jollypair
Dear TDI Club,
I finished an 800 mile trip from Northampton, MA to DC and I had to put 5 quarts of 5-40 into my 2003 Jetta TDI Wagon 74K with a Greasecar Kit conversion to run on vegetable fuel oil. I talked awhile with my local VW Dealer Service Manager, Bob Boyle, who suggested the following
1. We check for simply external motor oil leaks - I brought the Jetta in and they watched while running and found no external leaks ($30)
2. Fuel Injector May Need to be replaced $900 BUT he did not recommend this because he did would not know for sure if this was the problem.
3. Piston Problems - Just getting into the engine would cost $1500 and he said it would not be worth it. Just add more motor oil
4. The Veggie Oil may have gummed up the injector or the pistons or seals still equals more money than it is worth.
He is going to put his best Diesel mechanic on the car tomorrow 2-27 for one hour ($82 per hour) and see if there is a quick fix. If it is not a quick fix then he said it probably is not worth doing.
I feel bad about all the blue smoke coming out my tail pipe and I feel really bad about all the money I am wasting.
I did read Vegetable Oil DID NOT EAT MY MOTOR!!!!! but I am not certain about the source of the problem.
Any suggestions would be greatly appreciated!
Sincerely,
Jolly
Sincerely,
Jolly
