| TDI 101 Got a simple/basic TDI question? Are you a newbie (new to the forums). Feel free to post your question here. |
March 29th, 2008, 13:43
#1
Volkswagen part numbers
What is the best way to look up Volkswagen part numbers with a diagram. I notice that when I pick up parts from the Volkswagen dealer that they use a system called ETKA or at least that what printed out on top of the diagram I got from them. I read in a couple of threads that this system is not available to the public and I also found Vagcat.com. What is the best system to look up part numbers that has a diagram. Thanks
1997 Passat TDI, Ventectomy , Kerma chip tune, PP357
March 29th, 2008, 17:13
#2
VAG-COM is the easiest.
An all TDI Family!!
March 29th, 2008, 17:19
#3
I must be missing something. Are you telling me that Vag-Com can also give you the VW OEM part numbers. I know about how to run a scan and look at the error codes but I am talking about finding a part number (for example-I would like a new black end cap that goes on the injectors for cylinder #1).
March 29th, 2008, 17:21
#4
TDI Lifer
Fuel Economy: Old Passat 40 Mercedes 20
No...........
2013 Jetta Hybrid SEL Premium Frost Silver/Titan Black
1996 Passat TDI Storm Grey
1984 Mercedes 300D Blue/Green
March 29th, 2008, 17:24
#5
There are some boot-legged copies of ETKA out there....
However if you are looking for something specific once in a while, just ask here someone could help you.
PM me if you like. Also, many parts on your car already have VAG part numbers on them.
Read here about the VAG system:
http://forums.tdiclub.com/showthread.php?t=202957
March 29th, 2008, 17:37
#6
You mean a 028 130 229A Cap?
An all TDI Family!!
March 29th, 2008, 19:33
#7
Thanks for the information and help. I honestly thought you could just pay a fee and get access to the information somehow. In the last few days I learned how to swap out the injectors and the ECU in my car using the information posted in the forum. For any newbie reading this and thinking about installing new nozzles, I can tell you as a newbie myself, get the extraction tool that metalnerd's sells or from one of the other vendors listed on the forum. Mine came out with very little effort using that tool. Thanks again
March 29th, 2008, 19:41
#8
Thanks for the information about the part number. How much pressure are the injector return line under anyway. I had just enought of the old cap to cover it until I can get a new one.
March 30th, 2008, 04:56
#9
Low pressure. If it's damaged in any way, I'd get it replaced.
An all TDI Family!!
