Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Old April 9th, 2010, 06:42   #271
NL-TDI
TDI(s): 06 Jetta
A question for someone who has done this procedure:
When I re-tightened the 3 sprocket bolts, I was very nervous about breaking them, mostly because reading this thread I learned of someone else who broke them. So what I am wondering is how tight do the bolts get? To me it seemed like they were turning back in more then they turned coming out and I was scared to go too tight and twist off the bolt. I do have a torque wrench howeven not sure if I trust it. It is in in-pounds and NM. According to a online conversion 18 ft pounds is 24 NM but as I said the bolts seemed to be turning back a lot and not getting real tight. Any insight would be appreciated.
tks
2006 Jetta TDI 5 spd pkg 0
NL-TDI is offline   Reply With Quote
Old April 9th, 2010, 06:50   #272
DanG144
Fuel Economy: 41 around town, 52 interstate at 70mph, 50+ for the first year.
You might buy new bolts if you are concerned.
These never had TTY bolts in them, but someone could have installed TTY bolts from an injection pump by mistake, though it seems a low probability event.
And try a different torque wrench.
I have never had any issue with using 18 ft/lb.
Watch your pulley to ensure it is running true. If you backed the bolts out too much it might have slipped out of place just a tad, and no longere be tight and square on the hub. Again, this does not seem too likely.
VAG-COM diagnostic system (now have CAN bus, too) PM or Email me.
2005 Jetta GLS, manual 5 spd, RC 1+ tune, DieselGeek bypass oil filter, Caterpillar fuel filter, OEM steel skidplate, Bosal trailer hitch, whitedog's intake hose clamp.
2010 Jetta, Car Oct 2009 Engine Sept 12, 2009, DSG
Old April 9th, 2010, 11:03   #273
NL-TDI
TDI(s): 06 Jetta
ok guys......did a lot of test driving today and the car purrs like a kitten!! never ran smoother, every time I stoped at a red light I was waiting for the roughness but it never came.!!!!!..........Went to Advanced Autowerk's in Ottawa and got Gord to check the timing with their computer. This guys are great....highly recommend them to anyone who needs help with there VW!!!!!! I Was quite happy to see a reading in block 4, value 4 of..1.4kw .....I think this is in the acceptable range and I'm quite happy with the way its running so I am going to leave it there. Not interested in fixing it till it's broke....LOL.....Thanks to everyone who posted on here with this great info...
Jon
Old April 9th, 2010, 11:47   #274
zanzabar
zanzabar's Avatar
Jon
Lucky guy! Glad your 'intuition' on setting that cam was good. Still, this is in no way justification for doing this 'repair' blind like you did. In other words: DON'T TRY THIS AT HOME! I think 1.4 should be fine, I have mine at 2.0 I think.
His: 1994 Volvo 850 NA wagon
Hers: 2009 Honda Fit 5spd
I'm available for TDI work in the North Bay area.
zanzabar is offline   Reply With Quote
Old April 9th, 2010, 11:51   #275
NL-TDI
TDI(s): 06 Jetta
Thanks...I think.....LOL.....sometimes you do the best you can with what you have and hope for the best...I won a free coffee today too so must be my lucky day!!
Old May 30th, 2010, 14:19   #276
okie
TDI(s): 2003 Jetta
Default Torsion Always shows 0.0
So I got a 06 BRM Jetta and checked the 4/4 value and it was 0.0. Cool, a week later I changed the timing belt and checked again, 0.0. I went 1,000 miles to let the belt strech and checked, 0.0. So I moved the CAM just a bit clockwise. It runs better, smoother, checked the 4/4 value and it's 0.0!
My first guess is the CAM position sensor G40 (or wires) are toast. Checked codes and found a G40 code set.
If the G40 is out will the torsion value always show 0.0?
2003 Jetta GLS 5 speed. Kerma Tune, PP520, FDS w/SoftSport Stage II Cutch
okie is offline   Reply With Quote
Old May 30th, 2010, 18:45   #277
DanG144
I am not positive, but I think if it is out of range, it reads 0.0. This is a terrible way to build it, but I think it works this way.
I know one person who went all the way to the end of the slot, and it read 0.0, and it ran like crap. When he got it closer to right then it started displaying realistic numbers.
I think it is showing the substitute number that the ECU is using - zero - when the sensor has failed.
