| TDIFest 2008 Discussion about TDIFest 2008 that was held in Mason, OH on the Labour Day weekend (August 29th - August 31st, 2008) . |
August 24th, 2008, 16:58
#31
Good Ol' Boy
Fuel Economy: see signature
Good plan. Make sure to take into account for new EPA ratings vs. old EPA ratings.
August 24th, 2008, 17:17
#32
If everyone who is going to participate will let me know what vehicle they are driving, I will look up the EPA figures.
August 24th, 2008, 18:31
#33
Pre-Forum Veteran Member
Fuel Economy: Which VW diesel? There have been Twelve of them!
2005 Passat TDI wagon: 27 mpg c / 38 mpg h.
Svante Arrhenius 1896
August 25th, 2008, 07:19
#34
Sprockette's hubby
The "New" EAP MPG for both of our cars are now 23 c / 34 h. It's a shame that uninformed potential TDI buyers will see these new figures and think to themselves that it's not worth the extra money for diesel at those numbers. If they only knew what we already know.
Put me down for a 2005 Passat TDI sedan. I'm going to leave 2 days early and have my wife push the car all the way there  No really, I'll be using B20 like always.
2005 B5.5, TD Tuning, R783's, GTB2260VK, 6 speed O1E, BSM 2/09, Pod w/ 40 PSI & EGT Gauge, Thor Skid Plate, Cat FF, Euro switch
1996 B4V, 17/22, RC6, PP520's, .622 5th, Colt Cam II, Ecodes W/leveling motors & Euro switch, fog lights, Bilstein TC's, Cat FF, Whitbread 2.5" DP, exhaust, FMIC, APR
August 25th, 2008, 13:53
#35
And I was thinking the '05 figures were the new, revised ones.
23 / 34 / 28. Sounds like Twiggy at 8 months!
August 25th, 2008, 15:57
#36
Fuel Economy: 70.6/ 51/ 38
I'm In!
1997 Passat TDI: "old EPA numbers were 38/47; "new" numbers are 32/42. What a joke! The "new" numbers are so unrealisticaly LOW to satisfy complaints from "chuckleheads" that drive 90 mph and then blame the EPA for "misleading" estimates. I'm in on the contest, and will blow the "new" numbers into the next solar system!
1992 Mazda MX-6 (totaled by senile Honda driver!)
1997 Passat TDI
1999 Mercedes Benz E300 Turbodiesel
2005 Passat PD TDI
August 26th, 2008, 04:20
#37
Fuel Economy: 69.63/47/36
See my sig. Coming from the Twin Cities area, driving largely at night to avoid heavy Chicago traffic.
August 26th, 2008, 11:57
#38
Great, looks like we will be having a great event.
August 27th, 2008, 09:32
#39
Gadget Guy
Just so everyone knows, the 1st placer in this also gets an award presented to them at the banquet.
-J
August 27th, 2008, 19:49
#40
Veteran Member & HO5G CoFounder
Fuel Economy: 49/47.5 - 51 mpg once!
I'm beginning to understand the hardships the TDI fraternity ....
Fraternity? Are you forgetting about us club members with X chromosomes?! Or are you just implying that girls aren't silly enough to compete in a mileage competition...(which would be a perfectly reasonable explanation for your discriminatory faux-pas.)
BUG*PWR 2008
1999 Golf - ...mmmmm, diesel-licious!
1965 Plymouth Barracuda - 225cid of Fishey fun...
August 27th, 2008, 21:55
#41
Fuel Economy: B4:∅, ECO:45+
Oh, ok
I see the double standard here.
Gonna keep those X chromosomes all to yourselves, eh?
'92 Jetta GL ECOdiesel 1.6TD 1v K14
'96Passat GLS TDI 1.9td AHU
'13 Passat TDI-SE 2.0td
die über das Angebot Angst vor schlechten Wolfsburg?
August 31st, 2008, 06:19
#42
Here are the numbers
Name_______________MPG___vehicle_________%EPA
bestmapman_________68.4___06 Jetta 5sp_____207.2
jasonh______________53.2___05 Passat auto___198.9
Lug Nut_____________50.2___05 Passat auto___185.9
BRUSSELS BELGIAN____65.9___97 Passat 5sd____183.0
TD__________________53.1___04 Jetta 5sp_____147.5
Ecodean_____________55.05__02 Golf 5sp______144.8
vikingrob_____________46.5___04 Beetle auto___140.9
September 1st, 2008, 19:48
#43
Just ran a full tank for the Fest. Filled with b11 in Waukeegan Il and returned to the same station with 783 miles on the OD. Pumped 14.33 (I think, not in front of me right now).
Not bad at all considering I was upward of 90 a few times keeping up with Jason's trailer so I could draft!
Lots o fun, easy trip back to WI. Almost zero traffic and not a stop through Chicago for the first time in my life. Skipped the bypass but cutting 30 to 394 just by luck. Perfect.
Hope every one makes it home safely.
Tony B
TDiTony
September 1st, 2008, 20:59
#44
I just did my calculations of my drive to the Fest and then back home. (Toronto Ontario Canada)
1090.4 km traveled before refueling just outside of Bowling Green on way back to Toronto
14.186 U.S. Gallons used
<Insert Math here>
Results:
4.925 Liters per 100 kilometers
or
47.76mpg
2001 Jetta Automatic with PP520 injectors and RC3 Tune (275,580km or 171,237miles on the OD)
First time I went over the 1000k mark on a tank
MrVermin
2001 Jetta TDI: 6speed ERF swap, SB Endurance+ clutch W/30lbs SMF, RC Tuned, Race520's, Colt Stage2 Cam, PD150 Intake, PD150 RacePipe, VNT17/22, OMI, 3" Full Exhaust, 3BAR MAP, 11mm IP, Defender Skidplate, 17" Ariettas, GLI Suspension, Audi TT LCA Bushings,
September 3rd, 2008, 11:51
#45
Good Ol' Boy
39.5 MPG on the way home in the ECOdiesel (through the mountains, traveling ~3500 rpms @ 70 - 75 mph the whole way).
