Old March 31st, 2009, 09:45   #31
Jacob G
Jacob G's Avatar
stunning i really like it! great job, very clean.
Jacob G is offline   Reply With Quote
Old March 31st, 2009, 09:58   #32
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
Nice numbers. I've never seen a dyno plot like that before. What's with the flat spot in HP after the torque peak around 3000 rpm? Is that something that can be tuned out, or is it a function of airflow?
UFO is online now   Reply With Quote
Old March 31st, 2009, 12:51   #33
fenwick458
fenwick458's Avatar
not sure about the dyno plot, but i think it's probably an overcalclation of the torque, and the bhp is derived from the torque (BHP = LBFT X RPM / 5252) so in reality it would be less of a torque spike, and thus the power curve would smooth off a bit.
although it could be correct, i just don't know. alot of mappers over here always complain that is hard to smoothly map with one of these turbos and a 2.5" exhaust as they spool so quick, so i guess it could be.......
fenwick458 is offline   Reply With Quote
Old April 10th, 2009, 02:38   #34
fenwick458
fenwick458's Avatar
front and rear resprayed, rear end swapped to discrete tailpipes because there was too much soot on my rear!
Old April 10th, 2009, 16:07   #35
bschlatt
bschlatt's Avatar
Fuel Economy: 45
Default Siver
Looking good bro!
bschlatt is offline   Reply With Quote
Old April 10th, 2009, 16:09   #36
bschlatt
bschlatt's Avatar
Fuel Economy: 45
Default Silver
Put in on a set of KW coilovers and you wont have to slow down for the corners...
Old May 16th, 2009, 15:19   #37
fenwick458
fenwick458's Avatar
Eibach 25mm ARB's fitted now, don't need to slow down for corners!
Old May 17th, 2009, 12:29   #38
daztdgti
daztdgti's Avatar
Fuel Economy: 55 mpg
looking very nice bet it fast to.
Q want type of oil breath catcher you got no it matey
daztdgti is offline   Reply With Quote
Old July 16th, 2009, 13:59   #39
ryanp
ryanp's Avatar
did you end up fitting the Mk5 fuel filter setup? I'm struggling to get one from anywhere but i'd like to know if it's worth messing around for??
Ryan
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old July 16th, 2009, 14:17   #40
Sootman
Sootman's Avatar
Fuel Economy: 30 +/- MPG
Very nice, very clean and the HP and torque numbers are excellent. The only downside I can see is that your mechanic somehow swapped the steering wheel to the wrong side .
Great looking inside and out!
Sootman
A friend will help you move. A good friend will help you move a body.
Audi Quatro A3 gasser. Hey is it my fault I can't buy a diesel Quatro??
http://www.idparts.com/catalog/index.php
Dyno: http://forums.tdiclub.com/showthread.php?t=352348
Sootman is offline   Reply With Quote
Old July 18th, 2009, 04:58   #41
fenwick458
fenwick458's Avatar
thanks for the comments!
yeah i fitted the Mk5 fuel filter, i can't say i noticed a difference though! i got it for a tenner in the end, and a new filter was 13 quid from GSF.
Old November 1st, 2009, 08:20   #42
fenwick458
fenwick458's Avatar
new map from RS tuning
and yes i know it has lower figures than the last map but that is probably because the previous dyno a hub dyno and the figures it produces are on the high side
Old November 10th, 2009, 05:10   #43
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
Hi Stu looking good mate - whats your smoke levels with the new map? and what whp did it make?
Cheers
Bobby
Bobby Singh is offline   Reply With Quote
Old November 12th, 2009, 09:07   #44
fenwick458
fenwick458's Avatar
hi bobby,
the smoke levels are ok IMO, if i stamp on it low down it belches black smoke, it i roll onto the accellerator (most of the time) then it's a grey haze that is quite hard to see unless it's in car headlights or certain light conditions. but at the minute it's quite dark in th daytime here and this is only what i can see from my rear veiw! it looks rediculous at night in car headlights that are behind me, but it's not really that visible otherwise. the back is not covered in soot anyway, and i think it smokes less than some maps i had with a GT1749Vb turbo so it's ok in my books.
it's also nice to drive, it has plenty of response low down and does not smoke loads or surge onto the power when i'm trundling around town which i have had for the last few months, which was probably down the the actuator being out of adjustment
Old November 12th, 2009, 14:28   #45
fenwick458
fenwick458's Avatar
and here is the WHP and boost:
Page generated in 0.15591 seconds with 9 queries
[Output: 121.46 Kb. compressed to 100.62 Kb. by saving 20.84 Kb. (17.16%)]
