Old May 12th, 2008, 18:03   #1
dan30thz28
dan30thz28's Avatar
Default Cabin Air Filter 2002 Jetta TDI
Hi,
In the how to section, I saw that there was a diagram with pics on how to change the cabin air filter on the older jetta and the new beetle. Is the cabin air filter in my car located in the same area? Thanks, and I look forward to your responses, as I'd like to replace this myself.
Sincerely,
Dan Maldonado 2002 Jetta GLS TDI: 5-speed, BW BV39 VNT 17, PD 150 Intake, DLC 1019 injectors, Malone Stage 4, .658 5th gear, New South EGT and Boost Gauges, Panzer skid plate & Ventectomy.
dan30thz28 is offline   Reply With Quote
Old May 12th, 2008, 18:12   #2
Fahrfuwerfuelen
Fahrfuwerfuelen's Avatar
Dan
Pretty sure it's on the passenger side by the firewall. PITA to get out unless you have small fingers and hands.
Fahr
'05 Jetta TDI (A4), 5 spd. Manual
Fahrfuwerfuelen is offline   Reply With Quote
Old May 13th, 2008, 16:41   #3
dan30thz28
dan30thz28's Avatar
Hello,
Can anyone else verify this? Thanks! I'm sure it would save me a lot to do it myself.
Sincerely,
Old May 13th, 2008, 16:43   #4
joetdi
under the right wiper outside the car
joetdi is offline   Reply With Quote
Old May 13th, 2008, 20:42   #5
rdkern
Fuel Economy: A4 = wife drives it, don't know
I kinda think it's changed from the engine compartment by taking off the rain shield under the passenger wiper. At least that's what I remember doing in our 2000 Jetta.
Whitedog's in progress no-start link. http://forums.tdiclub.com/showthread.php?t=199398
Read all about it!
rdkern is offline   Reply With Quote
Old May 14th, 2008, 07:40   #6
paramedick
paramedick's Avatar
Ask and ye shall receive.....
http://pics.tdiclub.com/data/517/113...ter_change.pdf
Old May 14th, 2008, 14:55   #7
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
Originally Posted by paramedick
__. Yeah, the secret is that it's impossible to get that cover off . It's kind like the puzzles with a ring on two horseshoes that are linked together with chain. You can fiddle with them for a while and you're sure that the ring will never come off then you get the "combination" and it works easy. And once you get the cover off, it's a pure b!tch the first time you try to get the actual filter element clipped into the holders for it. But keep trying - once you get the combination, it's easy.
MrG, Wallace NC (2002 Jetta, Totalled by drunk, 11/'06) 130K mi in 4 1/2 years/~57 MPG lifetime; New car, '03 Jetta Wagon, CAT filter, .681 top gear, 270K mi. in 8 1/2 yr, ~52
mrGutWrench is offline   Reply With Quote
Old August 25th, 2009, 14:22   #8
Spirit76
TDI(s): 02 Jetta
Thumbs up Re Caf
Thanks very much
Couldn't find anywhere
R
Spirit76 is offline   Reply With Quote
Page generated in 0.13946 seconds with 9 queries
[Output: 81.75 Kb. compressed to 69.75 Kb. by saving 12.00 Kb. (14.68%)]
