Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old April 26th, 2008, 13:16   #1
mwood
Default Running biodiesel in 2005 Passat concern
I just read the following article:
http://www.biodieselmagazine.com/art...rticle_id=2290
From what I can gather, it says among other things that biodiesel can work its way into the motor oil thereby degrading its effectivness. I usually change my oil at 10,000 mile intervals. After reading this article, I wonder if I should do it sooner. I would appreciate some opinions from others.
I make my own biodiesel and usually run B20-30 in the winter and B80 in the summer. Any general comments on running biodiesel in the 2005 TDI would also be appreciated.
Thanks.
mwood is offline   Reply With Quote
Old April 26th, 2008, 13:34   #2
weedeater
Fuel Economy: 54/43/38
The tdi doen't use a post-injection regime for lighting off a particulate trap. It doesn't have one.
It may seem like I am doing nothing, but on a cellular level I'm really quite busy.
The game of Bridge is like Sex: You need either a good partner or a good hand.
You're either part of the solution or you're part of the precipitate.
weedeater is offline   Reply With Quote
Old April 28th, 2008, 15:03   #3
T'sTDI
TDI(s): 2001 Jetta
MWood- There wouldn't be any problem burning Biodiesel in an 05 Passat. What weedeater is talking about is the newer diesels have particulate traps to reduce emissions. All a tdi has is a CAT. Your good to go
T'sTDI is offline   Reply With Quote
Old April 28th, 2008, 15:17   #4
mwood
Thanks for the replies.
I guess my main concern was the statement that biodiesel works into your engine oil. I have never heard that before and would think that would be true for any diesel engine and would require more frequent oil changes.
Old April 28th, 2008, 15:48   #5
Volkstraktor
TDI(s): 2005 Passat
I don't know if there is a "concensus" about higher percentage Bio use in the PDs or not. Early on there was much debate on the issue here on the board with much "passion" on both sides of the issue. Much of it seemed to revolve around the added viscosity of Bio over Petro, and how much more stress it might put on the injection system and possibly the top end in our motors. The Search function will give you LOTS to read, but I don't know if it will add any clarity to your thoughts.
2005 Passat GLS - Artic Blue - 35% Tint - Grey Leatherette w/ OEM Brushed Interior Trim -
Fast Valve-stem Caps - Geared & 'Gatored by FixUmHaus 10/10/10
Volkstraktor is offline   Reply With Quote
Page generated in 0.13245 seconds with 9 queries
[Output: 62.48 Kb. compressed to 54.84 Kb. by saving 7.64 Kb. (12.22%)]
