| TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed. |
July 31st, 2008, 18:30
#1
August 2008 Mileage Thread
This is a month by month competition. Every time you make an entry it will be added up and recorded together according to the fuel type and car/year you are driving.
THIS IS NOT an individual tank competition (or a partial tank competition for that matter).
Entries will be accepted until September 5, but remember, report tanks FILLED IN August.
Entry Format:
Driver:
Miles:
Gallons:
Model Year:
Model:
Tranny:
Fuel Type:
You are allowed to put more than one fill up in a post, so long as each fill up conforms to format.
MPG: (optional since I will calculate it automatically anyway)
(anything else you would like to add)
Hint on entering your data - after the colon ( ":") put a space.
US GALLONS AND MILES
TRANNY TYPES:
(x) A = x speed automatic
(x) M = x speed manual *
DSG = direct-shift gearbox
CVT = continuously variable transmission
* if you have swapped in a taller 5th gear please noted this (ie: 5M w/.681)
FUEL TYPES:
Bx = biodiesel - x is the percentage of bio
Biodiesel use equal to, or more than B20, will be indicated in GREEN.
ULSD / LSD / D2 = normal petroleum based diesel
Also please note if it's winterized
- please note if you are using a fuel additive (ie: ULSD +PS)
- - Power Service (PS); Stanadyne (ST); Redline (RL)
Posts not in format will not be tallied / corrected.
Please do not go back and add additional fillups to a post. Multiple fillups per post is fine as long as all fillups are in format. If the driver name is not the same as your post name - this will be considered "Not in format" and will not be counted. Only exceptions would be "and spouse" etc.
2000 Red NB TDI, 4 speed Automatic, 278,695 miles
Now 5 speed manual and onto 500,000 miles + !
August 1st, 2008, 17:41
#2
Driver: Schwabe
Miles: 816.2
Gallons: 15.19
Model Year: '06
Model: Jetta TDI
Tranny: 5M
Fuel Type: D2
August 1st, 2008, 17:51
#3
Driver: Blue_Hen_TDI
Miles: 370.1
Gallons: 6.091
Model Year: 1996
Model: B4V
Tranny: 5M
Fuel Type: B20
MPG: 60.76 mpg
I experimented with three trips to work (120 mi r/t) with no A/C and cruising at 55 mph. I beat my average (usually at 65 mph w/ A/C) by 13 mpg.
August 1st, 2008, 19:01
#4
Fuel Economy: worst/average/best: 37/44.5/52
Driver: Joe TDI
Miles: 647.3
Gallons: 14.7
Model Year: 2003
Model: Jetta
Tranny: 5M
Fuel Type: ULSD
MPG: 44.03
2004 Jetta GL TDI Tiptronic 210k miles|VNT17|RC2|Cat/Mufflerectomy
2002 Jetta GLS Wagon 5spd 123k miles
1999 Jeep Wrangler 5spd 220k miles|Fisher Plow
2006 Jeep Liberty 80k miles
August 3rd, 2008, 15:54
#5
Fuel Economy: 75.0/53.0/38.4
02August2008
Driver: Fix Until Broke
Miles: 841.0
Gallons: 15.274
Model Year: 2003
Model: Jetta
Tranny: 5M W/0.681 5th
Fuel Type: ULSD
MPG: 55.06
250 miles @ 73 MPH
250 miles @ 63 MPH
350 miles misc trips work/home/errands/etc
A/C on for all highway miles and ~100 miles of misc trips
25% effort in driving for economy
89,074 ODO miles
SG Readings
MPG: 56.1
GAL: 14.9
Miles: 837
AVG MPH: 43
Hours: 19.2
Fuel Trim +61.6% for this tank (now +64.2%)
Miles Adjustment +3% (no change)
All speeds indicated (~3% higher than actual), no Odometer Correction (~1% lower than actual)
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP110 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, VNT 17/22, 3 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/50/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ASV Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, Gauges
August 3rd, 2008, 19:49
#6
Oil Wanker
Driver: Bob_Fout
Miles: 446.6
Gallons: 8.827
Model Year: 2003
Model: Jetta GLS
Tranny: 5M
Fuel Type: ULSD
MPG: 50.6
August 4th, 2008, 04:51
#7
Driver: tasdrouille
Miles: 673.7
Gallons: 10.45
Model Year: 1999
Model: Vento
Tranny: 5M
Fuel Type: ULSD
MPG: 64.47
300 miles going to and from work (7 miles each way)
370 miles highway at 53 mph
I've got so much torque...I could tear a hole in time!
