Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2008
TDIFest 2008 Discussion about TDIFest 2008 that was held in Mason, OH on the Labour Day weekend (August 29th - August 31st, 2008) .
Old August 25th, 2008, 13:59   #1
blizzak
Default Compression test @ the fest?
Hey guys,
I was wondering if anyone at the fest would be able to help me with a compression test. As shown in my signature, mine is a 97' Jetta 1Z. I guess I could go and borrow one from a local auto parts shop and do it myself, but I don't imagine I will have the time before the fest anyways.
As far as I have read, you need:
Compression tester
Battery Charger (I have a trickle charger, not sure if that would supply sufficient power though)
VAG-COM to clear codes
wrenches, etc
I can crack open the glow plugs and re-tighten them before heading to the fest just to be sure they won't be frozen. If someone doesn't feel they need to watch over me then if I could just borrow someone's tester for a bit at the fest I would be happy. But I wouldn't mind one of the many gurus helping me out and giving me insight during the process.
TIA,
Blake
Blake | Custom alignments available in Southwest GTA
2004 Grey TDI Sport Edition | 270,000 km | Grey | 6 speed ERF transmission with upgraded shifter fork & LSD | R32 18 Aristos | PP Downpipe, 2.5 SS exhaust with Magnaflow muffler, rest of mods in profile
Whitedog's no start thread - very useful!
blizzak is offline   Reply With Quote
Old August 25th, 2008, 15:27   #2
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
It's not a good idea to take your car apart so far from home. Snap off a glowplug or strip one of the holes, and life's gonna suck.
Trusted TDI Mechanics Map || TDIClub Chat
Old August 26th, 2008, 13:25   #3
blizzak
I suppose that's true...that's why I was going to make sure they weren't frozen before heading out. Life would suck either way if one of those things happened.
Ah well, maybe I will just borrow one locally and do it here then...unless someone can assure me that nothing'll go wrong at the fest
Old August 26th, 2008, 14:03   #4
compu_85
Gadget Guy
compu_85's Avatar
On your car the injection pump has to be de-timed to take out the #2 injector (on the IDI's you remove the injectors to do the compression test). I would really save this test for home.
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old August 26th, 2008, 14:20   #5
blizzak
IDI? Mine isn't an IDI, and the bentley article for this clearly states (for 1Z, AHU):
Compression, checking (engine codes 1Z, AHU)
  • Disconnect fuel cut-off valve on Diesel injection pump.
  • Disconnect harness connector for quantity adjuster on Diesel injection pump.
  • Remove all glow plugs using 3220 hinged socket.
  • Install VAG1323/12 adapter in place of glow plugs.
  • Check compression using US1110 compression tester.
I still think that there's really nothing that can go wrong as long as I make sure the glow plugs are not seized before leaving home. But if the concensus is that it shouldn't be done, that's what I'll go with...
Old August 26th, 2008, 20:00   #6
compu_85
Gadget Guy
compu_85's Avatar
Oops, for some reason I misread the engine code. I must have spent too much time workin on my ECO lately, I've got IDIs floating around in my head.
Page generated in 0.15099 seconds with 9 queries
[Output: 77.45 Kb. compressed to 67.90 Kb. by saving 9.54 Kb. (12.32%)]
