Trooper81
Has anyone had this happen yet? If so what happened?
That's where the H2S catalyst as the last part of the exhaust aftertreatment is there to deal with.GoFaster said:On a much less frequent basis occurs a de-sulfurization of the de-NOx catalyst. I would expect that this is going to make the exhaust stink like sulfur for a few minutes.
Göbel et al. Diesel NOx-Aftertreatment Systems for North America. 29. Internationales Wiener Motorensymposium 2008.The design of the exhaust line for the Volkswagen application is depicted in Figure 2. A diesel particulate filter (DPF) with a small upstream catalyst is located close to the engine. Both devices share the same canning. The important NOx-reduction device is located in underfloor position followed by a small catalyst which eliminates secondary emissions,
such as H2S which can be formed over the underfloor LNT during desulfation events.
internationals we have at workjvc said:Trooper 81
What truck engine are you referring to?
John
Wow!Drivbiwire said:
TDI exhaust system for T2B5
DB
Has anyone looked at the warranty coverage on any of this? What does it read like?Drivbiwire said:
DB
"Restrictive" is a buzz word used by aftermarket exhaust peddlers, nothing more. Real engineers have things under control.Revolutionary_mind said:is it me or does that look like a big restrictive mess.
Blush my ass, in the test cell with the 140hp/liter Diesel BMW you grew horns and developed an evil grunt like Dr. Frankenstien!TDIMeister said:As an engineer, I blush.
Not shown in the system picture is that it is put together using V-band clamps. The valve assembly in my estimation would be a 5 minute swap out (if you REALLY took your time). Sensors are no more unreiable than the O2 sensors in the BEW and BRM TDI's...when was the last time those went bad?invader said:Wow!
I wonder how much it will cost when something in that system goes bad. Say, like a sensor or something, and god forbid that exhaust valve should take a crap.
That's assuming someone will be able to fix it?(dealer)
I'll dig my owner's manual out again, but I think it's actually LESS that the total cars 36/36.. I believe it is two years.weedeater said:I would like to hope the emissions warranty is 7 years. It always has been.
I ran some numbers once... the power-to-weight ratio of the average bus at work is such that to be matched in a car, your Jetta TDI would need to be powered by a humble 28 horsepower diesel.GoFaster said:trouble with passive regen is that it depends on driving patterns. The DPF retrofit kits that were put into effect for European consumption were passive regen only, and if you didn't at least occasionally drive the car hard enough and for long enough to initiate a regen, they would clog.
Trucks tend to be relatively underpowered relative to cars (take a look at the power to weight ratio!) so the engine has to work harder, relatively speaking.
