Old June 28th, 2008, 16:05   #1
Greaseburger
Greaseburger's Avatar
Fuel Economy: Best of 53.8
Default Location of cruise control fuse in 96 B4?
My cruise conrtrol recently stopped working and I figured good place to start would be the fuse but since none are marked cruise in the panel I am not sure where it is, can anyone help me find it?
99.5 Jetta, RC3,Veg .216, Omi,Bilstein Tc sport 2 1/2''Exh no cat,no muff,Longbeach,Euroswitch,fogs front&RearDepo HL
Greaseburger is offline   Reply With Quote
Old June 28th, 2008, 17:44   #2
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
There isn't a separate fuse. What else has stopped working?
Confirm the brake and clutch switches are operating (closed with pedal up, open circuit pedal pressed) confirm the activate switch in the stalk is functioning to "set" a speed. Those have been the most common locations for 'failures' in mine.
p.s. I still have the lower engine cover for that A3. Want it?
Svante Arrhenius 1896
Old June 28th, 2008, 17:49   #3
Greaseburger
I will have to do some poking around then, sure I will take the lower cover, did you install nozzles in that A3? it feels pretty zippy
Old June 28th, 2008, 18:57   #4
redtdi966
I've been told it is incorporated into the ECU unlike the gasser. My 95 gasser has it in the shift console.
bruce
2003 jetta wagon 4-cyl , 2012 jetta sedan auto gassers -- Done with diesels "cost of ownership"
redtdi966 is offline   Reply With Quote
Old June 29th, 2008, 07:39   #5
rdkern
Fuel Economy: A4 = wife drives it, don't know
When the cruise stops working, you should get out the VagCom and test to see what isn't working.
Could be brake switch, clutch switch, or cruise switch.
Since the TDI is drive by wire, it's entirely controlled by the ecu.
If you haven't seen it, try wingnut's writeup.
Whitedog's in progress no-start link. http://forums.tdiclub.com/showthread.php?t=199398
Read all about it!
rdkern is offline   Reply With Quote
Old June 29th, 2008, 07:53   #6
VWWV
Fuel Economy: 48hw/36town
[quote=Greaseburger]My cruise conrtrol recently stopped working and I figured good place to start would be the fuse but since none are marked cruise in the panel I am not sure where it is, can anyone help me find it?
Search this one out. About 2 years ago my cruise stopped working and I found a post that outlined (with pics) how to remove the slide switch and squirt some WD 40 in there. Worked like a charm and it took maybe 30 seconds. Still working. p.s. I'd have searched for you but I'm on dial-up.
96 Passat TDi Candy White 100 K. mi, ventectomy, cat injector disabled.
WV - where relativity is more than just a theory.
TERM LIMITS NOW
VWWV is offline   Reply With Quote
Old June 29th, 2008, 14:03   #7
Lug_Nut
Lug_Nut's Avatar
Originally Posted by Greaseburger
...sure I will take the lower cover, did you install nozzles in that A3? it feels pretty zippy
Those were in there when I bought it. I chalked up the performance level to the A3 being that much lighter than the B4V.
BTW, I got a B5.5V as a replacement to the A3.
Old June 29th, 2008, 16:20   #8
Greaseburger
Wanna sell it cheap?I have another kid ready how about some pics.
Old June 30th, 2008, 05:04   #9
Lug_Nut
Lug_Nut's Avatar
Like marriage, I won't make that mistake twice!
Pictures are in the member's photo gallery down a few catagories.
Old June 30th, 2008, 13:33   #10
Greaseburger
Very nice Jon!! see you just needed a reason to upgrade
Old July 10th, 2008, 13:13   #11
james43
Fuel Economy: 60 mpg (UK gallons)
Hi All
I have a '96 B4 TDi passat (1z) and was wondering if the only part needed to add cruise control was the stalk, and then plugging it into a vag-com to recognise it.
Do I need other parts to 'retro-fit' it or are they already on the car?
Thanks,
james43 is offline   Reply With Quote
Old July 10th, 2008, 13:16   #12
james43
oh and does anyone have a part number (assume they will be the same in Europe)
Old July 10th, 2008, 13:56   #13
Chris Bell
UK/Euro cruise control retrofit
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Chris Bell is offline   Reply With Quote
Page generated in 0.14413 seconds with 9 queries
[Output: 109.84 Kb. compressed to 91.20 Kb. by saving 18.64 Kb. (16.97%)]
