Old June 24th, 2008, 06:44   #1
rsiegfried
Talking 2006 Jetta TDI Air Filter Change
Perhaps a dumb question:
How do you change the engine air filter on a 2006 Jetta TDI?
I use the Bentley on-line manual but can't find a description of the procedure.
rsiegfried is online now   Reply With Quote
Old June 24th, 2008, 11:04   #2
alphaseinor
lot's of screws... open box, vacuum, wipe, place new filter, then follow the numbers on tightening the screws...
Since you are on a 20k service, why not do the fuel filter and cabin air (not to mention the oil and filter).
The cabin air is easy, unscrew the two plastic screws that hold up the foam peice under the passenger's side dash. pull the foam out, pull the tab on the filter case, and slide the cap off, pull the air filter out, replace.
as for fuel filters, I can't remember if the '06s have two different types or not... maybe that was the 05.5's... one you'll have to pry up, the other pulls off like your oil filter.
alphaseinor is offline   Reply With Quote
Old June 24th, 2008, 15:48   #3
2004STARWARSTDI
2004STARWARSTDI's Avatar
Post Air filter
Use the stock paper filter. Do Not replace with a K&N or any oiled air filter! An oiled air filter will kill you MAF!
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old June 24th, 2008, 15:56   #4
airwolf
airwolf's Avatar
TDI(s): None
Originally Posted by alphaseinor
.....as for fuel filters, I can't remember if the '06s have two different types or not... maybe that was the 05.5's... one you'll have to pry up, the other pulls off like your oil filter.
06's have two different types. It is based on your VIN number.
_-Airwolf-_
2014 F-150 AKA-Ruby
TDIFest2009 Organizer! | TDIFest2012 Organizer!
airwolf is offline   Reply With Quote
Page generated in 0.12564 seconds with 9 queries
[Output: 61.43 Kb. compressed to 54.73 Kb. by saving 6.70 Kb. (10.90%)]
