| TDI 101 Got a simple/basic TDI question? Are you a newbie (new to the forums). Feel free to post your question here. |
July 18th, 2008, 14:35
#1
timing belt replacement
I have a 2003 jetta tdi with 95,000 miles on it. Dealer is recommending that at 100,000 miles i also replace the waterpump, rollers, tensioners, thermostate, and serpentine belt. Do I really need to replace the thermostate? Should anything else be replaced at this time?
Also, I always change the oil at 5,000 miles.....am I wasting my money....should it be every 10, 000 instead?
July 18th, 2008, 15:09
#2
Welcome aboard!!
1) no
2) yes
3) yes, probably
The thermostat does not NEED to be replaced, but it's fairly cheap and the rest isn't. I didn't replace mine, yet. I believe the TB interval was 80K until the upgraded roller(s) were installed after the first factory TB replacement.
Most of the bolts are single use TTY type stretch bolts. They are NOT to be reused, although many dealerships do, only to have them break after the job is miles down the road. Camshaft and vac pump seals also recommended. Buy the 100K TB "kit" from dieselgeek/metalman/etc.
The CORRECT SPEC synthetic oil is good for 10K, unless you are under severe service conditions. Most all good oil that meet the VW spec provide great used oil analysis even beyond 10K. I use Shell Rotella T 5w-40 full synthetic. It meets the spec for our model year, readily available, and has a good UOA track record. Many will have their own personal favorites and reasons.
Find a TDIclub "guru" to do your TB job. It will be done correctly (most VW dealerships are terribly uneducated in the TDIs) and for less money with the proper 100K updated kit. Read on/search here for many botched TB jobs. It isn't one of those things where close is good enough.
Gather information and procede carefully.
2004 Cadillac SLS (wife's)
July 19th, 2008, 20:25
#3
Fuel Economy: 52/41/36 (315k miles)
I have a 2003 jetta tdi with 95,000 miles on it. Dealer is recommending that at 100,000 miles i also replace the waterpump, rollers, tensioner, thermostat, and serpentine belt. Do I really need to replace the thermostat? Should anything else be replaced at this time?
This is amazing -- a dealership service department that actually wants to do the job right. Usually they just like to change the TB and tensioner, and then you come back later for a water pump, and then you come back later when one of the rollers fails and maybe damages the head.
Take a look at the Dieselgeek deluxe kit. www.dieselgeek.com
It's got all the best parts. There are other registered vendors on TDI Club that also have good TB kits. But the Laso water pump with brass impeller is the one Dieselgeek includes, and it is reputably the best water pump.
If you live in the Atlanta area, you've got two TDI pros you can go to:
Atlanta northside: Troy Sentz, Canton, GA 570.233.1385
TDI Club username TNTKNC
Atlanta southside: Roger Feldt 678.907.4221
If you live in south Georgia, there's Krout in Jacksonville, if that's closer.
If you use the right oil, a synthetic 5w40 meeting the VW spec or the API CI-4 spec (or better), then 10k miles is the normal oil change interval.
'03 Golf with 316k miles: Kerma Bosio PP520, Hammer 1849V, Passenger Performance 2.5" DP, Aligator tuning, VR6/G60 clutch/flywheel, Koni Reds, Houstons, Recaros, Akebonos, CAT, Old Navy CCV, DG Panzer skidplate, Hidden Hitch, Mobil 5w40
Foobert's TDI Hunt -- all Craigslist TDI ads nationwide
TDI Trusted Mechanics by jwlionking
July 19th, 2008, 21:32
#4
Originally Posted by jettawreck
.....I believe the TB interval was 80K until the upgraded roller(s) were installed after the first factory TB replacement...
Just a clarification: The 2003 interval is 100K on the original belt regardless of transmission. 2002 is 80k.
2003 Jetta GLS TDI 5-speed, Platinum Gray, Ventecomy, Ecodes, Engine Cover mod.
Have VAG-COM (Houston area)
July 20th, 2008, 14:24
#5
TB replacement
YES, replace the water pump and everything else the dealer says including the TTY bolts.  Better yet find a TDI Guru in your area and puirchase the Deluxe TB kit and let him install it and watch and learn from him. You will also save your self some $$$!
July 20th, 2008, 18:22
#6
I agree with all here. Thermostat is probably not needed, but it is cheap and based upon the cost to replace it later should it fail, probably not a bad idea to just do it now while you got the coolant out and are gonna have to bleed the system anyway.
July 22nd, 2008, 08:36
#7
great advice
thanks for all the responses...
which timing belt kit is better...the one on diesel geek for $333.00 or the impex site for $290?
i talked to Troy here in the atlanta area and he was really helpful although being new not real clear about cleaning the exhaust or something when he does the timing belt....can someone explain this to me..thanks.
July 22nd, 2008, 08:59
#8
I assume you mean this one: http://www.worldimpex.com/parts/germ...di_272109.html
The caption is not very informative -- it mentions a Laso water pump but not mention whether it has a brass or plastic impeller. It mentions "hardware" so I guess it includes all the "always-replace" bolts.
You could call Impex and ask for more information.
July 22nd, 2008, 11:24
#9
I think Troy meant cleaning the Intake Manifold, not the exhaust. The EGR valve dumps all sorts of soot, oil and gunk into the intake manifold and yours may be plugged. Good idea to have him check it while he is in there. The TDIParts site has a similar kit for $299.00, they all are very similar, who has free shipping???
The Thermostat is just easy to do while the coolant is drained, you only have to replace it once then. I would almost be tempted to do the Coolant Temperature Sensor while the coolant is drained as well, it may never go bad but there has been some history of them failing...
2003 Jetta TDI, Ventectomy, H&R OE Sport Springs......
July 22nd, 2008, 20:06
#10
This one for $305 shipped.
http://www.metalmanparts.com/product...&productId=159
Modding is an illness with no cure...
Yes I'm back to working on TDI's again!
Cell 954-295-7867 or Email me for info: deezldub@gmail.com
2010 Golf TDI 6spd.
2000 Jetta TDI 5spd, aka Deezl-Düb Sold
1993 Ford F350 Dually CrewCab 7.3L IDI, Banks Sidewinder Sold
July 22nd, 2008, 20:16
#11
Originally Posted by Pitboy
It mentions either a Graf or HEPU water pump. I think the one and only water pump failure I've had involved a HEPU, but I'm not 100% sure.
I still like to see the word "brass" used in describing water pump impellers. "Metal" is good, "brass" is better.
Metal Man has an excellent reputation, both as a vendor and as a TDI timing belt installer.
July 22nd, 2008, 20:21
#12
I've installed a bunch of these kits in customers cars plus twice in my car. No problems, complaints or failures.
2010 Golf TDI 6spd.
July 23rd, 2008, 06:47
#13
Thanks, you are correct with the model year requirements.
July 23rd, 2008, 07:00
#14
Zehntes Jahr der Veteran Vendor
Leave the thermostat alone, if it ain't broke don't fix it. Replacing a properly working thermostat almost always invites trouble, that is you end up installing a bad thermostat only to reinstall the original working one.
VW thermostats are extremely reliable. The only bad ones I have seen were the new ones that were installed on a customers insistance!
DB
*Check out our new Hot-Swap program, no downtime and injectors are shipped to you ready for install with the nozzle of your choice! *Insist on Genuine Bosio nozzles, All of our nozzles come with Bosio issued Authentication ID#'s traceable directly back to the factory.
July 23rd, 2008, 07:15
#15
Master of the Obvious
Decide which Guru will change the belt first and then ask them what kit they prefer to use.
