SyntorX9000
Is there a way to prevent coolant migration?
yep! hot paperclip in some pliers, make the hole in the corner of the connector, make sure not to pierce the coolant bottlekack said:this is when the coolant leaks into the level sensor plug then goes down the wiring harness and well you get the idea.
the fix is to make a small hole on the lower side of the plug which allows any possible fluid to drip out.
SyntorX9000, aka, a Motorola Syntor X9000 mobile 2-way radio? HEHE. It seems there are many radio guys on TDIclub. I am one too (N1DAS).SyntorX9000 said:Is there a way to prevent coolant migration?
that i dont know, mine has been steadily falling.hid3 said:Why coolant level might go up so high?
