S
SkyPup
Guest
This summer, Ford takes what will arguably be its most significant step yet into the world of diesel technology , with a new common-rail engine. It has been developed
at Ford's Center for Diesel Excellence in Dagenham, Essex, UK, under the stewardship of Phill.Lake, diesel chief engineer, Ford Europe.
The new 1.8-liter engine is actually badged 'Ford Duratorq TDCi', and will be followed by a 2-liter version in the Mondeo later on. Output is 115bhp at 3,800rpm and 250Nm at 1,850rpm, but there's also a transient overboost function delivering 280Nm during hard acceleration. The engine meets Euro III and produces CO2 at the rate of 145g/km. Apart from greatly improved refinement over the existing 90bhp TDDi engine, the unit's power output is 30 per cent higher for about the same fuel consumption which, on the combined cycle, is homologated at 5,5UlOOkm C51.4mpg).
The TDCi delivers a clear message to other diesel manufacturers: Ford is now backing diesels in a big way, though some might say not before time. Some may also say that by the late 19905, Ford had finally woken up to the fact that the latest direct-injection light-duty diesel engines coming out of Europe were going to be a force to be reckoned with, and that common rail was a bandwagon it could not afford to miss.
Whether Ford's tardiness into what will certainly prove to be a lucrative race is due to Detroit's lack of enthusiasm for diesels in general, or Ford Europe's official line that first-generation common rail lacked enough sophistication to be worthwhile, is likely to remain a mystery. Lake certainly advocates the latter point of view and thinks. "the disadvantages over first-generation common rail outweighed the advantages." Certainly, Ford and Renault have become the first companies to offer the latest common-rail system on their engines. Originally developed by Lucas prior to its acquisition by Delphi, the system features an unusual disc- shaped rail from which the injector feed- pipes emanate, and that has a built-in pressure sensor.
The pump is a crucial aspect of any common-rail system, and delivering high pressure has proved to be one of the major focal points for designers. Lake is cagey about discussing pressures, arguing that the value you arrive at is dependent on where in the system the measurement was taken. Nevertheless, he offers a figure of 1,600 bar at the pump.
TDCi is also equipped with a piezo electric knock sensor of the type used in gasoline engines, fitted to the block between cylinders two and three. According to Lake, the sensor's job is to detect any conbustion harshness by measuring the "signature of the combustion event". When this event occurs, the sensor signals the IDM and EEC-V modules, which then modify the injection process to smooth out any unwanted peaks of high pressure. Ford calls this function 'accelerometer pilot control' and it is one of several key features of the TDCi engine.
Another feature lies in the strategy for maintaining integrity during ageing. The injectors are given what Ford calls 'individual injector characterization' by a matrix code assigned during manufacture. Each code is scanned and programmed into the ECU, customizing the injection pulse timing and duration on a cylinder- by-cylinder basis. More importantly, the system allows each injector to be individually and continually re-calibrated, overcoming any problems caused by wear as they age.
The bottom line though, is that the precisely-metered multiple-pilot and single-post injections enable the TDCi to avoid sharp rises in cylinder pressure that cause the clattering noise. Frank Foehner of Ford's NVH center in Cologne thinks such control is a real achievement and
says it will allow NVH engineers to achieve impressive linearity of sound versus increasing engine speed and load.
As for the basic engine itself, changes have been made compared to the TDDi. The cast-iron block has further stiffening, and the piston, the larger bowl, the connecting rod, and main bearings are more robust. The head is cast iron, and there are just two valves per cylinder , despite the slim, 17mm diameter, injectors designed to accommodate a four-valve per cylinder configuration.
The swirl ports in the head have been modified compared to the TO predecessor, but apart from that, the real difference is the addition of external holes on which to mount the rail. A Garret variable-nozzle turbocharger reflects the current state of play in advanced diesels, and does away with the need for a wastegate altogether . electronically: controlled throttle also shuts completely at key-off to avoid the running-on that sometimes occurs in diesels.
On the road, TDCi is something revelation and, despite several years becoming used to the sophistication of the common-rail systems, this one comes across as extremely smooth and quick indeed. The unit also delivers serious performance thanks to the over-torque feature that belies the engine's rated output. Its 280Nm is substantially more than the 2.7 -liter PorscheBoxster can muster, and knocks on the door of the Boxster S. So despite the family car j of zero to 100km/h (62mph) in 10.i seconds and a top speed of 192km/l (120mph), the overtaking and cross. country performance of the lusty diesel border on dazzling.
The TDCi goes on sale in the summer and should be regarded as one of a succession of developments about to emanate from Ford. According to Lake; "There are no less than 30 diesel developments at Dunton and Dagenham and we are focused on becoming the leaders in diesel technology." It's a bold statement that competitors who have in the common-rail business far long may have even been considered arrogant a year or so ago.
But the TDCi and Ford's collaboraboration with Peugeot should silence any such criticism. Ford is in for the duration, it believes in common rail. Lake just sums that up when he says; "I think that every future diesel in the industry will one day use common rail." He may well be right. Despite major players such as VW-AUDI siding with the alternative of pump injection, even the latest examples of that technology lack the refinement of this new oil-buner from Ford. The TDCi may be a considerable achievement it's own right, but the implication for much larger-scale production is perhaps eve greater. The cost of common-rail has always been high, but now that customers can buy the technology more cheaply than ever before, the floodgates must surely open.
