Old October 3rd, 2008, 19:51   #1
subsams
Default Vibration/Shudder when under a load
My 01 Jetta has 81,500 mi. A few days ago it started making a shudder/vibration when under a load, it seems worse going up hills and at 1/2 to full throttle its not real noticeable yet just a bit annoying right now. I would like to get it fixed before it gets worse. I have read a lot of post about similar problems but have not seen very many solutions any help
subsams is offline   Reply With Quote
Old October 4th, 2008, 07:57   #2
Souzafone
Souzafone's Avatar
Fuel Economy: Worst 43+ Best 56.1 Avg. 45-46
Get the car to someone experienced with TDI's, you don't want to wast time and money with a parts replacer or some educated guessing, do you? That said, I had a similar issue, turned out to be a loosey DMF. It never got worse, but meant using higher rpm than I sometimes wanted to.
"I did choose to work for this car brand because their German Engineer does not follow and this cars are unique in designed."
“Your lack of Oink Oink shows that you are Dazed and Confused as the biggest content in your reply, I had authored .”
99.5 Jetta, whitish.
Souzafone is offline   Reply With Quote
Old October 6th, 2008, 09:41   #3
jettawreck
jettawreck's Avatar
Also have engine mounts checked, especially the engine/transaxle "dogbone" mount.
2004 Cadillac SLS (wife's)
Old October 6th, 2008, 13:27   #4
dieselvet
Possible inner constant velocity joint problem. I had the same symptoms with my 2002 Jetta. Rebuilding inner cv joints fixed the problem.
10 Mercedes E350 4Matic, stock for now
14 Mercedes GLK 250 4Matic Bluetec, stock for now
dieselvet is offline   Reply With Quote
Old October 11th, 2008, 17:44   #5
shufy
Fuel Economy: 40 avg
Hi Subsams,
I had what sound like a similar situation. I have a 2004 Passat TDi Wagon and when I would try to step down on the throttle past about half way, the car would shutter, the more I stepped down on the throttle, the worst it would get, almost like the transmission was slipping. It ended up being the fuel filter, which only had about 30K miles on it. Now when the car starts to shutter, its time to chage out the filter.
shufy is offline   Reply With Quote
Old October 11th, 2008, 19:01   #6
Canadian_Grizzly
Canadian_Grizzly's Avatar
TDI(s): 02 Jetta TDI
Sounds like inner CV's unless you just had a timing belt change, then I would suspect engine mounts.
Byron
Driver Found!
"There is lots of work to be done, if we are to achieve the kind of society people have the right to expect." Tommy Douglas
Having trouble with limp mode... Troubleshooting Low Power
Having trouble searching? Read this thread on advance search in forum http://forums.tdiclub.com/showthread.php?t=133579
Canadian_Grizzly is offline   Reply With Quote
Old October 13th, 2008, 06:28   #7
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Dmf....
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old October 13th, 2008, 10:50   #8
Hamman
Hamman's Avatar
I've had the same problem, but it only showed up after I the car was chipped and nozzled. If it's the DMF, then a clutch upgrade would help.
However, that's not going to happen as long as the original is okay.
2016 Golf SE TSI
2016 Tiguan 2.0 TSI 4motion
1984 Rabbit 1.6D (no emissions )
Hamman is offline   Reply With Quote
Old October 13th, 2008, 12:50   #9
jasonTDI
jasonTDI's Avatar
huh? I've seen a lot of stock car horrendously fail DMF's.
Old October 13th, 2008, 12:52   #10
Antsrcool
Antsrcool's Avatar
mine does htis but ive narrowed it down to a slippin TCC. Its the only thing left feels like im driving over a washboard. Its done it for about 40k miles now and i knwo how to drive it so its not really there
Antsrcool is offline   Reply With Quote
Old October 15th, 2008, 05:50   #11
LNXGUY
LNXGUY's Avatar
Could be a wheel bearing, tierod, balljoint or even a bad CV joint.
I doubt it's the DMF. '01s weren't know to have DMF's that flew apart.
Bill
LNXGUY is offline   Reply With Quote
Page generated in 0.15131 seconds with 9 queries
[Output: 98.25 Kb. compressed to 82.26 Kb. by saving 15.99 Kb. (16.27%)]
