| Jetta/Bora/Vento TDI Picture Gallery Do you have a Jetta/Bora/or Vento TDI? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle. |
August 24th, 2008, 07:22
#1
rocketeer928 - My 2003 VW Jetta TDI
Hi Fellow TDI Friends,
I thought I would finally post my '03 Jetta TDI on this site, which I purchased in Dec 2007. The details are below in my signature. So far, this is the favorite car I've ever owned and the only one I have installed serious modifications. My wife and I lived in Ockenheim, Deutschland (grapevine & wine country) from Dec 2006 through Nov 2007 for my job, and this is where my love for the VW diesel engines was cultivated. My company gave us a 2005 VW Passat Wagon (Kombi) TDI for the year, and for a wagon it was a lot of fun to drive and got 6.4 liters/100 km (35 mpg). Hope you enjoy the pictures.
Link: 2003 Jetta GLS TDI - Platinum Gray
Ich liebe meinen FOW-VAY, weil er sehr schnell fährt.
October 26th, 2008, 19:01
#2
Dyno at Dent Sport Garage in Norwood, MA
Modifications at the time include:
The stock engine is rated at 90 hp / 155 ft-lbs torque. At 118 hp / 215 ft-lbs torque, this translates to an increase of 31% hp / 39% ft-lbs torque.
June 8th, 2009, 08:04
#3
Modifications: May 2009
Over the course of the week of May 22 – 30, 2009, I installed the following modifications on my 2003 VW Jetta TDI:
Ø Garrett VNT 17/22 Hybrid Turbo
Ø MAF to Turbo Intake 2.5-inch OMI
Ø Upgraded 2.5-inch Upper and Lower Intercooler Pipes
Ø 3-Bar MAP Sensor
Ø 0.658 Fifth Gear
Ø 034Motorsport Density Line Dogbone Mount
Ø 2.5-inch Downpipe with Catalytic Converter
Ø 2.5-inch CAT-Back Exhaust without Muffler
Ø Braided steel turbo oil supply line
Ø CAT Fuel Filter (installed early May; no installation description or pictures)
The following modifications were installed on my Jetta TDI last year:
Ø Unitronic Stage 2 PLUS/EGR Delete chip software
Ø Dieselgeek by-pass filter, short shifter, race pipe, and EGR delete
Ø PP520 Injector Nozzles
Ø Valeo G60/VR6 Clutch and Flywheel (This by far was the hardest job for me to do.)
Ø TDI FrostHeater
Except for the 0.658 5th gear (see reason below), I installed all of these modifications myself. At this time, I’m still using the OEM 10-mm injection pump and OEM intercooler. Perhaps next year I will consider upgrades to these two components, such as the 11-mm injection pump and a TTT or Eurojet side-mounted intercooler. I spent enough extra money on modifications for this year. On June 20, 2009, I have plans to have the RocketChip RC4 software installed on the Jetta TDI, which I suspect replaces the Unitronic Stage 2 PLUS software.
The following posts explain the installation of my latest modifications. I used many different “how-to” documents found on the internet. Unfortunately, some of my pictures are a little blurry because the digital camera I have is rather old and doesn’t do well with close-up shots or it focuses on something else besides what I was going for.
Perhaps a fellow TDI enthusiast will find this document helpful.
June 8th, 2009, 08:27
#5
Bumper Removal
June 8th, 2009, 08:32
#7
Headlight Removal and Connector Replacement
Removed both headlights with T20 screwdriver on four bolts each. I have washers underneath the bottom bolts to slightly raise the headlights projection at night.
Disconnected the headlight harnesses. When I first installed these headlights last year, I managed to badly mangle the passenger side headlight harness connector. This is when I was first learning how to disconnect such wiring. So, this was a good opportunity to replace the damaged harness connector.
Removed the purple clip from inside both the damaged and new harness connector.
Using an extraction tool I bought from a fellow TDI Club member, removed one wire at a time and placed into the same position within the new harness connector. Wire numbers 2, 4, 6, 8, & 10 from the top and wire numbers 7 & 9 from the bottom. I have extra wiring for the fog lamp relays.
Re-inserted the purple clip with the grooved channel side out until it clicked in place. Temporarily connected negative battery terminal and tested the headlight and turn signal, which worked!
June 8th, 2009, 08:40
#10
Race Pipe Removal
Disconnected the Stewart Warner TDI boost gauge tubing from the Dieselgeek race pipe.
Removed the three bolts and washers attaching the Dieselgeek race pipe to the intake manifold with a 5-mm Allen socket.
June 8th, 2009, 08:43
#11
Intake Manifold Removal
Removed the 2-bolt vacuum lines bracket from the intake manifold with a with a 5-mm Allen socket.
Loosened the six intake manifold bolts with a 6-mm Allen wrench and a ¼-inch metal tube about 12-inches long. I discovered this technique when I cleaned my intake manifold, removed the EGR and EGR cooler, and installed the Dieselgeek race pipe after I first purchased my Jetta TDI. Lots of soot… I don’t yet have long metric Allen sockets. As each bolt was loosened, I removed them. From the passenger’s side, bolts number 2 & 6 did not come out until the intake manifold was removed.
Removed the intake manifold and its gasket, which will be replaced upon re-installation.
I inspected the intake holes to the cylinder head with a mirror. There was a little soot, but nothing to fret and lose sleep over.
June 8th, 2009, 08:46
#12
Turbo Oil Line Removal
| Thread Tools |
Search this Thread |
