Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
User Name
Password
Thread Tools Search this Thread
Old July 14th, 2008, 17:45   #1
DeliveryValve
Default Throttle Body Cleaning
I noticed on other threads about cleaning out the throttle body, but have not found anything on the BHW throttle body. Should I also clean the throttle body if my EGR is caked with carbon and oily goo, and while looking inside the intake it is coated with an oily goo substance?
If so, what is the procedure to remove it for cleaning?
- Richard-
2005 Passat TDI GLS Wagon 69,xxx miles
DeliveryValve is offline   Reply With Quote
Old July 14th, 2008, 18:07   #2
MOGolf
MOGolf's Avatar
Yes, clean it too. Disconnect electrical connectors. Unbolt it to remove it.
The intake manifold bolts are a little difficult to remove. A couple of them are blocked from straight access due to the turbocharger actuator. You may need long, ball end 6mm hex bits to get to them.
MOGolf is offline   Reply With Quote
Old July 14th, 2008, 19:31   #3
Nocky
Nocky's Avatar
The carbon build-up in my 03 was really really soft. It did not take much scraping to get the big chunks loose. After that some carb cleaner and a tooth brush was all it took.
Nocky is offline   Reply With Quote
Old July 15th, 2008, 07:49   #4
senez
Good God Almighty...
How many miles were on yours and what sort of performance decrease did you see?
2005 Passat Sedan GLS - Unchained
Stonehenge Gray
senez is offline   Reply With Quote
Old July 15th, 2008, 10:34   #5
abctdi
Are we confusing throttle body with EGR in these pics? Why pics from an 03 whatever? Certainly not a passat tdi.
88 Fox variant gasser - long gone
98 Jetta TDI 1.9 - sold...
05 Passat GLS 2.0 PD, stock hp/trq, UnChained, Steel GPs
I'm not as green as I am cheap...
y2k F250SC4x4 PSD 444 cid, 333hp, 667trq
69 Mach 1 Mustang 377 cid, 420hp, 440 trq
abctdi is offline   Reply With Quote
Old July 15th, 2008, 11:00   #6
Radman
Those pics are from an ALH engine not a BEW/BHW engine.
Radman
2009 Passat 2.0 TSI Wagon 6 speed.
2004 Passat TDI Wagon. FOR SALE.
Radman is offline   Reply With Quote
Old July 15th, 2008, 21:36   #7
DeliveryValve
Thanks for the info guys!
BTW - Here is a pic from club member "jrock" on what his gunked up Passat EGR looked like before (Mine was similar) and after he cleaned it.
http://forums.tdiclub.com/showpost.p...19&postcount=1
- Richard-
Old July 16th, 2008, 07:57   #8
abctdi
Yuk, mine was not that bad at my 30k cleaning, but I'm gonna check again at 50k. But what about your question about the throttle body? I'm not aware of that needing to be cleaned.
Old July 18th, 2008, 19:07   #9
DickSilver
Just unplug the EGR connector. It will stay shut, the intake manifold will stay cleaner, and the car will run fine. The MIL light will stay on and you will get a bleep from it on starting.
It is useless getting angry at your car: don't let nuthin' whup you that can't talk....
B5.5V, chainless 122K
B4V, 203K
DickSilver is offline   Reply With Quote
Search this Thread:
Advanced Search
vB code is On
Powered by vBulletin Version 3.5.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.07617 seconds with 10 queries
[Output: 65.34 Kb. compressed to 60.59 Kb. by saving 4.75 Kb. (7.26%)]
