Old July 12th, 2008, 07:56   #16
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
Originally Posted by ymz
There's the rub... some of the people named in the "trusted mechanics" thread aren't really up to the task of changing the timing belts. It's best to keep on reading here to find out who the "trusted mechanics" for this maintenance item really are... If you can get yourself to a "guru", so much the better... even if you have to drive a long distance to get there... (BTW: "guru" in this instance is someone who's known to the membership here as having done this successfully - and "by the book" - in the past and who isn't inclined to take shortcuts.)
All the best,
Yuri.
IMO, they don't qualify as "trusted" mechanics unless they are honest enough to tell you that they don't have enough confidence in their ability to do the job you are asking them to. IOW, you should be able to ask anyone on that list to do the TB job, and trust their ability to do the job, or they don't belong on that list...
tditom is offline   Reply With Quote
Old July 12th, 2008, 08:11   #17
icecap
Fuel Economy: 37 MPG Highway
Originally Posted by Ski in NC
I work on large marine diesels. When tightening head bolts, some are tightened to a certain ft-lb, then an additional number of degrees. Each head is marked for the degrees. I have noticed that if you pause to get another purchase on the wrench, the degrees turned in the ft-lb mode are very different than the ones where you can get a clean sweep. So yes, call it "sticktion" or whatever, torquing is certainly an inexact science.
Regarding the pulley that slipped on the cam nose, there must have been something else going on as others have posted. A taper with a retaining bolt at 33 ft-lb will lock just fine. But all must be clean and well seated.
Take a pulley and cam that is out of the head, and put the bolt in and tighten it to 33. Now take some strap wrenches or pipe wrenches and try to twist the pulley relative to the cam. If mating surfaces and threads were in good shape, I bet you cannot get it to slip.
But when I did my own tb, I went to 33 and said...hmmm, not enough. And went to about 45. A gut feel thing.
-Eric
Thanks for your input Ski. I also recently ran into a situation with a conical or 'morse taper' drive gear on a cummins 6C 8.3 engine in a track drill. I removed the injection pump to get it repaired since it had a crack in the governor housing. When I got the pump back from the injection shop it had a tag attached noting that the 130 ft/lb torque in the service manual should be ignored and it should be torqued to 170 ft/lb since they have been known to slip thier timing at the factory setting. Needless to say I had some reservations while I was torquing it wondering whether I was going to pull the threads but it held.
2006.5 TDI Jetta 5Spd. Black /Anthracite Pkg1
Have VCDS Hex + Can USB and many A5 & BRM Tools
icecap is offline   Reply With Quote
Old July 12th, 2008, 08:25   #18
wil2007
TDI(s): none
[quote=ymz]There's the rub... some of the people named in the "trusted mechanics" thread aren't really up to the task of changing the timing belts. It's best to keep on reading here to find out who the "trusted mechanics" for this maintenance item really are... If you can get yourself to a "guru", so much the better... even if you have to drive a long distance to get there... (BTW: "guru" in this instance is someone who's known to the membership here as having done this successfully - and "by the book" - in the past and who isn't inclined to take shortcuts.)
All the best,
Yuri.[/qote] Now I need to find the trusted "Trusted Mechanic" near the Treasure Coast, find TB changeout and add to the price of TDI.
wil2007 is offline   Reply With Quote
Old July 12th, 2008, 08:48   #19
terrydtdi
terrydtdi's Avatar
Fuel Economy: BEST 58 ( 900 mile Club ) av. 46, worst 38, Mobil 1 TDT
I have bump up the torque setting to 37ft-lbs. after hearing a few of these cases also ,for a little insurance.
2K jetta gl tdi 5spd 398k, RC5+, 17/22, PP764's, ported head, ARP head studs, 11mm, 3" turbo back, Kerma OMI, PD150IT & race pipe, VR6 air box & MAF, Godspeed SMIC, 3 bar map, PD lift pump, 681 fift, TT LCA's, spindles, brakes, GLI rear brakes and interior, VR6 axles, mcnalley boost/egt gauge, SBC Stage 2 Endurance, bagged, Michelin Pilot Super Sports
terrydtdi is offline   Reply With Quote
Old July 12th, 2008, 09:48   #20
Harvieux
Harvieux's Avatar
Originally Posted by oilhammer
LOLing at 'dealer bafoon'... seen that a lot, although usually they never bother to even remove the sprocket because they are just doing the old "Mark & Pray"
Oh yea! I almost forgot about the dealer's mark and prey white marks method which crops up it's ugly head from time to time making me wonder HTF the cam sprocket came loose so easily on those. LOL!
Originally Posted by tditom
so, we have 2 gurus (Frank and Harv) going beyond the spec, and 3 gurus (DB, LugNut, oilhammer) sticking to the spec (after ensuring the taper is clean and burr-free).
