| VW MKV-A5 Golf/Jettas Discussions area for A5/MkV Jetta/Golf (2005/2006 PD and 2009 CR). |
October 22nd, 2008, 20:52
#1
'09 Shudder problem
Just curious if anyone has had any problems with their jetta having hesitations/hiccups/shuddering.
Like clockwork after I start mine up and drive down the road about 1/2 mile holding the throttle steady it will have a hesitation or almost shudder and jerk then continue on. After this initial shudder it seems to do fine but almost always does it after a startup.
Since this car is manual and my last was dsg I have also noticed that while holding the throttle steady and travelling down hilly roads that when it goes over a hill it almost feels like it is defueling and has a slight shudder there also.
Anyone else having issues like this? I have 4K on it and I figured I would wait until the 5K oil change to bring this all up to the dealer.
'13 Reflex Silver Jetta TDI 6spd
'05 SRT-10 Viper
October 23rd, 2008, 07:46
#2
Yes I have noticed this also. Almost like a we used to call a flat spot. I have not noticed as much lately I'm sitting at 3600 miles.
2000 TDI NB, SMOG .205, B99 250k miles
2006 MINI Cooper S 17% JCW CAI, One Ball
2009 Jetta TDI Platinum Grey, Anthracite, 6speed Man. 87,000 miles
October 23rd, 2008, 10:57
#3
Me too
Yes, I've noticed this as well. (My car is a manual.) I had dealer check it -- he said the computer showed "no faults." At 2400 miles now it is less frequent. I was worried that I had gotten bad fuel.
Not to start another big ruckus, but why a 5K oil change?
Matthew
October 23rd, 2008, 13:17
#4
Matthew
I believe the first oil change is 5K is it not? This is the break-in oil that needs changed.
'05 SRT-10 Viper
October 23rd, 2008, 15:55
#5
I experience something like this, but only on one particular low hill on my commute; as I crest the hill the engine feels like it defuels for just about one second, then comes back up. No shudder, just a smooth hesitation. I finally figgered out how to avoid this: as I crest the hill I make sure not to move the go-pedal at all. My natural instinct is to back off on the go-pedal a little bit, and I suspect that the computer interprets the slight release of the pedal combined with the sudden disappearance of load on the engine (as the hill is crested) as a request to coast (and when it coasts it defuels). Like I say, if I keep from backing off on the pedal I don't experience the problem.
That shudder on start-up that you have, though...that's something I've never experienced.
2009 Jetta TDI (Loyal Edition, Campi White, DSG, #1470, built 5/08): 56K miles and zero problems 1/16/2011.
WeatherTech deflectors, Dieselgeek skid plate (both A+)
My other diesel gets 120 MPG (minutes per gallon): Kubota 2630 w/ FEL
My other other diesel I don't even want to talk about (1995 Dodge Ram 2500 Cummins 4x4)
October 23rd, 2008, 16:45
#6
Experienced
Fuel Economy: 42,with a best of 47
What does your owners manual say? Make sure you are looking at the schedule for the Diesel engine, not the gas ones.
The 06s got the first OC service at 5,000, but I thought they changed the schedule for the 09s to 10,000 miles for the initial OC.
Let us know what you find in the manual!
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
October 23rd, 2008, 20:32
#7
Fuel Economy: avg. 41.93 high 46.32 low 34.6
This shudder, do you feel in the trans or engine or not sure..
October 24th, 2008, 19:32
#8
I guess I expericenced the same thing about 3 times know, basically when I was proceding from a stop sign when I first start the car from sitting all night. I got a 6 speed stick with 4000 kms. But when I drove it off the lot with 25 kms the engine went on and the oxygen sensor had to be replaced. That O2 sensor was changed at 3300 kms and I haven't had the problem since.
October 27th, 2008, 10:41
#9
Happens on my 6-speed as well. Pete
October 27th, 2008, 10:59
#10
Vehicle hesitation
Yeap, I have been having same issue as you are.
Vehicle:
2009 TDI with 5,400 miles
Symptom:
Vehicle shudder / hesitation under light to moderate acceleration for less than a second
Description of symptoms and Discussion:
The hesitation occurs randomly, on cold or fully warmed up engine. When the event happens, it happens on 2nd, 3rd or 4th and 5th gear under light, sometimes moderate acceleration. It does not happen every day; there might be few days in between the occurrences.
During the event, which takes a less than a second, it “feels” like fuel supply is being cut off and then suddenly reinstated, which in turn jolts the vehicle forward.
By all means I’m not an experienced mechanic, but I’m trying to solve the problem before it gets bigger or triggers more problems. From my understanding, the IP is TB driven, so IP going bad is not an issue? Or is it? Lift pumps seems to be working; every time I turn the ignition on, I hear the lift pump.
Can this hesitation be caused by the exhaust system EGR valve? I have read posts that indicate that there is a valve in the exhaust system that opens/closes during the regen?
The fuel I have been getting is either from Hess or Sunoco, and the current “tank” is Shell.
Additionally, no “dash” warning lights are on nor were on. I presume that one step I could do is to perform scan for fault codes.
Obviously, diagnosing this problem will be hard due to its random occurrences.
Hella HID projector headlights, projector fog lights, highline ECM, Euro light switch, LED tail lights with amber turn signals, rear fog light, LED side markers, LED interior lights.
October 27th, 2008, 11:03
#11
it feels more like an engine hesitation
October 27th, 2008, 13:07
#12
09 JSW, manual, has about 4k miles and I noticed it about the 3rd time i drove it(it's my wife's) My wife has not said anything, it doesn't surprise me, and i notice the "hiccup" usually on 3rd gear at a steady pedal pressure.no problems at high speeds down I-20 at 80MPH. I too will mention it to VW on service date.
"SUICIDE CHARLEY"
1stBN 7th MARINES 86'-90'
San Diego Rock & Roll Marathon(x2)
Dallas Marathon
Chicago Marathon
Phoenix Rock & Roll Marathon
Marine Corps Marathon
1943 Ford GPW
90' 3500 Dodge Ram CUMMINS 5-speed manual
93' 3500 Dodge Ram CUMMINS 5-speed manual
94' 3500 Dodge Ram CUMMINS 5-speed manual
02' 2500 Dodge Ram CUMMINS 6-speed 4X4
09' JSW; Pano-roof; Silver & manual
October 27th, 2008, 15:47
#13
EGR cycling?
Reminds me of my passat before the reflash.
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 17" (CC) Spas, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, premature cam wear?  now driven only once or twice a week
2012 Kia Optima SX turbo, 274 hp, 269 ft-lb @ 1750-4500 rpm, corsa blue, new daily driver
October 27th, 2008, 17:47
#14
Matthew
It is definitely 10K, and the dealer will not perform a no charge warranty oil change unless you're within a 1000 mile window on either side of 10K.
There IS NO BREAK IN OIL... VW hasn't used break in oil in years according to my highly experienced VW dealer. (Mechanics have been there over 25 years).
I too have noticed that "drop out" a couple of times. I thought it was related to the incline / decline sensor, but some of you are reporting this in the manual version - so that shoots that theory.
To me it feels like the car just loses all power for a brief moment. Upon applying pedal it responds as usual, wouldn't you agree?
Wes
09 Jetta TDI, Campanella White, DSG Loyal
Aurora, OH
Mileage 42.5 to 50 mpg (when I REALLY try)
October 27th, 2008, 17:56
#15
Wes
I just keep the "go pedal" pressed and wait the split second for a sling shot....
