has anyone done the city light as DRL mod
here? is it bright enough? I was thinking of putting some really bright
LED in the city light position so i'm not using the H7s so much.
also reading through the how to PDF it seems you just switch the pins that the wires connect to (ie swap the city light and low beam connections). this still allows the low beam to function normally, correct? I don't know a whole lot about electronics, how do the city lights and low beams request their respective power requirements?
