TDikook
I have a PD 150 Turbo inlet pipe(TIP) and I was curious what could be done to help the fact that the TIP is made of aluminum and runs very close to the exhaust manifold, and after a bit of driving around that pipe(TIP) can get very hot, which cannot bo good for the air going into the turbo being compressed. cooler air in is better.
I bought some exhaust wrap and some silicone heat spray: http://www.designengineering.com/products.asp?m=sc&cid=3
I got them from Advanced Auto Parts, but almost all auto parts had them.
I painted the TIP with a few coats, then wrapped the TIP with the header wrap. it is a long job, waiting for paint to dry and the wrap to dry(it suggests soaking it in water before wrapping, and that is a highly recommended step by me) I put it in the oven and baked it dry as I was kinda in a hurry.
anyway, initial indicatiuons of the project seems very favorable. I cannot get my IAT(ait intake temp) as per scangauge above 165*F and I have had a few WOT runs to see how high it will go. I have hit 180*F on an uphill offramp but that was only once. I was able to routinely hit 180-200*F before doing this. so the initial observations says this is a worthwhile project to do if you have a metal TIP.
I know I need an intercooler, but I am having issues getting it installed, so it is sitting in my trunk till I can figure it out.
Eric B
Eric B
