scooperhsd
This is a month by month record of mileage. Every time you make an entry it will be added up and recorded together according to the fuel type and car/year you are driving.
THIS IS NOT intended to be an individual tank record (or a partial tank record for that matter). So if you want to wait and post all of your tanks in MAY at once, it would be greatly appreciated . Multiple tanks per posting acceptable as long as all are in exact format. One tank at a time is also acceptable. If you are going to report on different days - do not go back and edit a previous post - just put it in as a new one.
Entries will be accepted until JUNE 5th, but remember, report tanks FILLED IN MAY ONLY .
Posts not in format will not be tallied / corrected
Entry Format:
Driver:
Miles:
Gallons:
Model Year:
Model:
Tranny:
Fuel Type:
(anything else you would like to add)
US GALLONS AND MILES
TRANNY TYPES:
(x) A = x speed automatic
(x) M = x speed manual *
DSG = direct-shift gearbox
CVT = continuously variable transmission
* if you have swapped in a taller 5th gear please note this (ie: 5M w/.681)
FUEL TYPES:
Bx = biodiesel - x is the percentage of bio
ULSD / LSD / D2 = normal petroleum based diesel
- please note if you are using a fuel additive (ie: ULSD +PS)
- - Power Service (PS); Stanadyne (ST); Redline (RL)
Entry Format:
Driver:
Miles:
Gallons:
Model Year:
Model:
Tranny:
Fuel Type:
TRANNY TYPES:
FUEL TYPES:
