kooyajerms
grocery getter
- Joined
- May 5, 2004
- Location
- Pomona, Southern California
- TDI
- 97 B4V (mine), 11 x5 35d (hers) 04 V10 (that one you want), 2014 Q7 (mom's) 74 Shasta 1400
So I had my scangauge callibrated to my system with PP520's. was working nicely and proving the same MPG as my written numbers. Even when I had stock injectors, the numbers were the same and still callibrated.
engine: 1.9
fillup: % at -18%
tank: 25 gallon
speed: 2 (makes SG callibrated with mileage, not with actual speed due to larger tires)
then i got alligatored (not done tuning at the moment). but my callibration is way off. Getting it inline has proven to be more difficult than just changing the fillup %. depending on load, the numbers are showing to be way off. Cruising is producing more efficient numbers than I am getting. Trying to reduce the % to -25% causes high load numbers to be very low in MPG but at cruising load (which for me is about 40) I'm getting WAY efficient MPG. So I thought, maybe I should change my engine type. move it up from 1.9 to a 2.5 engine... and find something that creates a callibrated system.
I'm getting closer, but I'm still getting screwed on cruising speeds. my cruising is not producing as much MPG numbers as SGII is showing.
engine: 2.5
fillup: % at -25%
tank: 25 gallon
Did anyone else move from non chipped to chipped? and how did you change your callibration? Obviously I can try to adjust to just get it to my numbers, but cruising on the fwy is causing my numbers to jump on the SGII.
1997 passat stationwagen FA chipset, 1Z. PP520's
engine: 1.9
fillup: % at -18%
tank: 25 gallon
engine: 2.5
fillup: % at -25%
tank: 25 gallon
