Old February 28th, 2008, 16:19   #1
LiquidBlackDZL
LiquidBlackDZL's Avatar
TDI(s): 2000 Golf
Default 11mm fuel injection pump Bosch part no.
I found a bosch service center that I might be able to get a rebuilt 11mm pump from, but they need to know the Bosch part no. instead of the vw part no. (038-130-107-J). Anyone know what that number is?
LiquidBlackDZL is offline   Reply With Quote
Old February 28th, 2008, 17:53   #2
FlyTDI Guy
FlyTDI Guy's Avatar
Fuel Economy: 56.5/44/41
Not all that familiar w/the Bosch part number stds. Do you see it here?
'01 Jetta GLS, 5 sp, Black on Black, Leather, Sun Roof, MFSW, Monsoon, Cold Weather Pkg., Full LED interior, always a work in progress
FlyTDI Guy is offline   Reply With Quote
Old February 28th, 2008, 18:10   #3
VailPowder
RIP, Gone But Not Forgotten
VailPowder's Avatar
0460 404 977-038 130 107D or E - VWBora, Golf, Polo 1.9TDI, 1996-2001
0460 414 987- 038 130 107H or J or K - Audi A3, A4, Vw Bora, Golf, Passat 1.9TDI, 97-2002
1-877-KERMA TDI / 1-877-537-6283
Sign Up on kermaTDI
LTGB Colt Cams
VailPowder is offline   Reply With Quote
Old February 28th, 2008, 19:30   #4
LiquidBlackDZL
TDI(s): 2000 Golf
Thanks guys, the 0460414987 is exactly what they needed.
Old March 1st, 2008, 18:24   #5
tdikb
Fuel Economy: 30-40
Hey any chances you can get me one?
tdikb is offline   Reply With Quote
Old November 1st, 2010, 03:44   #6
drejck
Fuel Economy: 5,2l/100km
are this all 11mm pump??
drejck is offline   Reply With Quote
Old November 1st, 2010, 12:20   #7
dieseleux
Théoricien -TDIClub Contributor
dieseleux's Avatar
TDI(s): Jetta TDI 02
Fuel Economy: 4.2L/100km
the 414 un bosch number is 11mm pump
the 404 un bosch number is 10mm pump
Dieseleux
Si votre seul outil est un marteau, toute les solution ressemble à des clou.
If your only tool is a hammer, all the solution looks like nail.
dieseleux is offline   Reply With Quote
Old May 2nd, 2011, 12:40   #8
bhodgkiss
whats the difference between h j and k please and which one do i need for a passat B5 TDI AFN? The AHH auto model came with the 11mm pump, think i have to do some electrical tweaks to get it to work?
Can anyone confirm which VW part number i need and the differences?
thanks
bhodgkiss is offline   Reply With Quote
Old May 3rd, 2011, 22:57   #9
adamss24
Fuel Economy: 35-45mpg
thanks
AHH 90Bhp manual has 11mm pump- i have one of a W reg audi a4 saloon ! The h,j and k are revised versions and you will have to change the connector plug to allow it to work on your AFN engine (11mm pumps have 10 pin connectors).
adamss24 is offline   Reply With Quote
Old May 4th, 2011, 05:42   #10
bhodgkiss
thanks for the info, yes i have the info for changing from 10 to 8 pin, bit of a faff but hey!
Old May 5th, 2011, 02:06   #11
cola76
all of them have 11mm pump...
A3 1,9TDI ALH 90PS with Automatikgetriebe
Golf 4 1,9TDI ALH 90PS with Automatikgetriebe
Bora 1,9TDI ALH 90PS with Automatikgetriebe
Seat Leon / Toledo 1,9TDI ALH 90PS with Automatikgetriebe
Skoda Octavia 1,9TDI ALH 90PS with Automatikgetriebe
Audi A4 1,9TDI AHH 90PS
Passat 3B 1,9TDI AHH 90PS
cola76 is offline   Reply With Quote
Old May 5th, 2011, 05:26   #12
bhodgkiss
any of these have 8 pin connectors?
I guess not
Old May 5th, 2011, 22:15   #13
cola76
i used EDC from old 10mm pump...wainting to set it up in vag com!
Old May 6th, 2011, 09:28   #14
cog
11mm pump has 10 pin conectors ben
just make sure you get the timing right
Now BMW 123d @ 272bhp
Formerly GT-TDI 110 AHF VNT 17VB[/B],@24psi ,,R520s,ported head,11mm pump,arp,headstuds,eurojet smic,id parts upgraded pipes,SBC[B] stage 3, pd150 manifold, custom silicone t.i.p 2.5"downpipe and cat delete,racepipe,,pd lift pump
cog is offline   Reply With Quote
Page generated in 0.17161 seconds with 9 queries
[Output: 111.08 Kb. compressed to 91.72 Kb. by saving 19.36 Kb. (17.43%)]
