TDIFest 2013 Registration is now open!
Old September 21st, 2008, 22:56   #1
ibanix
ibanix's Avatar
Fuel Economy: ~45mpg
Default P0673
I get this CEL every so often. Clear it with ScanGuage and it comes back a few weeks to months later.
VAG-COM says it's an intermittent electrical failure on Glow Plug #3. Does anyone have advice for how to diagnose this?
Thanks!
2003 Jetta TDI GLS, 100k miles - 17/22, PP502s, 11mm FIP, AXR intake manifold, EGR+cooler delete, S/T race pipe, drill-less EGT probe, TheTDIWagonGuy CCV filter, NewSouth DualPod w/ VDO Boost, VDO EGT, Hella Supertones, Eurojet SMIC, Boostvalve, DC Clutch IV+, Koni Reds, Poly control arm bushings, ScanGuage II, Carter lift pump, 5.5L coolant bottle, R32 snorkle/lower, 2.5" OMI, 3 bar map, TDIparts 2.5" DP and straight exhaust. New transmission! 164HP dyno
ibanix is offline   Reply With Quote
Old September 22nd, 2008, 02:44   #2
2004STARWARSTDI
2004STARWARSTDI's Avatar
Post P0673
Glow plugs 101 ***Ver. 2.0*** - TDIClub Forums
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2011
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Page generated in 0.07988 seconds with 9 queries
[Output: 48.24 Kb. compressed to 44.14 Kb. by saving 4.10 Kb. (8.50%)]
