Old June 30th, 2008, 15:05   #1
Jaco
Fuel Economy: 5.3 / 4.8 / 4.1
Default 1.4 TDI tuning/info
Hello,
Just bought a 2004 Polo 1.4 TDi .
This is a 3 cylinder engine (1422 cc) , 55Kw (75 HP) , I believe this is PD injection.
What type of turbo is stock on this engine? Is it a regular GT1544 or a VNT?
Full boost is at 2200 rpm , looks like a non-VNT to me.
What tuning options are there for this engine (besides a chip/box) ?
What's the max (reliable) power this engine can make?
thanks,
jaco
Jaco is offline   Reply With Quote
Old June 30th, 2008, 15:11   #2
mojogoes
TDI(s): mk3 tdi golf
Fuel Economy: not much
I'm not sure but it maybe the Gt12
A3 / mk3 golf with 249Whp "Now in the hands of someone else"
mojogoes is offline   Reply With Quote
Old June 30th, 2008, 18:46   #3
Bojje
I guess it would be pretty reliable if it's a PD130 just with one cylinder less
In that case, 140-150 hp without any internal mods should work.
Bojje is offline   Reply With Quote
Old July 1st, 2008, 01:00   #4
turbo johan
turbo johan's Avatar
It's more like a PD100 with 1 cilinder less.
The rpm's were the power is is very small.
With good chip it gets better.
With GT1749V or something you can make 120/130 hp with stonger clutch.
The it's a pretty fast car :-)
Johan
VW Golf 6 GTD 270 Hp & 490 Nm DSG
Lupo PD 280 hp & 500 Nm.
Fastest ET 13.1 sec 1/4 mile @ 178 km/h
turbo johan is offline   Reply With Quote
Old July 3rd, 2008, 11:43   #5
TorqueMonster
Hey! That looks like my last EKG chart!
TorqueMonster is offline   Reply With Quote
Old October 9th, 2008, 11:23   #6
Rub87
Johan
Hi Johan, do you have some info about which clutch to go for? Do you know why they took such weak one? if they kept the PD100 there would be zero problems, but it seems even with moderate torque it slips in the higer gears when the turbo efficiency peaks :2200-2500rpm
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old October 9th, 2008, 12:06   #7
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
Your car is equipped with WG Turbo, to swap in a VNT it needs a little more to do. To change to a VNT turbo you can use the device from Audi A2, 1.4l 90hp, and use basic mapping also from this car. Unfortunately the Audi Turbo is a kkk device so you cant do the easy compressor Upgrade with Garrett parts like with a Garrett turbo. I was searching for bigger compressor for the Audi Turbo but couldnt find until now. Anyway you should be able to see about 110hp with the conversion to the Audi device plus chiptuning.
You can also use PD Injectors from ASZ or ARL for further gain.
Greets Alex
Seat Leon Cupra R MK1, VW Polo 1.9TDI ASZ
majesty78 is offline   Reply With Quote
Old October 9th, 2008, 12:09   #8
Rub87
I'd just go for a gt1749v or kp39a and cut the 4th runner off the manidolf, other DP flange and it's done..
Old October 9th, 2008, 12:40   #9
TheoSweden
TheoSweden's Avatar
Tomorrow I'm probably buying a Polo just like the threadstarer have! And I have my ASZ manifold laying around... NO this car is going to be stock! maximum remapped:-)
//Theo
TDI Project: VW Golf 1 - 83
Track/Ice racer: Audi A3 TDI Q - 02 ~280hp
Daily driver: Audi A4 TDI Q - 08 ~300hp
http://65.110.12.166/showthread.php?t=378371
TheoSweden is offline   Reply With Quote
Old October 9th, 2008, 12:45   #10
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
Dont forget: OE is Wastegate, gt....v or kb39 is VNT !
