Old August 13th, 2008, 12:20   #1
Johhny04
Question BEW timing check
Hey everyone, i just replaced my timing belt on my '04 PD, used the DIY procedure from here. Great write up by the way. Now i am wondering if there is any timing adjustments that i need to do or check like you would with a ALH timing belt job? Someone mentioned that i might have to check my injector timing or something along those lines with VAG-Com, does that sould right???
2003 Jetta TDi skid plate, GLI suspension, VR6 brakes, Fat 5 TT rims
2002 Ford E350 7.3L Powerstroke. Weekend workhorse that pulls like a freight train!....sold
2004 Jetta TDI ..... sold
Johhny04 is offline   Reply With Quote
Old August 13th, 2008, 12:43   #2
TDICADDGUY
TDICADDGUY's Avatar
Fuel Economy: 42/46/51 with 5 speed - was 36/40/42 with 01M
Not necessary on a PD as there is no injection pump.
2012 BMW X5 35D 2000 NB with 3 pedal mod, RC3, PP520's, Eurojet SMIC, SBC 3, 2.5" side exit straight pipe, 2" lift.
TDICADDGUY is offline   Reply With Quote
Old August 13th, 2008, 13:08   #3
Johhny04
It was mentioned to me that i sould check some blocks with VAG-Com to see if, injector timing or some other type of timing or fuel delivery, lies within 2-5 number range, but i can't remember if that was it or it was something else. Can anyone chime in and educate me. Thanks
Old August 13th, 2008, 16:49   #4
2004STARWARSTDI
2004STARWARSTDI's Avatar
Post Timing
After all mechanical checks timing is controlled by ECU! Your Done!
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old August 14th, 2008, 09:06   #5
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
Here's a thread referring to optimizing the cam timing on the pd engines:
http://forums.tdiclub.com/showthread.php?t=215202
They mention better mileage and smoother idle. Haven't had a chance to check my '04 yet.
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old August 15th, 2008, 06:43   #6
Johhny04
Exactly what i was looking for. Thank you gforce1108.
Page generated in 0.13264 seconds with 9 queries
[Output: 71.30 Kb. compressed to 61.93 Kb. by saving 9.37 Kb. (13.14%)]