I would vote for sticking to the VW spec, but I've only done 6 VW TB jobs
I have no argument against keeping it to spec. It's more of a personal freak out prevention method I decided to take without going overboard. Know whadda mean? Later!
Harvieux is offline   Reply With Quote
Old July 12th, 2008, 11:51   #21
cheeba
Originally Posted by whitedog
OK I have a question for you. I heard about this via the internet, so I want to hear other opinions and facts.
I heard that unless the torque is less than something like 70% of the final torque, That check thing is useless. This would be because of something I have heard called "Sticktion". That is the resistance to START turning that a bolt has.
To me it sounds possible, though I'm not sure about the number, (70%) but the basic theory sounds sound.
I would appreciate any thoughts.
I'm going to assume that sticktion is a contraction of static friction, or maybe sticky friction
Whatever you call it, there is definitely a difference between smoothly tightening a bolt without stopping and re-tightening a bolt after you have stopped turning the ratchet/wrench. This is due to static friction (in nearly all cases) being higher than the kinetic friction. Unfortunately, I don't think there's any magical number - such as 70% - since the relationship betwen static and kinetic friction changes in accordance with the force being applied. However, I'm far from a physics guru, and there could be a relatively safe guideline to use.
'02 225 TT - 2.0L, Daily 30+PSI @ 10:1, 9000RPM, Precision 6262 - RIP
'06 A3 3.2
Regina Portrait and Wedding Photographer, Jeremy Brehm
cheeba is offline   Reply With Quote
Old July 12th, 2008, 12:23   #22
Franko6
Ok, I expected to get a few flames... Let me put it into terms of a machinist.
The taper that the camshaft sprocket and the camshaft fit to is in much respect like a Morse taper. The morse taper is a common tooling fit for very large drill bits and tooling where extreme forces come into play. Sometimes the Morse taper fit will force on so tightly that it takes a 5 lb sledge and several whacks at the removal tool to get the taper to part. But I can tell you, I have never split a morse chuck and I've used some powerful machines pushing them.
Now, I'll bring the point of the bolt. It's a 12mm bolt. When there is no other indication, I refer to a 'standards' for torque. My standard for a 12mm bolt's torque on hardened steel is 44 ft lbs. That is a very reasonable number. Might I add, the force needed to remove a bolt at 33 or 44 ft lbs is negligible. I can't tell the difference.
But all it takes for me is a few disasters. I have already admitted, grease, accuracy of torque wrenches, dirt... there are several causes that might affect the 'correct' torque setting and the outcome.
But for me, the bottom line is this: I have a very hefty 12mm bolt and a very rugged morse style taper to pin two critical parts together. And you want me to take the risk with a torque number which I, by my personal experience have seen no less than 15 crashes because of a loose camshaft sprocket??
You do what you want. Mine is only a well thought-out suggestion based on a very sad history of the ones that have had camshaft sprockets slip and fail. I'm sure if you ask those people with the failures, they would suggest the higher number.
Just so you all don't go beserk about how damaging my idea is, I have measured how much further the camshaft is forced onto the cam by loading an additional 11 ft lbs. of torque. It amounts to .0015".
For those who use the 33 ft lbs number, don't you wonder why such a beefie bolt for such a low torque?
Something is wrong with the spec.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old July 12th, 2008, 16:01   #23
cheeba
Well said, Frank. I tend to agree with your line of thinking; and, in fact, have tightened the cam sprocket bolt to 40-45 ft-lbs. each time I've removed it.
'06 A3 3.2
Old July 12th, 2008, 16:04   #24
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
quote=Franko6] ...For those who use the 33 ft lbs number, don't you wonder why such a beefie bolt for such a low torque? [/quote]Not at all.
I attribute the seemingly low torque to the:
1. hardening of the cam making the hardened internal threads more brittle, and more prone to fracture than yield.
2. taper angles increasing the expansion distortion force on the sprocket hub.
3. fine pitch on the bolt increasing the linear force of the sprocket on the cam more than a steeper pitch coarse thread might and further affecting the distortion force of #2.
Any one of these would justify lower than standard flat surface to flat surface, coarse thread bolting of mild steel. I'm not about to boost the torque I use on mine when I change it.
And it's mine only. The comment about "gurus" having the confidence to handle others work requests applies to me. I'll guide you if you wish, but you'll make the final decisions, and perform your own work.You want 45? Go for it.
Svante Arrhenius 1896
Old July 12th, 2008, 16:52   #25
Franko6
Lug Nut,
I think there are a few errors in your summation.
1. The camshaft is not hardened through and through to brittleness. It's a complicated 7-step process, but what is flame hardened to a higher Rockwell standard (about 65)are the cam journals to about a .020" thickness, except at the peak of the lobe which is about .050" depth. The balance of the shaft is heat-treated for toughness, not brittleness. The bolt is not a TTY bolt. Neither are the threads. Nor are the threads brittle.
