Old March 16th, 2008, 17:31   #1
buccicone
buccicone's Avatar
Default VW Radio codes retrival
Does anyone know if the VW Dealer charges $$ to retrieve the radio codes When you get one from another VW and don't have the code?
Mike
buccicone is offline   Reply With Quote
Old March 16th, 2008, 17:58   #2
compu_85
Gadget Guy
compu_85's Avatar
If you pull the radio for the dealer they should be able to look it up for free.
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old March 16th, 2008, 18:06   #3
mypassat
TDI(s): Jetta
We don't charge anything---Wish I could give you my login at www.vwhub.com
mypassat is offline   Reply With Quote
Old March 16th, 2008, 18:20   #4
ninedee_golf_tdi
It takes the vehicle vin # as well as the radio serial number to retrieve the security code. If the two numbers don't match (i.e. the radio was replaced) you are sol.
ninedee_golf_tdi is offline   Reply With Quote
Old March 16th, 2008, 19:14   #5
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
My local dealer did not charge me for the code. The parts guy actually took about 20 minutes, then entered the code into the radio to confirm.
Tony
Diesel fleet: 2015 Jetta TDI SE DSG; 2006 Jetta, TDI, DSG-5sp Conversion; 2006 DC Cummins, CC/LB/DRW; 1996 Passat TDI, 5sp, Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old March 18th, 2008, 15:33   #6
mrw
Fuel Economy: 45/40/38
The local thief (dealer) in Langhorne, Pa would not do it for less than $89. flat charge. My radio has not functioned for 2 years. I refuse to be screwed by a scum bag dealer
99 Jetta TDI (old style)
mrw is offline   Reply With Quote
Old March 19th, 2008, 16:55   #7
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
I needed the code once. The replacement radio was from a junkyard, VIN unknown. No charge for the code retrieval, HOWEVER... They don't hang around getting paid by the franchise owner to give away their services. My look-up was a courtesy thanking me for the other parts purchases I was making that day.
The $89 charge others assess is keeping out free-loaders asking for hand-outs. Schedule some service there and add in retrieve the code. I'll bet it's complimentary then.
Svante Arrhenius 1896
Old March 30th, 2008, 12:05   #8
buccicone
buccicone's Avatar
Since I did the original post, I got the code from the "Stealer" for no charge over the phone. I saw in the owner manual they are not to charge for the codes. It maybe free for the original radio if it matches. You need the V.I.N. # of the vehicle and the radio "V.I.N." which is stamped in the side.
Mike
Old November 15th, 2008, 13:24   #9
anahii18
TDI(s): none
Hey I am having the same problem, i called the dealer and they want to charge me...who is the stealer so I can get my free code 2!!!!!! I want my code for free~~~ i go to college and paying 100 bucks is not an option!!!!!!!! help
anahii18 is offline   Reply With Quote
Old November 16th, 2008, 03:43   #10
TonyJetta
anahii18,
Call around to other dealers. Being in vegas, there is a dealer in LV and Henderson. If one doesn't want to be helpful, try the other.
In my case, I have a good relationship with a parts guy; he was able to spend 15 minutes calling VW to get the safe code for mine.
HTH
Tony
Page generated in 0.13388 seconds with 9 queries
[Output: 93.83 Kb. compressed to 79.39 Kb. by saving 14.44 Kb. (15.39%)]
