Old May 15th, 2008, 19:12   #1
TimboTA
Fuel Economy: 47.3
Question ABS sensor wiring clip broken
Hi all -
After having a wheel bearing replaced (for the second time - the first was faulty), I started getting an ABS code - intermittent signal fault on the driver's front. I investigated that ABS sensor's wiring and it turns out the clip on the wiring is now broken, so I suspect it is getting slightly dislodged under certain conditions, and the ABS will kick in for no reason sometimes; others the light will just come on.
I'm trying to get this squared away since I also need to get an alignment and figure out a strange knocking noise under slow, light braking that started after replacing the front brakes.
Does anybody have any ideas of how to keep this wiring clamped together? The clip is broken both on the sensor and the wiring side. I suspect a ham-handed mechanic.
2003 Jetta Wagon TDI...SOLD! 9/12/2008
Moved on to a vehicle not listed here.
1996 Trans Am....I miss our daily drives
TimboTA is offline   Reply With Quote
Old July 25th, 2008, 17:52   #2
TimboTA
Fuel Economy: 47.3
Default Ok
Ok - I'm in the process of using small wire ties at the moment - nobody's ever had one of these break?
Old July 26th, 2008, 13:34   #3
mjghh
Default clip
thats about all you can do short of replacement..................I safety wired mine on after I errrrr hammed it.................pretty cheesey plastic connection to begin with ,but my safety wire job is bulletproof!
mjghh is offline   Reply With Quote
Page generated in 0.11425 seconds with 9 queries
[Output: 52.83 Kb. compressed to 47.64 Kb. by saving 5.20 Kb. (9.84%)]