Old May 30th, 2010, 19:31   #278
okie
TDI(s): 2003 Jetta
A little more info, went for a test drive (runs great BTW) and the torsion values never moved from 0.0 I did WOT under load, no load, everything I could and the torsion value never changed.
Old June 5th, 2010, 15:35   #279
okie
TDI(s): 2003 Jetta
Default MFD Changes??
Originally Posted by Hurst89
I have mine set at 4.9 hot idling. I also got my best mpg on a tank the other day since installing my new wheels (a year ago). I managed to get just under 45 mpg with about 80-85% highway travel going an actual 75ish mph. Before, the most I could get out of a trip like this would be just above 42 mpg, so a 2.5 mpg gain or more is what I have gotten on one tank, but I am not sure how good of data that is. I will know a little better this summer when I get to driving around some more on the open road. My MFD is really low now though, reading around 5 mpg low compared to the 1 or 2 mpg high it was reading. Has anyone found where the timing limits are in the Bentley manual?
Hurst
So, (I know this is an old quote) did the timing adjustment change the MFD readings or had you done something else to the car?
Old June 6th, 2010, 10:42   #280
Hurst89
If I remember correctly, when I changed the timing, the fuel mileage indicated on the MFD also changed. I can't remember what caused it to read high or low (advancing or retarding), but I am pretty sure it changed the mpg figure. I think this is due to the way the computer measures fuel being injected, and a camshaft timing adjustment changes the profile of the cam the injector rocker is riding on at a given time in the engine's rotation.
Hurst
2005.5 Graphite Blue Jetta TDI, SpeedTuning Stg2 w/EGR delete, cam timing adjustment. 5spd, 70,000 miles on my DMF (I think I'm reaching the end... lol)
Hurst89 is offline   Reply With Quote
Old June 7th, 2010, 00:19   #281
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
Hurst, you are right, when the timing is adjusted, it effects the reading in the MPG...I noticied this as well...
Got mine set at 0.0...Remember this setting/adjustment accomplishes 2 things, changes the cam/crank relationship(cam timing), and the ignition timing... So not to change the relationship of the cam timing, I would recomend setting straight up at 0.0....
http://www.rsbdiesel.com/
2006.5 DE DSG, RC2, Sunroof, Rear airbags, 73K miles, 61MPG best.
2005.5 Jetta-5 SP, LSD, Spec S2, 110K, 48 mpg every tank. Best-49.3 mpg-LOCAL. ELF 506 0-30W/15K OCI/37PPM FE, Best=740 MPT, RSB Diesel custom 2.5DP/3" SS exhaust, Synthetic fuel, Koni lowering springs. One of the first Mark V Jettas to hit the street. Pkg 1, MFD, Autowipe, Auto-headlights, Auto-dim mirror, auto-climate. 248C=150HP RC2
2004 6L 89000 19MPG
2000 7.3 388 HP-818 FT lbs Propane
Mach1 is offline   Reply With Quote
Old June 16th, 2010, 09:18   #282
Dunno513
Dunno513's Avatar
Fuel Economy: 44.3 lifetime
Originally Posted by DanG144
Besides, your timing sounds perfect as it presently is set. I think 0.0 to 0.5 is the best setting.
This is what mine is set to but I notice it flickers from 0.0 to 0.5 depending on power application. Just got done with a timing belt. Anyone else notice theirs changing while driving?
I suspect that I am right on the cusp in regards to the sensor position. It is 0.0 while under power and changes to 0.5 while coasting or idling.
Dunno513 is offline   Reply With Quote
Old June 16th, 2010, 09:39   #283
DanG144
This is normal.
Old June 16th, 2010, 09:46   #284
Dunno513
Dunno513's Avatar
Thanks... Just a bit nerve racking after having JUST done the TB 5 miles prior....
Old July 31st, 2010, 14:11   #285
sk8rdi16
Fuel Economy: Best 52
Send a message via AIM to sk8rdi16
Can anyone confirm this? I get a reading of 0.0 but the engine is running VERY bad. Missing, bucking, and tons of black smoke. Just hoping it's the cam timing before I put a new cam in!
'01 Golf GLS TDI 5sp Jetta Front
sk8rdi16 is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.11274 seconds with 9 queries
[Output: 121.38 Kb. compressed to 99.99 Kb. by saving 21.38 Kb. (17.62%)]
