side of the box or intake (not hard since it faces downwards). Remove the filter. Insert the new filter. Put the top back on, tighten the screws back down (I don't have the torque spec... I would guess 'snug' would do it). I've seen it recommended on here not to open the filter box until you want to change it in order to not mess up the seal, i.e. don't check to see if it's dirty. I don't know if it's solid advice, but I don't mess with it.
Join the "I drive a TDI" Group on Facebook!
2006 Jetta TDI, DSG, Pkg 1, DG Skidplate.
December 6th, 2008, 05:17
#9
My maintenance includes vacuuming leaves and dirt out of the bottom of the filter housing. Don't blow the crud out as you might just blow it somewhere it is not supposed to go like the top of the air filter housing.
2003 Jetta wagon GLS, 5 Speed, Alligator tune, 34 psi tire pressure, 49.1 US mpg first 35k, 50 next 31.5k, 50.4 next 36k miles, cleaned intake twice and polished end runners last time, Mobil Truck & SUV or Delvac. Koni FSDs, VWs since 1977. Sprint 520 Nozzles for Christmas 2007. Ecodes with fogs and Eswitch. 261,000 miles and counting.
December 6th, 2008, 09:57
#10
I just changed my air filter yesterday (during my 100K service)and it looked identical...I also had the door stuck open and we used shims to keep it closed...(my friend the ex-marine diesel tank mechanic says the the hotter the intake air the better it runs and that I should have left the door in the open position to allow hot air off the manifold all the time)by the way that door is not a replacable part according to VW you have to replace the entire airbox assembly ( almost $200)
2005.5 Jetta, package 2, RC 1+, DG Bypass Oil Filter,Metalnerd Magnetic Oil Plug
2003 Jetta GLS ALH, EGR/Cat efficiency mod,coolant migration mod, ventectomy, snowscreen delete, glovebox door and center console hinge delete
"When the people fear the Government that is tyranny; when the Government fears the people that is Liberty" -Thomas Jefferson
December 6th, 2008, 10:23
#11
I'm thinking cooler air will be denser and therefore better for intake. However, I mainly wanted to note I like the prefilter cuz it keeps the **** out of the pleats of the filter.
*2006 Jetta TDI, pkg. 0, campanella white, 111K miles, best 731.2 mi/14.923 gal @ 49 mpg, M1 TDT/D1, PSI Powerbox, VR6 clutch/Sachs 14# SMF conversion
*1994 Chevrolet Z28, 396 stroker, bout 700 hp on spray
*1994 Pontiac Firebird Formula, Gt47-80 turbo, hopefully 1000 hp when I get done
*2004 Jeep Liberty Sport 4X4
July 18th, 2010, 00:15
#12
Fuel Economy: To Date 40.99 Ave. MPG, Best MPG 59.52, Worst MPG 35.24
Air Filter Bypass
Does the Air Filter Bypass have anything to do with the EGR? Does the Air Filter Bypass deliver Exhaust Gases back into the Air Intake System?
I have looked in the 2005-2006 VW Jetta Service Manual and the Air Filter Bypass is not shown in the Intake System Diagram.
July 18th, 2010, 07:19
#13
No, the air filter bypass has NOTHING do to with the EGR. EGR gasses are introduced directly into the intake via the EGR valve and has no filtration on it. Only thing that happens to the EGR gasses is they get 'cooled' by the EGR cooler ;-).
_-Airwolf-_
July 18th, 2010, 21:42
#14
Yes, correct change interval is 40k. And yes, that's an unusually dirty filter, but isn't necessarily a problem. If no performance increase with new filter, then old one was not overly restrictive.
July 19th, 2010, 00:18
#15
Fuel Economy: 49.3, 48, 21.2,19.99
Abarns, I would include one other small detail to your DIY...I have seen the seal get stuck and pinched if they are not placed down in the bottom box..I usually place/push the seal around the entire parameter. So, I would throw in there about checking the seal surface after installing the filter in the bottom airbox-that the seal is down in the seal area...R U enjoying civi life?
I like cool air coming in my filter so I jammed my defective valve shut. I havent seen one yet that was working correctly. They are all partially open at ambient, so I go in there and run a screw in them and preload them, so they are shut..
http://www.rsbdiesel.com/
2006.5 DE DSG, RC2, Sunroof, Rear airbags, 73K miles, 61MPG best.
2005.5 Jetta-5 SP, LSD, Spec S2, 110K, 48 mpg every tank. Best-49.3 mpg-LOCAL. ELF 506 0-30W/15K OCI/37PPM FE, Best=740 MPT, RSB Diesel custom 2.5DP/3" SS exhaust, Synthetic fuel, Koni lowering springs. One of the first Mark V Jettas to hit the street. Pkg 1, MFD, Autowipe, Auto-headlights, Auto-dim mirror, auto-climate. 248C=150HP RC2
2004 6L 89000 19MPG
2000 7.3 388 HP-818 FT lbs Propane
