Old April 10th, 2008, 11:35   #1
dave23703
Default V Belt Tensioner shock absorber
Does any one know if the shock absorber for the tensioner can be bought separately and what do they go for
2000 jetta tdi
dave23703 is offline   Reply With Quote
Old April 12th, 2008, 14:00   #2
theeman23_69
i purchased a ribbed belt tensioner from the dealer and it doesnt have the shock on it. i am wondering if the belt i got with my TB kit from tdiparts.com will work with it. i will post a picture in a little bit. btw both the old tensioner and the new tesioner have the same part number. maybe its a new "upgraded" version.
theeman23_69 is offline   Reply With Quote
Old April 12th, 2008, 15:02   #3
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
ALL ALH motored cars have the tensioner with the shock. And NO it's not available seperate. If you have a tensioner without one they sold you a BEW or a BRM tensioner from a PD car.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old April 12th, 2008, 16:29   #4
theeman23_69
here is the picture of the two tensioners with the same part number. notice the lack of the shock absorber. the alignmentof the two pulleys appears to be similar. anyway they sold me a different belt than the one i got from tdiparts.com, hope it works out.
Old April 12th, 2008, 16:35   #5
HatefulMechanic
HatefulMechanic's Avatar
that is a PD tensioner, and will not work.
you have incorrect parts.
HatefulMechanic is offline   Reply With Quote
Old April 12th, 2008, 16:56   #6
theeman23_69
thank you. I am now going to go strangle my local parts guys.
Old April 12th, 2008, 17:05   #7
Losha
Losha's Avatar
Hmm, why exactly it won't work?
VDUB Auto Repair www.vdubauto.com
Malone Tuning Dealer for SD, ND NE, IA, MN
'06 Jetta TDI DSG - Malone tune, Bilsteins B6, H&R Sport Springs, GLI front end, HID
Losha is offline   Reply With Quote
Old April 12th, 2008, 17:13   #8
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
I may be blind, but the mounting holes look different...
Theeman: As for the 2 tensioners having the same part number... are the numbers stamped on the parts or do you have the part numbers only from the receipt?? I've seen many VW parts department give out wrong parts on account of them having been stocked in the wrong bin...
Yuri.
ymz is offline   Reply With Quote
Old April 12th, 2008, 17:48   #9
Losha
Losha's Avatar
Yuri.
Lol, I know it won't work, otherwise I would have used gasser one on my TDI. I was just acting dumb, I have couple used ones from gasser in my tool box laying around.
If tensioner shock is dead you can install spring $4 from ACE and it will work fine for long time.
Old April 12th, 2008, 18:16   #10
theeman23_69
the hole locations are the same. Im thinking about just installing it to see if it fits properly. and yes the part numbers are stamped on the part. 038 903 315
Old April 12th, 2008, 18:40   #11
ymz
The ALH model should have a "C" suffix, the BEW model should have an "AE" suffix...
Yuri.
Old April 12th, 2008, 18:48   #12
theeman23_69
well thats the problem then. i shall go and take the wrong part back and get the right one. thanks guys
Page generated in 0.14318 seconds with 9 queries
[Output: 101.39 Kb. compressed to 84.63 Kb. by saving 16.75 Kb. (16.52%)]
