Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2008
TDIFest 2008 Discussion about TDIFest 2008 that was held in Mason, OH on the Labour Day weekend (August 29th - August 31st, 2008) .
Old August 31st, 2008, 17:51   #1
mcolmsted
Default In desperate need of help in Columbus, OH
At the recommendation of someone on the mid-west forum, I'm posting here. Anyone coming back through who can help???
We were up this weekend for a vintage base ball festival and are supposed to be leaving tomorrow. However, as we were attempting to leave the festival today, our 03 VW Jetta wagon refused to start. It won't turn over, etc. We know there is an error code being thrown of P0228. According to Autozone, this is the throttle position sensor.
Is there anyone who can tell me what this is, how it can be fixed, and if there is anyway to get it fixed in order for us to drive home to St Louis tomorrow?
If not, the plan is to rent a Uhaul trailer and have a friend tow our car back tomorrow. It's going to be a tight fit for all of us in his truck, though, so we'd prefer to get it fixed if at all possible. Any and all help is MUCH appreciated!!
Courtney
2003 TDI Jetta wagon
143K and counting
mcolmsted is offline   Reply With Quote
Old August 31st, 2008, 21:29   #2
Haiku TDI
Haiku TDI's Avatar
While I can't be of much help in terms of fixing the car -- I'm in no way skilled enough nor do I know enough about the throttle position sensor -- I am in Columbus, OH if you need a place to gather people and parts and knowledge.
Hope all gets fixed for you soon.
Haiku TDI is offline   Reply With Quote
Old August 31st, 2008, 21:38   #3
paramedick
paramedick's Avatar
Courtney, it may very well be a TPS. However, please confirm that you have checked the antishudder valve to ensure that it is not stuck closed.
http://forums.tdiclub.com/showthread...ighlight=start
Old September 1st, 2008, 05:23   #4
mcolmsted
Thanks for the link. Unfortunately or fortunately, that doesn't sound like the problem. The car won't start at all--it actually doesn't do anything. When the key is in the off position, the clock and odometer are on. As soon as you turn the key, everything turns off and the engine does nothing. When the car was hooked up to another battery (jumping it), when the key was turned the dash lights (CEL, etc.) did come on and the engine did click a couple of times. Other than that, nothing.
MOGolf (bless the man--hasn't he driven enough this weekend?!) drove over at 7:30 this morning to check it out. His initial assessment is the battery so the guys are headed to buy a new battery and see if that works. Thanks for the suggestions!
Courtney
143K and counting
Old September 1st, 2008, 05:40   #5
Growler
Got Soot Vendor
Growler's Avatar
Hooray for MoGolf! He drove back & Forth all weekend to fest..
Deserves a Medal! SOlid gold as big as his heart!
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old September 1st, 2008, 06:53   #6
mcolmsted
Thanks to MOGolf, the car is up and running with a new battery. We are very grateful!!
143K and counting
Old September 1st, 2008, 12:31   #7
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
GREAT!
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old September 1st, 2008, 18:12   #8
DCELL
DCELL's Avatar
Fuel Economy: 44mpg ave
Thanks to MOGolf for helping me out this weekend too... Left my Vagcom at home and tripped a CEL on the way to the fest. he hooked me up!
MCCOLMSTED- Glad to hear you got going ok. I've never had much luck jumping a TDI either.
TDI service work available on a limited weekend basis. Timing belts, maintenance, etc. PM me with your needs!
When opportunity knocks, and I'm not home, opportunity waits.
DCELL is offline   Reply With Quote
Old September 1st, 2008, 19:34   #9
MOGolf
MOGolf's Avatar
You're welcome Courtney. Let us know that you got home safely.
I understand that you and the hubby won't be at Old Navy's GTG this year. Enjoy your other plans.
Removed the battery and checked for corroded grounds. Examined connections at starter and back of alternator. No problems found.
Hooked up VAG-COM and found the system reporting 9.xx low voltage. Probably a dead cell.
I offered to take the battery home and try to properly charge it, but the decision was made to try a new battery.
Looked in my TomTom for the nearest place. Autozone came up with its phone number.
We called them. They had a couple of 94R batteries.
Went there with the old battery. Looked identical to the replacement except the replacement doesn't have the useless green indicator, nor tape over the caps.
Went back with the new battery and installed it.
Car started right up.
Rechecked with VAG-COM and system voltage was 14.2x. Revved the engine up a few RPMs and the generator load readings and voltage indicated the alternator was working properly.
We had a chuckle that the Autozone computer listed the battery replacement as "labor intensive". Based on that, we wonder what they'd list for a timing belt. It took them longer to actually find the battery than for me to remove the old one.
The TPS code was probably a false code due to low voltage. It did not return while I was there. There was also an engine start blocked by immobilizer code. Both cleared after the replacement battery was in.
MOGolf is offline   Reply With Quote
Old September 1st, 2008, 19:42   #10
TDITONY
Fuel Economy: 54.6/48/38
MOGolf you freaking RULE. Thanks for the quick mod on the windows and coming through for a member in need.
Tony B
TDITONY is offline   Reply With Quote
Old September 1st, 2008, 19:47   #11
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
I suppose they would also think that replacing the back bank of plugs on an air cooled vw motor to be labor intensive too! Ha!
2015 Golf SE TDI with DSG, 61k.
2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is offline   Reply With Quote
Old September 2nd, 2008, 18:29   #12
MOGolf
MOGolf's Avatar
I talked to mcolmsted. They all made it home safely with no further problems.
Old September 2nd, 2008, 20:33   #13
mcolmsted
Thanks again to MOGolf for his great help!! It's amazing (and frustrating) that something as simple as the battery had us completely stranded because we had no good way to diagnose it. Makes me think I need to get a VAG-COM . But then I wouldn't get to watch the generosity of club members like MOGolf, who saved the day with his willingness to help.
Thanks again to everyone who offered help and suggestions, and most importantly to MOGolf who got us back on the road!!
143K and counting
Old September 4th, 2008, 09:31   #14
Windjammer
TDI(s): MK4 & Mk5
This is the load tester that you need to test the battery. You can get one for $25 - $50.
00 Jetta TDI GLS Auto Black w/Beige leather, Phatbox
06 Jetta TDI Shadow Blue w/Beige Pkg 2 DSG W/NAV & Phatbox
06 Jetta TDI Blue Graphite w/Grey Pkg 2 DSG W/NAV & Ipod dock
06 Jetta TDI White w/Beige Pkg 2 DSG
06 Jetta TDI Black w/Beige Pkg 0 5MT
Windjammer is offline   Reply With Quote
Old September 4th, 2008, 10:00   #15
Mark of Diesel
Q. So how many miles DID you put on the Passat this last weekend Glen? You are the Master!
An object at rest cannot be stopped!
Mark of Diesel is offline   Reply With Quote
Page generated in 0.17747 seconds with 9 queries
[Output: 123.58 Kb. compressed to 102.19 Kb. by saving 21.39 Kb. (17.31%)]
