Old October 6th, 2017, 08:43   #271
[486]
TDI(s): 02 golf ALH
Ah, that makes more sense. can get away with a lighter crank with the counterweight further from center
I balanced my big 7.25" clutch flywheel on a tire balancer, you can do calculated imbalance just the same way. Throw the stock fw on there, note the imbalance and position relative to the TDC mark (or any other reference) and then make the same imbalance on the new one with a drill.
[486] is offline   Reply With Quote
Old October 9th, 2017, 21:05   #272
Sausage
TDI(s): Lupo 1.4 TDI
Does anyone run the flywheel without the imbalance? if so do they leave the front crank counterweight pulley alone or remove that imbalance?
I have 228mm flywheel and clutch to go on, but wasn't going to be messing with the flywheel balance, but now think I might need to:
http://forums.tdiclub.com/showthread.php?t=343554
If so as suggested by 486 above you could stick the 3 pot flywheel on a bubble tyre balancer and put weights on it to balance it opposite the cut out, weigh the weights used and mark the location, then you know how much to remove on the 4 pot flywheel and where (directly opposite the weights location).
I dont have a balancer though....
Sausage is offline   Reply With Quote
Old October 10th, 2017, 08:21   #273
[486]
TDI(s): 02 golf ALH
I used the kind that spins the wheel and tire then tells you the imbalance on the screen.
No friends that work in auto shops? I'm sure any automotive machine shop around you would know someone that balanced flywheels, but they'd want like a hundred bucks. If Ruben says people run it without, it's likely fine and a small imbalance.
Old October 11th, 2017, 04:07   #274
Sausage
I'll try it without, just then wondered about the front pulley without the flywheel to match might be causing stress.
Old November 15th, 2017, 23:21   #275
Snuupy
Snuupy's Avatar
Hi guys, I have a offer for Garret GTB1549V for a very good price, what do you think about this turbo? They say is good for 200h.p. and spool faster than most VNT17 or VNT20 turbos? I know I need custom manifold, but this is not a problem
I have a an other question: Did you know the max fuel injection quantity of a PD75 injectors, now I'm running 55mg of fuel. Did they can handle more fuel - 60/65mg before they fail?
Snuupy is offline   Reply With Quote
Old November 20th, 2017, 12:56   #276
biohaufen
Hi Snuupy,
I ran about 70mg worth of duration with AMF injectors. (465cc)
So they shouldn't "fail" if you're running only 60-65mg.
biohaufen is offline   Reply With Quote
Old December 1st, 2017, 02:18   #277
Zaziki
@Snuupy i run also ~69mg of fuel throuh BNM(465cc) injectors, everthing is fine.
I've done a simple remap on a BNM Engine, now like always, i want a bit more power from it. I'm now at 1,3 bar boost pressure, but i think it will kill my clutch since this car has done 222.000km so far and i have clutch slip when i use my trailer (to be honest 1,3t).
So, is there any recommendation today, for a stronger clutch - or a plug 'n ' play gearbox ?
Zaziki is offline   Reply With Quote
Old December 8th, 2017, 15:21   #278
Welington K.
im going to try to put a 1.9 gearbox and clutch as so far its what everyone is doing not sure how much work will be involved in it, i already have the mounts for it, come new year and ill probably do it
Welington K. is offline   Reply With Quote
Old January 4th, 2018, 14:45   #279
Jowens
Default 1.4 tdi tuning
Has anyone fitted a pd130 turbo to a pd75 ?
Jowens is offline   Reply With Quote
Old January 4th, 2018, 15:12   #280
Rub87
should work well
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old January 12th, 2018, 16:21   #281
Welington K.
Ruben managed to get myself a 6 speed too straight out of a polo with everything i need !
finally gonna be able to see what sort of power we are making
Old January 14th, 2018, 07:16   #282
Snuupy
Snuupy's Avatar
@biohaufen - Thanks, cuz I got software with 60mg of fuel and 1.3bar of boost, without MAF, EGR OFF and etc.
@Zaziki - My mapper recommendet to me a G60 flywheel with Golf MK4 clutch.
Old January 28th, 2018, 15:12   #283
Welington K.
all is done boys got the 6 speed on and its working like a charm, little note to anyone thats planning on doing youll need to shave off some material on the engine mount the one in the left not to gearbox one as it wont line up next update is the dyno figures !
Old January 29th, 2018, 01:40   #284
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
Well done - looking forward to seeing what it makes.
Cheers
BSR
Audi A4 3.0TDI B8 - 505hp/980nm...
Bobby Singh is offline   Reply With Quote
Old January 31st, 2018, 14:31   #285
Chrislupo
Hi,
at the moment my lupo 1.4tdi amf (151.000km) has only a remap and
longer 4 (0.90) and 5 gear (0.65) with sachs performance clutch.
In 5th gear the car is not faster than before, but real quiet.
The car need more than a engine upgrade, but thats another thing...
Originally Posted by biohaufen View Post
Maybe this is interesting for some of you.
At the end of the month my 1.4 TDI is finally ready to get into my car again...
It has been bored to 81mm, got BHW pistons and H-style conrods...
Which headgasket you use?
I can´t find a solution, therefore i will use nüral+0,5 87-114907-46 from ARL.
Another question, which 1.4 tdi have these 50.85mm rodjournal?
http://rosten-performance.com/produc...rodbearingset/
My camshaft is not in very well condition, a upgrade would be nice,
but i cannot find one...
Can I cut a 1.9 tdi camshaft and make a slot for tandem pump?
From a lupo 3l 1,2 tdi I will use the vnt and the light body parts.
Injektor 038 130 073 AL from ARL or 038 130 073 ag with new nozzels.
At the end I hope to reach 150+ with no or little smoke
best regards
chris
Chrislupo is offline   Reply With Quote
Page generated in 0.14986 seconds with 9 queries
[Output: 123.45 Kb. compressed to 102.51 Kb. by saving 20.94 Kb. (16.96%)]
