Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old April 14th, 2008, 18:48   #1
Savageman69
Savageman69's Avatar
Default Shifter Question?
Yestarday i had the extreme pleasure of driving a 1994 golf vr6 that has probably close to 300whp or more. All i have to say is holly wow nuts. My question is the car had a short shifter in it and it seemed to shift very smooth. Now my car i find is very notchy (i guess how youd put it) it just seems you feel it come out of first and feel it go into second. The golf just gluided into gear. Would say a short shifter make my tdi shift smooth like that or is it a tdi thing to be notchy. Also how do you get the shifter shaft its self shorter i really want a lower profile. Thanks guys.
2012 Highline Touareg v6 TDI - 8spd - Silver - Weathertechs - Buzzken Downpipe/Dpf/Scr Pipes - Hybrid 2260 - 4 Bar Map - JR Auto Performance/Buzzken Stage 3 Tune - 31 BFG k02s - Cayenne Trans Coding - Gutted/Painted Muffler - Full Led Swap
Savageman69 is offline   Reply With Quote
Old April 14th, 2008, 18:52   #2
VwPodRacer
VwPodRacer's Avatar
have a disel geek one in my car and it has a real sporty feel to it.. feels alot different now when i drive other ppls cars without.. i wouldnt go back to stock if anyone payed me.. one of my favourite investments
Evil Things To Come! .:RTDI
VwPodRacer is offline   Reply With Quote
Old April 14th, 2008, 18:55   #3
Savageman69
Okay thanks vwpodracer....so you left the shifter the same height in the car tho.
Old April 14th, 2008, 19:01   #4
burpod
teh stallionz!!1
burpod's Avatar
i have a DG sigma5 shifter in mine... it was kinda notchy at first, but then switched to redline MTL gear oil when i had the tall 5th gear put in - that made a big difference in smoothness (others i have talked to felt the same). i also cut off about 3/4" the shaft of the shifter lever, which to my surprise actually improved the feel a bit. just my thoughts....
82 rabbit AHU 17/22 26psi ported head, 11mm pump, pp764s, franko6 cam, custom ce2 wired, vwmikel tuned
1998 jetta AHU 17/22 26psi pp764s etc
vwmikel tuned
88 scirocco
AHU 2056vl build... delayed...05 jetta tdi & 06 golf tdi
burpod is offline   Reply With Quote
Old April 14th, 2008, 19:04   #5
Savageman69
Thanks burpod ill be ordering that tranny fluid for sure and as for cutting the shifter off how do you get the shifter back together after cutting it
Old April 14th, 2008, 19:21   #6
Wingnut
Wingnut's Avatar
Fuel Economy: 4.5L/100km
If you want to shorten the throw, I would suggest getting the Audi TT shift lever. It is identical to the TDI one, but the pin is closer to the fulcrum, so it has a shorter throw (about 20%). But it still has the weight on it to keep it smooth.
The other short shifters without the weight will feel more notchy as they don't have the momentum from the weight to help them into the next gear. I have used many different versions of short shifters and to keep it smooth, you need the weight and good fluid.
Moving? Need boxes?
Go green and check out FROGBOX.com
Old Ride (2000 Black Sedan): Gone
New Ride: (2003 Silver Wagon): Malone Tuned, T4 injectors, 11mm pump, 2.5" Magnaflow cat back, PD150 intake, OMI, Wingnut SS, ERF 6 speed, Bilstein TC Sport susp. w/GTI springs, Neuspeed RSB, Santa Monica's, Autometer Cobalt Boost & EGT, MFA Sport cluster, GLI Leather seats, SS vacuum lines, AVIC Z3 Nav and I still get 4.5L/100km (I got 3.9L/100k on a tank once)
Some handy 'How to's'
Wingnut is offline   Reply With Quote
Old April 14th, 2008, 19:30   #7
burpod
teh stallionz!!1
burpod's Avatar
i just used a fine hacksaw to cut it off all you need to do is take off the knob & boot. i installed a rieger knob/boot at the same time... much nicer than the stock golf-ball knob, imo. it's not too fancy and has oem feel
vwmikel tuned
88 scirocco
Old April 14th, 2008, 21:19   #8
johnnloki
johnnloki's Avatar
TDI(s): 04 Golf TDI
Fuel Economy: 1100 km tanks, generally
JSP also has a cheapie X axis short shift attachment that apparently works quite well with the audi ss many have.
johnnloki is offline   Reply With Quote
Old April 15th, 2008, 10:27   #9
LA@JSPerformance.ca
This unit is an OEM modified VW Factory unit. This unit works very well with any of our or the comepition short shift units. This unit is well priced.
LA@JSPerformance.ca is offline   Reply With Quote
Old April 15th, 2008, 13:08   #10
yatzee
yatzee's Avatar
TDI(s): see sig
I have a TT sfhiter, and I'm not all that impressed. It did make a difference, but it isn't that noticable.
2005 C230 6 spd, 1994 E280 5 spd, 1991 405 mi16, 1986 190e 2.3-16. No TDIs in the fleet for now
Please use the search function
yatzee is offline   Reply With Quote
Old April 15th, 2008, 14:55   #11
Wingnut
Wingnut's Avatar
You are right. I was not impressed either. But the OP wants something smooth. And you cannot put smooth & short shifter in the same sentence. By shortening the throw, it makes the shift feel more notchy. Not smooth. I thought the TT was a comprimise between a smooth & shorter throw. Although, the Neuspeed is even shorter than the TT (35% shorter as opposed to 20%), and has a weight to help keep it smooth, but they are around $150-$175. The TT is $50 at the dealer.
If money was no object, I would suggest the JSP one @ $230 and it also has the side to side reduction also:
Moving? Need boxes?
Old April 15th, 2008, 16:51   #12
LA@JSPerformance.ca
Before releasing our product we did extensive research, and found that most people like the short shifter kits but they did not like the 'notchy' feel of the throws. When we designed our kit we took this into account and produced a kit that reduced both the X and Y axis, but retains the stock OEM 'smoothness and feel'. We do make more aggressive kits as per customer requests - but they do become notchy.
Below are two threads regarding customers feed back on Vortex:
http://forums.vwvortex.com/zerothread?id=3176713
http://forums.vwvortex.com/zerothread?id=2986940
Old April 16th, 2008, 04:45   #13
Toronto_Vento
Toronto_Vento's Avatar
Fuel Economy: 50/48/44
Wish JSP had their kit when I bought my dieselgeek. Nothing really wrong with the dieselgeek, but would have been nice to have the weight on there. I've gotten used to the dieselgeek kit, so shifting isn't an issue, but it's a little more notchy than stock.
MK3s had much smoother shifting than MKIVs. I used to have an MK3 TDI and put the dieselgeek kit in for that car. Beautifully smooth. My MKIV takes a little effort to get into gear compared to my MKIII. As stated, though, given the choice, I wouldn't go back to stock on my MKIV.
-- John K
Wingnut's HOW TO's thread
"The commuting system is so badly broken that it will take decades just to bring it up to a level where it is merely malfunctioning." - Globe Drive
Toronto_Vento is offline   Reply With Quote
Page generated in 0.15762 seconds with 9 queries
[Output: 116.40 Kb. compressed to 97.21 Kb. by saving 19.19 Kb. (16.48%)]
