Old March 6th, 2008, 09:02   #1
IbizaTdiPD
Default Stroker KIT to 1.9 TDi Pd ?
Hy,
Exist any type of stroker kit to my 1.9 TDI PD motor ?
Thanks,
IbizaTdiPD is offline   Reply With Quote
Old March 6th, 2008, 09:05   #2
StingrayRT
StingrayRT's Avatar
Originally Posted by IbizaTdiPD
Hy,
Thanks,
Yes it exist a 100mm crankshaft and 82mm pistons
Crazy engine tuner
StingrayRT is offline   Reply With Quote
Old March 6th, 2008, 09:44   #3
IbizaTdiPD
Thanks,
How can i see more specs and prices ?
Old March 7th, 2008, 02:20   #4
apomiett
TDI(s): A2 mTDI
http://www.eurospecsport.com/eurocrankshafts.htm for crank and pistons from StingrayRT
apomiett is offline   Reply With Quote
Old January 10th, 2009, 07:28   #5
elroberl
TDI(s): 1.9 150 cv
Hello.
The connection does not work.
That pieces I need but to make in a 1,9 TDI 150 ARL.
Thanks.
elroberl is offline   Reply With Quote
Old January 12th, 2009, 05:30   #6
elroberl
TDI(s): 1.9 150 cv
Originally Posted by elroberl
Hello.
Thanks.
Hello?
Old January 12th, 2009, 08:56   #7
Yucca
http://www.eurospecsport.com/product...rankshafts.htm
Yucca is offline   Reply With Quote
Old January 12th, 2009, 14:16   #8
Scott_DeWitt
Scott_DeWitt's Avatar
Are those suitable for Diesel use, especially a souped up diesel?
www.advancedautomotion.com
Scott_DeWitt is offline   Reply With Quote
Old January 13th, 2009, 01:35   #9
StingrayRT
StingrayRT's Avatar
Yes that crank can be used for diesel but remember that 130PD and 150PD has bigger rod diameter (big end) so you can use only crank and VE / 115PD /100PD with smaller rods.
Crazy engine tuner
Old January 14th, 2009, 06:27   #10
elroberl
TDI(s): 1.9 150 cv
EBC 105 101 SC 100 038, 06A, 06B 100.0mm 47.758mm New Style Long Nose and Trigger Wheel, Super Light. 12.5kg.
EBC 105 101 SB 100028, 048, 058100.0mm47.758mmOld Style Short Nose and Trigger Wheel, Super Light. 12.5kg
.As it is the correct reference of Crankshafts?
.This is the correct reference of the pistons?
EFP 107 162682.077.01626144203814.8:1Flat
It is not necessary to change the connecting rods?
Because there is no distributor in Spain?
Old January 14th, 2009, 09:16   #11
Rub87
take the long nosed one if you have 038 type engine eg alh/asv/or PD
take short nosed one for older engine, 028 type, AHU/AFN/1Z
the pistons you describe or for gasoline engine wil definatly not work in a tdi.. you need shorter rods and/or custom pistons..
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old January 14th, 2009, 10:20   #12
Scott_DeWitt
Increasing the stroke by 4.5 mm to 100mm, will only yield 1.986 liters as opposed to the 95.5mm's 1.896 liters.
Looks like you'd get more bang for your buck going with an 82 or 83mm piston. With an 82mm bore and 95.5mm stroke you'd get 2.017 liters. with an 83mm bore, would yield 2.066 liters.
Old January 14th, 2009, 10:23   #13
Rub87
maybe 100mm and 82mm then
Old January 14th, 2009, 11:03   #14
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
Good luck with your headgasket then*g*
But one question in general: If a stroker crank is used, it is better to use custom pistons than shorter rods, isnt it?
Seat Leon Cupra R MK1, VW Polo 1.9TDI ASZ
majesty78 is offline   Reply With Quote
Old January 14th, 2009, 11:49   #15
apomiett
TDI(s): A2 mTDI
Propably slightly better due to better rod leight/ stroke ratio but definitely more expensive. I`m not sure if there is enough space between wrist pin and piston deck to make 4,5mm shorter pistons with oil cooling channels and omega chamber.
Page generated in 0.16739 seconds with 9 queries
[Output: 118.94 Kb. compressed to 97.90 Kb. by saving 21.05 Kb. (17.69%)]
