Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old April 10th, 2008, 10:46   #1
NaughtyVWGirl
NaughtyVWGirl's Avatar
Default Transformer oil for fuel??
I have a friend who works for one of the public utility companies. He is wondering if waste transformer oil could be used to make biodiesel or burned in a WVO car? Anyone here know?
~Resident Biodiesel junkie & Ron Paul fan~
1982 Jetta with AAZ transplant, 1979 German Rabbit also with AAZ transplant, 2001 Jetta TDI GLS, 2007 Kubota BX1850 loves the bean oil too.
Previous: 2001 Golf TDI GLS, 2004 Golf TDI GLS, 1980 Rabbit diesel, 1986 Jetta TD. (The rest were all gas cars)
NaughtyVWGirl is offline   Reply With Quote
Old April 10th, 2008, 10:48   #2
dieseldorf
top post dawg
dieseldorf's Avatar
Hi, Girl. Sounds like experimentation there!
Don't stand behind the car when it's running
Welcome aboard!
Old April 10th, 2008, 10:48   #3
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
I thought that stuff had nasty stuff in it like PCP?
-tom
autos: 15 Volvo V60, 08 MB E320 Bluetec
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old April 10th, 2008, 11:01   #4
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
Sure in 1964.
Now it's highly refined mineral oil.
NB_TDi is offline   Reply With Quote
Old April 10th, 2008, 12:00   #5
weedeater
Fuel Economy: 54/43/38
Depends on where it comes from. Personally, I wouldn't do it unless I knew for sure what it was. some of that crap will kill you deader than a sack of hammers.
It may seem like I am doing nothing, but on a cellular level I'm really quite busy.
The game of Bridge is like Sex: You need either a good partner or a good hand.
You're either part of the solution or you're part of the precipitate.
weedeater is offline   Reply With Quote
Old April 10th, 2008, 12:08   #6
compu_85
Gadget Guy
compu_85's Avatar
If you could confirm there were no nasties in the oil, I'd think it could be a good fuel, there wouldn't be as much crap in it as other WVO sources.
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old April 10th, 2008, 12:17   #7
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Old electrical transformers and oil-filled switches had polychlorinated biphynls (PCBs) in them. So did some other hydraulic fluids used in hydraulic power systems. The main purpose was that PCBs make an oil fire retardant. They were found to be a carcinogen and have been known to cause deformaties in aquatic life (Lake Michigan fish, for example). They were banned in the mid 70's (or earlier, I believe) from being used.
Through the years, power companies and industry has gotten them out of the system by replacement. Most were incinerated in EPA approved incinerators like the one here in Deer Park, Texas (Rollins Environmental Services).
If you are going to use transformanr oil as a fuel, make sure it contains less than 50 PPM (parts per million) of PCBs. That is the number that EPA designated as "PCB free".
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old April 11th, 2008, 03:32   #8
BioDiesel
TDI(s): '98 Jetta
"power companies and industry has gotten them out of the system "
They missed a couple.
Two years ago a transformer leaked in our town's high school.
It had PCB's in the oil. Cleanup was estimated at 1/2 million dollars.
Burning that oil in a diesel would make you a pariah on the scale of the
captain of the Exx0n-Valdez
BioDiesel is offline   Reply With Quote
Old April 11th, 2008, 11:17   #9
NaughtyVWGirl
Thank you for the responses. I understand that their "toxic department" keeps a close eye on the PCBs. So does anyone have any further details about burning non-PCB mineral oil as a fuel?
Old April 11th, 2008, 12:04   #10
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
You'll be de-watering? One of the reasons for changing transformer oil is absorbed moisture; I used to service the Karl-Fischer equipment used by the local Utility to measure levels...
DPM is offline   Reply With Quote
Old April 11th, 2008, 13:14   #11
aja8888
aja8888's Avatar
When I worked for Anaconda in Ansonia, CT, we got rid of 25 or so PCB transformers. Yes, there are still lots of them out there.......
Old February 14th, 2011, 17:28   #12
philngrayce
Fuel Economy: 53/43/49 ('02 Jetta 5 sp)
BUt really, really look put for the PCBs. They're bad.
philngrayce is offline   Reply With Quote
Old February 14th, 2011, 17:35   #13
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
This is just a BAD idea due to the fact that the oil could possibly contain PCBs. You just do not know if it's mixed in or not.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old February 14th, 2011, 17:37   #14
aja8888
aja8888's Avatar
The stuff is "fire retardant" as that is why it is used in transformers and hydraulic systems. So it contains some chemicals to render it fire retardant. Don't use it in high concentrations as it does contain chemicals that may be detrimental to pump seals, etc.
I am not a chemist, so I can't provide detail on it's chemical properties.
Old February 14th, 2011, 17:57   #15
bluesmoker
bluesmoker's Avatar
Fuel Economy: 57 highway mpg
perhaps the most environmentally irresponsible post i have read during my entire life here at the club
burning ANY pcbs leads to the production of dioxins and furans; two of the most toxic substances known to man
if you have any moral fibre you will stop using this crap today, now, immediately
http://en.wikipedia.org/wiki/Transformer_oil
http://en.wikipedia.org/wiki/Polychl...enzo-p-dioxins
http://en.wikipedia.org/wiki/Polychl..._dibenzofurans
2004 pd 5 speed tip,malone tuning stage 1.5 with egr delete
former:1998 red jetta 5 speed man, malone tuning stage 1 with egr delete (it still lives in Maple Ridge)
new gas guzzler: 2001 Mercedes Benz Ml 320
bluesmoker is offline   Reply With Quote
Page generated in 0.17616 seconds with 9 queries
[Output: 128.78 Kb. compressed to 107.38 Kb. by saving 21.40 Kb. (16.62%)]
