Old July 11th, 2008, 07:20   #1
garnet
Fuel Economy: 50/46/40
Default Torx bit and star bit
Are these the same thing, or do I need a different set of bits?
garnet is offline   Reply With Quote
Old July 11th, 2008, 08:38   #2
puter
Fuel Economy: 57 mpg
You need triple square most likely.
Torx and star are different, you are more likely to run into torx than star, and most likely to run into triple square.
puter is offline   Reply With Quote
Old July 11th, 2008, 08:46   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
This keeps coming up. Here are what the different things are:
Torx: 6 pointed
Tamper-proof Torx: 6 pointed with a round peg in the middle
Torx Plus: 6 pointed, but the points are rounded off
Tamper Proof Torx Plus: 5 pointed, points rounded off, peg in the middle (yes, they are FIVE pointed).
XZN (Triplesquare): 12 points
Allen: 6 sided hollow hex
Polydrive: 6 widely spaced rounded points (used on some head bolts).
There is no such thing (technically) as "Star".
Read all about them here:
http://en.wikipedia.org/wiki/Torx
oilhammer
www.cardocautomotive.com
Old July 11th, 2008, 08:49   #4
Lex4TDI4Life
Lex4TDI4Life's Avatar
What, exactly, are you trying to unscrew here?
2001 Golf TDI 5 spd
RC2, Bosch T4-764 injectors, OMI, SBC Stg 2 Clutch, Koni FSDs, TT LCA Bushings, The Mystery Bar, Dieselgeek Panzer Plate, Elephant Hose, DG Race Pipe, Autometer Cobalt Boost Gauge, Boostvalve,Fumoto Valve, Mufflerectomy, Scangauge II
Lex4TDI4Life is offline   Reply With Quote
Old July 11th, 2008, 10:11   #5
garnet
The drive alxes from the tranny
Old July 11th, 2008, 10:12   #6
garnet
Stupid manufacturerd, just have a standard type.
Old July 11th, 2008, 10:17   #7
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
You need Triple-Square... (XZN) 8mm...
Yuri.
ymz is offline   Reply With Quote
Old July 11th, 2008, 10:19   #8
garnet
Sears have them?
Old July 11th, 2008, 10:28   #9
puter
Nope.
Generally an online deal. I have seen them a few times at various auto parts stores.
Old July 11th, 2008, 10:55   #10
ymz
Sears have them?
AutoZone may have a set... I don't think Harbor Freight does... MetalNerd has excellent quality ones (as usual...) Probably most auto parts stores have something... (Lisle makes some...) Then there's always Snap-On... (I still have mine from way back when I needed it for my Type-III and Type-IV air-cooled VWs...)
Yuri.
Old July 11th, 2008, 12:13   #11
Lex4TDI4Life
They arent THAT unusual. Just call up the local independent parts store and ask them for 8mm Triple Square bits. You will probably need a short extension and a universal/wobbly adapter to get to those bolts.
2001 Golf TDI 5 spd
Old July 11th, 2008, 12:17   #12
Lex4TDI4Life
http://www.sears.com/shc/s/p_10153_12605_00992177000P
2001 Golf TDI 5 spd
Page generated in 0.14088 seconds with 9 queries
[Output: 103.41 Kb. compressed to 86.36 Kb. by saving 17.05 Kb. (16.49%)]
