Old September 5th, 2008, 18:36   #1
pedrodiesel
Fuel Economy: 50 m.p.g.
Default Golf Gl 2004 manual timing belt replacement
I recently purchase a 2004 TDI manual, has 92000 miles.
Do I need to replaced the timing belt?
What does A4 means? I see that often in different discussions.
I am not familiar with VW plataform or engineering.
I also read that 2004 model has two different diesel engines it is truth?
What belt brand will you recomend? do I need to change something else besides the belt?
Pedrodiesel
pedrodiesel is offline   Reply With Quote
Old September 6th, 2008, 03:15   #2
2004STARWARSTDI
2004STARWARSTDI's Avatar
Post Timing Belt
Timing belt done at 100K. So you are close to it. Golf had ALH engine or BEW for that year. Different timing belt kits. Yes, you need the deluxe TB Kit. You need a TDI Guru to do it for you. Not something you would want to try on your own. Deluxe kits are sold by:
www.dieselgeek.com Storefront
TDIParts.com - Shop TDI Parts, VW Parts, Diesel Engine Parts, Volkswagen Performance & Aftermarket Parts, Lubricants, Fluids,...
World Impex, Inc.
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old September 6th, 2008, 05:24   #3
HopefulFred
HopefulFred's Avatar
Fuel Economy: ~39 USMPG
"A" refers to the platform used for the Golf, Jetta, and New Beetle. "4" refers to the fourth generation.
Novice VCDS user.
Proud owner and successful two-time user of AST timing belt tool kit.
HopefulFred is offline   Reply With Quote
Old September 6th, 2008, 06:43   #4
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Look up KROUT in the search function. He's in Jacksonville. A bit of a drive but it's worth it to get it fixed RIGHT. You're good to 100K miles.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old September 6th, 2008, 18:57   #5
pedrodiesel
Question MIL lamp on
Hello guys, thnaks for your answers.
My recently adquired TDI Golf gl 2004, 92000 miles has the MIL lamp on.
Previous owner told me it may need to injectors, car runs fine.
p.s.: ( I started to get familiar with my Diesel (never owned a diesel before )
I Think i will to enjoy the car because:
1. it is a Diesel
2 and manual transmission.
3. It is german design what do yu think?
Old September 6th, 2008, 18:57   #6
TornadoRed
TornadoRed's Avatar
Pedrodiesel
The timing belt is due for replacement at any time, but not later than 100k miles.
Visit www.dieselgeek.com and look at the parts in their deluxe TB kit for your model/year. Those at the parts that need to be replaced: TB, tensioner, rollers, waterpump, single-use bolts, and the serpentine belt. The DG kit has a few extras. Other TDIClub vendors sell similar kits, these include www.metalmanparts.com, www.tdiparts.com, www.boraparts.com, and a handful of others. They all sell kits with good parts, differing mainly in which brand of waterpump they include.
I strongly recommend that you do NOT allow a VW dealership to do this work for you, not let some local mechanic without TDI experience practice on your engine. You will save money and probably get better workmanship by having a TDIClub "guru" install the kit for you. Krout in Jacksonville is one of them, but there may be others.
There were two different TDI engines in 2004: a 2.0-liter engine in the Passats, and a 1.9-liter engine in everything else.
'03 Golf with 693k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilsteins, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Nokian snows, TDT/Delvac1
TDI Trusted Mechanics by jwlionking TDI Search Engine https://cse.google.com/cse/publicurl...44:_idbzjdyxdm
Page generated in 0.12748 seconds with 9 queries
[Output: 73.88 Kb. compressed to 64.54 Kb. by saving 9.34 Kb. (12.64%)]
