Old August 2nd, 2008, 11:38   #1
hid3
Banned
Default Oil question: 5w40 vs 5w30
Hello folks.
At the moment my TDI PD has ~81k miles on it. I'm using Motul 505.01 5w40 100% syntetic oil.
My friend owns BMW 320d 100 KW with 120k miles on it and he's using 5w30 oil. He says that I'm stupid and idiot to be using 5w40 at such mileage. He claims I'd be using 5w30 instead.
I got confused. Someone told me that for our climate (West/Central Europe, in winter -25 in summer +30, humidity is high) it is a good idea to use w40.
My driving style is 95% city driving with frequent stops and accelerates.
Will it be better if I switch to 5w30 now? Guys, I need youd advice on this question, please share your opinion. Thanks.
hid3 is offline   Reply With Quote
Old August 2nd, 2008, 11:40   #2
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
At such mileage, LOL. 81K miles is nothing
You're fine. You can use either 5w30 or 5w40 that meets or exceeds 505.01.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old August 2nd, 2008, 17:26   #3
wjdell
Fuel Economy: avg. 41.93 high 46.32 low 34.6
What he probably meant was your engine is young and does not need a thick oil. That you may get better mileage or performance from a thinner oil. 12.0 vis vs 13.5. As the engine ages then thicker is less likely to pass by the rings. Oils have changed and although he may have been correct before thats not entirely correct today.
Post your UOA data in the TDI UOA Database thread
http://forums.tdiclub.com/showthread.php?t=205814
~ USED OIL ANALYSIS ~ http://forums.tdiclub.com/showthread.php?t=190958
1.9 PD Jetta V ~ pkg 1 ~
DSG ~ 17" VV ~ 36/34 psi ~
ULSD ~ DG-BP90 - speed 39.2
hwy/city 83% / 17% ~
elev 58 ft / temp 72 F / humidity 76% ~ MPG 48.3 / 42.8 / 35.6
wjdell is offline   Reply With Quote
Old August 4th, 2008, 17:41   #4
TornadoRed
TornadoRed's Avatar
Originally Posted by hid3
Hello folks.
Some of the VW505.01-rated oils in the 5w30 viscosity range are actually very thick 30-weight oils... what might be considered a 5w38 viscosity. So there's probably not a great deal of difference between the 5w30 and 5w40.
Most TDI owners in North America are using synthetic 5w40 oils, and our conditions are just as severe as in Lithuania or the vicinity.
'03 Golf with 693k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilsteins, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Nokian snows, TDT/Delvac1
TDI Trusted Mechanics by jwlionking TDI Search Engine https://cse.google.com/cse/publicurl...44:_idbzjdyxdm
Old August 5th, 2008, 08:00   #5
Powder Hound
Powder Hound's Avatar
Personally, I like as small a temperature range as I can get away with. Temperature ranges used to be entirely done by adding in a polymer to a thin oil. These polymers coil up at low temperatures and then lengthen out at higher temperatures. The then longer chains add viscosity at the higher temperature.
High quality oils these days have a "natural" temperature range increase as compared with older oils from, say, 20 years ago. Back then, GM did some testing and declared that a temperature range of 25 or more was a near guarantee of sludge formation in the engine due to break down and polymerization of those polymeric viscosity increasing addtives. These days, a lower quantity of those additives is required to get the temperature range, so you end up with more oil in the bottle and less additive that might sludge up your engine.
In my engine, I run a 15W-40 group V synthetic. It isn't VW approved, it just works better than anything they do approve, IMO, and that is about all anyone here can say, anyway.
My car is a Y2K vintage Golf, and so I'm not worried about 505.01 or any other VW certification. And if I was, I have 232k+ miles on it anyway, and VW will never do any powertrain warranty at this point, so what do I care what VW says?
For me, I get better mileage than nearly any gasser out there. So I look at the following: I want my car to last. My target is 500k miles. I'll do what I can to get there in one piece, and right now, I want the best protection for the engine that I can afford. That means a little thicker bottom end number than 0W or 5W. I like 15W. I'd prefer 30, really, but the manufacturer (Redline) doesn't supply a diesel formulation in viscosities other than 15W-40 AFAIK. OK, so I'll get a little lower mileage on cold winter mornings (particularly now, since I moved to NH), but I'll still be way ahead of any bimmer.
FWIW - back to flogging the dead horse (happens a lot on these threads) diesels run in a lower temperature range, have lower head temperatures, and lower heat rejection due to better thermodynamic efficiency. Sludging isn't as big a problem as it is in a gasser engine that cooks it oil at higher temps than we do. Yet another reason diesel engines last longer.
Page generated in 0.12839 seconds with 9 queries
[Output: 70.42 Kb. compressed to 62.38 Kb. by saving 8.04 Kb. (11.42%)]
