TDIFest 2013 Registration is now open!
Old November 13th, 2002, 10:07   #1
Opetu
Default Engine won\'t start, glow plug light flashing
My Golf IV TDI 2000 won't start, the glow plug light keeps flashing, I have checked the fault code with my vagcom and gotten the following errors, I don't have the bentley CD would someone be able to tell me what is happening, I am suspecting the fuel Pump (actually dreding it's not the pump).
17570 FUEL TEMP SENSOR(G81) SHORT TO GROUND 35-10 INTERMITTENT.
17970 QUANTITY ADJUSTER(N146) UPPER LIMIT REACHED 35-10 INTERMITTENT.
17969 QUANTITY ADJUSTER(N146) CONTROL DEVIATION 35-10 INTERMITTENT.
18009 RELAY FOR VOLTAGE SUPPLY TERMINAL 30 (J317) IMPLAUSIBLE SIGNAL 35-00.
17655 NEEDLE LIFT SENSOR(G80) OPEN OR SHORT TO PLUS 35-00.
Opetu is offline   Reply With Quote
Old November 13th, 2002, 10:19   #2
weedeater
Fuel Economy: 54/43/38
Default Re: Engine won\'t start, glow plug light flashing
If it's not the pump, it's the wiring TO the pump. And the #3 injector.
Inspect the wiring from the pump to the ECU. A connector may be loose or something may have chewed through the wires.
weedeater is offline   Reply With Quote
Old November 13th, 2002, 11:49   #3
Birdman
Fuel Economy: 55 summer 50 winter
IF you have a Tuning Box check it and the wiring as above post. All those codes are from the electronics of the pump.
[ November 13, 2002, 12:37: Message edited by: Birdman ]
Birdman is offline   Reply With Quote
Page generated in 0.12823 seconds with 9 queries
[Output: 51.84 Kb. compressed to 46.82 Kb. by saving 5.03 Kb. (9.70%)]