Old October 9th, 2008, 14:10   #11
Rub87
I know, thats the point.. use the base file you mentioned..
you can use 90hp WG turbo, which will also flow 20hp more, but spoolup is with the tiny WG oem turbo already at 2000 rpm.
Code:
Saturday,04,October,2008,14:17:26045 906 019 BF ,,1.4l R3 EDC G000SG  5179,,Group A:,'011,,,,Group B:, Not Running,,,,Group C:, Not Running,,RPM,Absolute Pres.,Absolute Pres.,Duty Cycle,,,,,,,,,,,TIME,,,,,TIME,,,,,TIME,,,,MARKER,STAMP, /min, mbar, mbar, %,STAMP,,,,,STAMP,,,,,0.39,1617,1662.6,1091.4,24.7,,,,,,,,,,,0.78,1659,1723.8,1162.8,24.7,,,,,,,,,,,1.17,1722,1785.0,1224.0,24.7,,,,,,,,,,,1.56,1785,1876.8,1305.6,24.7,,,,,,,,,,,1.95,1848,1958.4,1397.4,24.7,,,,,,,,,,,2.34,1932,2060.4,1499.4,25.1,,,,,,,,,,,2.73,2016,2162.4,1621.8,24.7,,,,,,,,,,,3.12,2121,2233.8,1805.4,30.7,,,,,,,,,,,3.51,2268,2244.0,2060.4,39.4,,,,,,,,,,,3.90,2436,2244.0,2274.6,44.6,,,,,,,,,,,4.30,2625,2244.0,2284.8,47.0,,,,,,,,,,,4.69,2709,2244.0,2264.4,47.0,,,,,,,,,,,5.08,2814,2244.0,2233.8,47.4,,,,,,,,,,,5.47,2919,2244.0,2264.4,47.0,,,,,,,,,,,5.86,3024,2244.0,2254.2,47.0,,,,,,,,,,,6.25,3129,2244.0,2254.2,47.4,,,,,,,,,,,6.64,3234,2203.2,2203.2,47.8,,,,,,,,,,,7.03,3339,2193.0,2223.6,49.0,,,,,,,,,,,7.42,3444,2182.8,2162.4,49.4,,,,,,,,,,,7.81,3549,2172.6,2182.8,50.2,,,,,,,,,,,8.20,3633,2162.4,2182.8,51.0,,,,,,,,,,,8.59,3738,2152.2,2142.0,51.4,,,,,,,,,,,8.98,3801,2152.2,2121.6,51.4,,,,,,,,,,,9.37,3906,2091.0,2121.6,52.2,,,,,,,,,,,9.76,3990,2029.8,2111.4,53.8,,,,,,,,,,,10.15,4053,1999.2,2060.4,55.4,,,,,,,,,,,10.55,4116,1509.6,1887.0,91.6,,,,,,,,,,
This is log of remapped car.. notice the quite "slow" spoolup..
Somehow I'm too stuped to post the log well :/
Old October 9th, 2008, 15:48   #12
Rub87
The car was a VW Polo 75hp version, engine code: AMF
It suprised me that the oem file spiked already 2300mbar while requested was around 2090mbar..
NOTE: MAP and RPM are switched on the axic by axident..
Old October 9th, 2008, 15:51   #13
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
Dawes Device Boost Controller could help to clean up such spiking, isnt it?
Old October 9th, 2008, 16:07   #14
Rub87
A remap too.. as you see the modded log almost has no spiking I first tought there was something wrong with the actuator/N75, but when just spending 5 minuts with the N75 map it didn't spike 50mbar..
The oem file in that car was really one of the ugliest I've ever seen.. it spikes, car was slow.. All of the duration maps had antoher size ..
Old October 9th, 2008, 16:10   #15
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
Yes sure such things can be cured with a good remap.
I just wanted to request if this dawes device would really help *g*
Page generated in 0.16858 seconds with 9 queries
[Output: 124.95 Kb. compressed to 103.55 Kb. by saving 21.39 Kb. (17.12%)]