Jetta 2000: VR6/G60 clutch kit and .216 nozzles
www.HyperKilometreur.com - Quand chaque goutte compte...
August 5th, 2008, 17:23
#8
driver: DK
miles: 783.4
gallons: 13.991
year: 2002
model: Golf GLS
tranny: 5m
fuel: ULSD+PS
mpg: 55.993
$4.69/gallon
cost/mile: 0.083 cents
August 5th, 2008, 18:24
#9
Originally Posted by Schwabe
Driver: Schwabe
Miles: 816.2
Gallons: 15.19
Model Year: '06
Model: Jetta TDI
Tranny: 5M
Fuel Type: D2
C'mon dude! You're killing me!
Are you SURE you don't mean 512.2 miles?
August 6th, 2008, 07:08
#10
Fuel Economy: Max 54, 44 avg
Driver: MPLSTDI
Miles: 635.7
Gallons: 14.349
Model Year: 2006
Model: Jetta MKV
Tranny: DSG
Fuel Type: ULSD B2
44.3MPG :-( I'm not sure why this tank was so bad. I blew out the turbo out a number of times more than normal. My wife got 50.5MPG in her Prius, and boy did she rub it in. I did change the oil, fuel filter etc. But I did not spill much at all. (Also a little more AC than normal)
Member of the TDT for PD Mafia
2006 Jetta TDI DSG base 0 - heated seats Shadow Blue 133K ScangaugeII Hidden hitch
2005 Jeep Liberty CRD 67K, GDE ECO tune, GDE TCM
August 6th, 2008, 07:15
#11
53.7 mpg is not out of line for a manual trans PD driven lightly.
August 6th, 2008, 07:24
#12
Fuel Economy: Best: 57 Worst: 39
I am moving this from the July thread because it wasn't included in the totals. I guess I put it in to late for July.
Driver: meby
Miles: 840
Gallons: 14.916
Model Year: 00
Model: Jetta
Tranny: 5m
Fuel Type: ULSD + PS
MPG: 56.31
I did it!  Well over 800 miles on a tank. By far my best (not anymore, see below). No A/C, average speed of 55 mph, windows up as much as possible, and trying not to us my brakes to stop when possible.
Tank 2
Driver: meby
Miles:749.1
Gallons: 13.2
Model Year: 2000
Model: Jetta
Tranny: 5m
Mpg: 56.75
This tank I put grandma to shame.  Except for the last 125 which was done on the interstate with the cruise @ 70 mph. No a/c.
Tank 3
Driver: meby
Miles: 725.5
Gallons: 14.13
Model Year: 2000
Model: Jetta
Tranny: 5m
Fuel Type: ULSD
MPG: 51.34
This tank was all but 160 miles on the interstate. Cruise @ 75 or 80 mph. A/C on most of the time. What wasn't on the interstate was driven like a madman. No PS this time. I went to WI over the weekend and wow, you fuel is a lot cheaper. Filled one tank @ $4.21 and the other @ $4.28 per gallon.
PETA = People for Eating Tasty Animals.
2000 Jetta TDI 5spd,200,000 miles Mods: Ventectomy, Mufflerectomy, DRL Delete, 5 light mod, any other ectomies I should do?
August 7th, 2008, 08:07
#13
Location: Virginia, in the mountains west of horse and buggy land
Fuel Economy: 800mi club, 45.2 avg
Driver: Johnny_come_lately
Miles: 815
Gallons: 14.51
Model Year: 1998
Model: Jetta
Tranny: 5m
Fuel Type: ULSD
56 mpg, not even trying hard. Just a rural, non-interstate commute, not even in flat-country. The Shenandoah Valley is a pretty place to log miles. I'll admit to driving a bit slower on the uphills, but when September hit's I'm going for 900 miles on a tank. (no A/C)
Does the '98 Jetta have a low fuel bell that rings when you get below the red?
My carbon footprint is small because I have to PAY for carbon.
August 7th, 2008, 13:09
#14
Oil Wanker
[quote=
Does the '98 Jetta have a low fuel bell that rings when you get below the red?[/quote]
It dings when you reach the red. It's LOUD.
August 7th, 2008, 14:29
#15
Driver: Ieracer
Miles: 714.2
Gallons: 13.453
Model Year: 2000
Model: Jetta
Tranny: 5M
Fuel Type: D2
Another 700+ tank and my best mileage to date.
53.089 mpg
2000 Jetta GLS TDI
5spd Silver/Black 220k miles
Sprint 520
