Old November 6th, 2008, 14:01   #1
gebbeth
TDI(s): 99.5 jetta
Default Clock and Trip Odometer reset problem.
Both the clock and Trip Odometer reset to 12:00 and 0 respectively whenever the ignition is turned off. The main mileage odometer seems ok. Any ideas?
gebbeth is offline   Reply With Quote
Old November 9th, 2008, 08:58   #2
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
__. These items need to have full-time battery power to function correctly. I'm guessing a bad battery, loose connections or grounds, or a bad ignition switch. It's like you're disconnecting the battery every time you switch it off. The main odo is "phantom powered" - otherwise, it would go back to "0" every time you changed the battery.
MrG, Wallace NC (2002 Jetta, Totalled by drunk, 11/'06; 130K mi in 4 1/2 years/~57 MPG lifetime); New car, '03 Jetta Wagon, CAT filter, .681 top gear, 350K mi. in 11 1/2 yr, ~52.
mrGutWrench is offline   Reply With Quote
Page generated in 0.11637 seconds with 9 queries
[Output: 48.75 Kb. compressed to 44.51 Kb. by saving 4.24 Kb. (8.69%)]