2. The amount of difference that the cam sprocket is wedged onto the camshaft is virtually inconsequential.
3. You are opening a can of worms saying that a coarse thread and a fine thread torqued to the same value have differences in applied force.
To futher diminish the argument that my higher torque value has no merit, the BEW camshaft hub, to which the camshaft sprocket is attached is applied with 100 Nm (74 ft. lbs.) and the bolt attaching the BEW camshaft hub is the same as the ALH camshaft fastener; it's 12mm x 1.5 pitch.
Why does VW now decide that the later model sprocket needs to be more than doubled? Why, when each of us who has been around long enough to see slipped camshafts, would not doubt that a 74% increase would be appropriate, when in the BEW model VW made a 224% increase and didn't even change the bolt?
Although I agree that in optimum conditions the bolt will hold the camshaft securely with 33 ft lbs, (45Nm), it's not a strap wrench I'm worried about making it come loose. It's the forces of an engine at speed. I also will not forget that in an imperfect world, adjustments must be made.
There is always room for improvement.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Old July 12th, 2008, 18:37   #26
alphaseinor
I've done about 100 belts on the ALH... I'm not really a "guru" but I did stay at a holiday inn express...
I use 40 lbs, and keep some emory cloth and a can of brake cleaner (non chlor of course) for the cones.
Make it spotless and any ridges get rid of with the emory cloth then spray it again with brake cleaner and a clean rag.
The cam will break at 50 lbs, so 45 is the max I'd use on the cam.
alphaseinor is offline   Reply With Quote
Old July 13th, 2008, 06:10   #27
Franko6
I"ve never felt threatened for breaking a camshaft or sprocket, but I do appreciate your input. Tell you what I'll do... I've got some spare sprockets. I'll take a worn out camshaft and sprocket and I'll torture test them. When something breaks, I'll tell you what torque and where it failed. I don't think 50 ft. lbs. is the number.
One thing is for sure. The information for the timing belt job should be annotated to include check both the camshaft and sprocket for damage and cleanliness prior to connecting them.
A new camshaft comes in cosmoline. I've always cleaned that off. But I do see grease or oil being a problem.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Old July 13th, 2008, 06:45   #28
radar912
I have never done a TB change on a TDI, have researched it here in reading many posts as will have one done in the future. My question is, has anyone ever damaged a camshaft with the higher torque settings? We have plenty of examples where things have gone wrong at the lower value, anyone snap a cam to date?
radar912 is offline   Reply With Quote
Old July 13th, 2008, 06:49   #29
joetdi
That bolt is to big I am sure it can handle the extra torque. Most bolts that size get a higher torque anyways.
joetdi is offline   Reply With Quote
Old July 13th, 2008, 07:32   #30
Drivbiwire
Zehntes Jahr der Veteran
I have personally seen the results of overtorqued cam pulley bolts. The bolt (grossly overtorqued) resulted in the cam shattering between the taper and #1 cam bearing when the pulley was removed on a subsequent timing belt (1Z motor).
The older procedure used a drift and hammer to knock the pulley off the taper. Since the pulley had been pressed onto the taper by way of over torqueing the bolt, the pulley caused enough offset force to crack the cam when it was removed with the drift/hammer procedure due to the higher force to remove the pulley from the cam.
Had the cam been torqued to spec, the pulley would have released off the taper and not broken the cam.
The other concern is deforming the pulley's female taper by way of overtorqueing the bolt. I would agree that a few ft-lbs of variation (+X/-0) may not result in damage, however just adding what you may "think" is ok may in fact result in deformation and damage to the taper resulting in a failure to maintain a proper mating to the cam's end taper.
The issue with the cam bolt is not the bolt! The issue is the angle that the taper is set at is the limiting factor. Increasing the bolt torque applies significantly higher force in respect to that generated by the two tapered surfaces coming together. The VW spec is not predicated on the limits of the bolt but the forces generated by the two contact surfaces of the taper.
The BEW uses a different angle thus a different torque spec is utilized. Additionaly, the PD uses a keyed cam to pulley so timing is maintained and assured via this method. The external pulley accounts for variation between belt production lots and uses three elongated bolt holes to adjust for any variation between timing belts. Also the BEW has to endure much higher rotational vibrations and forces due to the increased loads on the valvetrain by way of the PD system
Comparing the two is an apples to watermelons comparison and not valid.
The best advice is to stick with the VW spec!
DB
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Page generated in 0.17285 seconds with 9 queries
[Output: 135.93 Kb. compressed to 114.58 Kb. by saving 21.34 Kb. (15.70%)]
