Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
User Name
Password
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Thread Tools Search this Thread
Old March 25th, 2008, 11:59   #1
tnp
tnp's Avatar
Default BSFC (Brake Specific Fuel Consumption)
Being a newbie, I've been reading a lot of threads. There are many mentions to the most efficient range of the RPM curve. A little Googling ran me into some neat terms: BSFC (Brake Specific Fuel Consumption) being the most interesting. I've seen graphs of BSFC vs Engine RPM vs Torque, and BFSC vs BMEP (Break Mean Effective Pressure, or Engine Load) for various engines - but not ours...
Using the minimum fuel for the power produced should equate to the highest fuel economy. While I appreciate the different posts that users state where they believe those points are, it would be great to see some actual data. This would validate a lot of things, such as what really are the best shift points (under various conditions), how quickly to accelerate, among other things. Then, one could use VAG-COM to validate these assumptions and even calculate/predict the best shift points and acceleration modes under particular conditions.
Does anyone have these for a Beetle TDI 1.9L? Or, would anyone know how we can get this?
Thank you!
2000 Beetle GL 1.9L TDI 5-speed Manual
No Mods (for now) except tires Michellin Energy MVX4's @ 45psi and DRL Disabled
tnp is offline   Reply With Quote
Old March 25th, 2008, 13:08   #2
Bob_Fout
Bob_Fout's Avatar
Send a message via AIM to Bob_Fout Send a message via MSN to Bob_Fout Send a message via Yahoo to Bob_Fout
There is a chart of what you are wanting around here somewhere.....
Originally Posted by TDIJetta99
Typically the flaming carbon will fly 20-30 feet depending on what you use for an air source.
Now with Mobil 1 0w40
OCD TDIClub Member #3
Photos | Mods | CJ-4 Oils | Oil Analysis | AFE CAI | AFE CAI Video
Bob_Fout is offline   Reply With Quote
Old March 25th, 2008, 13:16   #3
Bob_Fout
Bob_Fout's Avatar
Found it. DBW had it in his pics.
Old March 25th, 2008, 13:21   #4
nokivasara
nokivasara's Avatar
That confirms what´s been discussed many times, these cars are most fuel efficient at 55mph.
Edit: The BSFC is always at peak torque, isn´t it?
Golf TDI 90hp (AGR engine = wg turbo) A4body -98
AMT
nokivasara is offline   Reply With Quote
Old March 25th, 2008, 13:22   #5
Bob_Fout
Bob_Fout's Avatar
Who drives that slow anymore though :-\
Old March 25th, 2008, 13:24   #6
nokivasara
nokivasara's Avatar
I think the car runs great at 120kph, and that´s where I set the CC
AMT
Old March 25th, 2008, 13:25   #7
Bob_Fout
Bob_Fout's Avatar
Ya, at 70 MPH and up it feels good.
Old March 25th, 2008, 13:36   #8
flatopete
Indeed, the cars do run just fine/great at ~75 mph and faster. I drove a BMW 530d at about 130mph (210kph) on the Autobahn in Bavaria and it also felt just fine and "ran great" but certainly wasn't as efficent as it could be. I've only ever driven that fast in Germany late at night. The rest of the time I spent on the highways was "with the flow" at about 80mph (70 - 90 average and of course some care are slower).
flatopete is offline   Reply With Quote
Old March 25th, 2008, 13:39   #9
dubvulture
dubvulture's Avatar
45 to 55 mph for approx. 18 miles every morning. Of course that's at 3:00 AM and on a stretch of rural highway where the speed limit is 45. It's fuel efficient and it makes it easier to dodge all the deer here in PA!
"The man who sailed around his soul
From East to West, from pole to pole
With ego as his drunken captain
Greed, the mutineer, had trapped all reason in the hold." - Andy Partridge
dubvulture is offline   Reply With Quote
Old March 25th, 2008, 13:42   #10
nokivasara
nokivasara's Avatar
But if you were driving faster you´d be past the deer before it runs up on the road!
AMT
Old March 25th, 2008, 13:45   #11
dubvulture
dubvulture's Avatar
LOL! A lot of trucks run the same road and you should see what's left of those deer when they collide. Meat explosions!
Old March 25th, 2008, 14:51   #12
TDIMeister
Moderator at Large
TDIMeister's Avatar
This chart only shows BSFC at full load at the given RPMs. However, nobody drives at full load under normal circumstances.
A more useful map of BSFC over the entire range of operating speeds and loads (BMEP) is below, for an ALH TDI:
It can be seen that the minimum BSFC of 197 g/kWh occurs at around 1750 RPM and just shy of the full-load curve. However, a steady cruise, say in 5th gear at that RPM, would be far, far less for a correspondingly higher (worse) BSFC.
TDIMeister
Performance Through Engineering
Leistung Durch Ingenieurwissenschaft
TDIMeister is online now   Reply With Quote
Old March 25th, 2008, 14:57   #13
TDIMeister
Moderator at Large
TDIMeister's Avatar
The most economical shift point is the tallest available gear for a given road speed at almost any RPM above 1000 RPM (note the curves of constant BSFC curve back upwards as engine RPMs are reduced closer toward 1000 RPM; this is most noticeable right around 1000 RPM around the 8-10 bar BMEP area.
TDIMeister
Old March 25th, 2008, 15:15   #14
TDIMeister
Moderator at Large
TDIMeister's Avatar
A more useful illustration is to superimpose curves of constant power onto a BSFC map (given in the blue curves below):
Each curve represents a constant horsepower developed by the engine. If you are driving on a given road with a constant grade, speed, and ambient conditions, regardless of which gear you are in, it requires roughly the same amount of power to overcome aerodynamic drag, rolling resistance and driveline losses. Therefore, regardless of what gear you're in, you're riding anywhere along the same blue curve; exactly where you sit on that blue curve being only dependent on the gear you're in and therefore the RPM at which the engine is turning over.
If I take the example of operating on a certain speed such that the power is 20 HP, The lowest BSFC occurs when running at the gear that corresponds to about 1250 RPM. If I run at either a higher- or lower RPM from this point, my BSFC will increase. This is about the only point in the entire engine map where it would be disadvantageous to operate at an even higher gear if one were available (lower RPM) because of the worsening BSFC. Almost everywhere else, the lowest BSFC is achieved at the lowest possible RPM at a given power.
TDIMeister
Old March 25th, 2008, 15:54   #15
TheTDIWagonGuy
TheTDIWagonGuy's Avatar
Are you sure?
Very interesting!
2003 Bora Wagon, 5 Speed, 282,000km, Defender Skidplate, 2.5" SS Down Pipe, MA-Z1 225 45R 17, Lubromoly 505.00 5w40, ecode HID projectors, G60/VR6 Clutch, TT LCA Bushings, Redline MTL, Home made Boost Valve, Wingnut short shifter, ARP Headstuds, 216's, 5 Light Brake, Aspherical Mirrors, Phatnoise
Galvanized Steel Skid Plates For mk4's $195us
TheTDIWagonGuy is offline   Reply With Quote
Search this Thread:
Advanced Search
vB code is On
Powered by vBulletin Version 3.5.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.11530 seconds with 10 queries
[Output: 105.13 Kb. compressed to 97.63 Kb. by saving 7.50 Kb. (7.13%)]
