Old April 9th, 2008, 07:58   #1
tompholden
Default 2000 Beetle automatic transmission filter change
I just found the TDIClub article on How to change the ATF fluid & filter. I was unbeliveably well done with great pictures!!!!
Any DIY'er can do this!
Thank you all so much!!
I just purchased a used 2000 VW Beetle with 130,000 miles. I an in the process of changing the filter and am concerned. When I open the pan the filter was sitting on the bottom of the pan. The new filter has no mounting screws to the transmission boidy and only appears to be held in place by the friction of the gasket into the transmission body. Seems strange!!!
I also would like to know how to top of the system to the corrcet level during the refill process. I am told it is 3.2 Liter at 95 degrees. I have also heard to fill until it flows out the fill tube. Does any one have a detailed filter change instruction they can send me.
Love this site!!!
Tom Holden
Billings, Montana
tpholden@aearchitects.com
tompholden is offline   Reply With Quote
Old April 9th, 2008, 08:34   #2
HopefulFred
HopefulFred's Avatar
Fuel Economy: ~39 USMPG
Lots of trans filters are held on only by an o-ring (and probably the suction of the pump). If the old one was in place and you have the proper filter to refit with a fresh o-ring, I wouldn't worry at all.
I don't have any information about the proper procedure to refill the transmission. Sounds like you could use a Bently repair manual. Someone reading probably has one and will help.
Welcome to the club!
Novice VCDS user.
Proud owner and successful two-time user of AST timing belt tool kit.
HopefulFred is offline   Reply With Quote
Old April 9th, 2008, 09:00   #3
basskleff
basskleff's Avatar
Fuel Economy: 40-43 overall
Yes, filter is press fit onto valve body.
You really need Vag-com to measure the fluid level, because it's all done through the ECU(computer) at the correct tempurature. See Bentley manual.
If you don't want to bother, I think 3.2 -3.3 liters is about the right amount.
Use Pentosin OEM Fluid from one of our vendors or buy from the dealership.
They don't tolerate anything else.
2003 Beetle GLS TDI auto 4spd. 01M --> (bet ya $$ it goes 250k+ miles, any takers?? ), 129K miles. Evolution Imports skid plate. Rocket chip RC2 Ventectomy. 40+MPG overall.
basskleff is offline   Reply With Quote
Old April 9th, 2008, 09:07   #4
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Amsoil ATF has been used with the 01M auto trans by at least one board member with success, but go with the OEM (it's non-synthetic BTW) fluid to be safe.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old April 9th, 2008, 09:09   #5
dieseldorf
top post dawg
dieseldorf's Avatar
...and another reported failure within a few thousand miles after filling with that product, AJ
Old April 9th, 2008, 09:16   #6
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
...LOL... yeah, stick with the OE stuff.
oilhammer
www.cardocautomotive.com
Page generated in 0.13550 seconds with 9 queries
[Output: 73.46 Kb. compressed to 63.76 Kb. by saving 9.70 Kb. (13.20%)]
