Just to let you guys know the gains are big with the 4cly turbo diesels, We recently did a demo in the Philippines to show our kits out and heres some results.
This is his set up, We completely ditched the factory intercooler, There is a DO1 nozzle pre turbo which you can see from the charts the resutls of the instant spooling it provides even with 100% water the TQ off the line is impressive and a DO2 nozzle at the intake to further cool things down. Now a DO3 nozzle at the intake would work just as well on most vehicles but this one struggled to make boost so we did pre-turbo which makes the little turbo act like a big one.
We did pulls with 30/70 methanol/water and then switch over to 50/50 denatured because the meth was already mixed at 30% gains probably would have been even greater with the methanol.
Note the mixture was 30/70 methanol/water if it is not stated on the dyno sheet. The other mix we use was 62P bottle of Ethly alcohol from the drug store 500ml and 500ml water for the 50/50 mix. The gains were huge
System activates at around 1400rpm on this 2001 Starex
BASE LINE VS 100% WATER
Note 30lbs or around 40nm tq that you have at activation of the system even with 100% water vs the stock. This is the pre-turbo injection benifit. Little turbo acting like a bigger more efficient turbo.
Here is a comparison of different activation points with 30/70 methanol /water..
TQ numbers
Notice the 50lbs or 67nm improvement at 1500rpms and 38lbs or 51nm at 2500rpms.
This is were we change it up to 50/50 mix, The methanol was already pre-mixed so we had to go with ethyl alcohol which I bought for 62P in a 500ml bottle. Gains will be higher with methanol because it has a higher octane number and better cooling.
Once again 50lbs more TQ AT 1500rpm the turbo spools up instantly when the system starts to inject. The effect is instant torque at low RPM's.
Here is a Mazda MPV that just installed the kit and the dyno results from 3 days ago.
Great results at 1500 to 3000rpm power and torque increases are great but the turbo does fall flat on it's face at around 3600rpms a pre-turbo nozzle would give you alot more gains in your top rpm range.
But look at the max gains.
1500 rpms 14hp TQ 47LBS Max HP Gain 43% Max TQ gain 46%
2000 rpms 32hp TQ 84LBS Max HP Gain 63% Max TQ gain 65% HUGE!!
2500 rpms 17hp TQ 36LBS MAX HP Gain 20% Max TQ gain 21%
3000 rpms 10hp TQ 19LBS MAX HP Gain 10% Max TQ gain 11%
To give you a ideal how well the system is working when you just look at the gains on just water alone it's enough to be impressed.
1500rpms 6.3hp gain- 20% over stock / TQ 22lbs 22% over stock
2000rpms 18hp gain - 36% over stock / TQ 47lbs 36% over stock
2500rpms 12.5hp gain- 15% over stock/ TQ 26lbs 15% over stock
3000rpms 6.9hp gain- 7% over stock/ TQ 12lbs 7% over stock
Even just using water give you good gains and if you want more power just add some alcohol to the mix and you got it. There is simply no modification for the money that can do this and all without changing anything about your engine. Even on pure water you get marked improvements in acceleration and fuel economy as well as reduced emissions.
As we stated before these vehicles have undersized turbos and the pre turbo injection signifiacatly helps them with the top end power Just compare the starex dyno. If he puts on a Pre turbo nozzle the power up to will be much greater.
All in all very impressive must be a blast to drive compared to stock.
TQ numbers
